4 hours ago, jd1923 said:
Think HARD about which cable management device you select. Many are overkill and require a large opening. Models suggested here require square or rectangular openings.
My plans is/was to use this bulkhead fitting through the roof as a cable guide and into a utility box on the roof. If this fits in the Icotec 90 degree fitting, I’m golden! Just a drilled hole through the outer hull into the attic.
https://a.co/d/0anCrU1v
Edited by Steve Morris
Steve - Northern Ohio, USA
Facebook - Instagram
40 minutes ago, Steve Morris said:
My plans is/was to use this bulkhead fitting through the roof as a cable guide and into a utility box on the roof...
Personally, I believe the utility box install is extreme overkill. We are NOT installing a 5KW inverter with 1800W solar system in a Class-A, not by any means! Are you needing a 1 1/2" conduit for another half-dozen future rooftop additions, NOT! Please think about the simple realities.
I installed solar on a previously owned RV, by merely drilling two (2) 1/4" holes through the roof, for the two (+/-) 10 AWG solar panel feeds. No box, no Icotech entry solutions, just two simple 1/4" holes and a drip of Dicor on each, still working today, with no leaks. Or you can mount a big-@ss box. You can imagine what my choice would be! 🤣
It's up to you, do you want to mount a 6x10" box and blow two tubes of Dicor all over the roof of your beautiful Oliver?  BTW, a rectangular junction box does not fit nicely on the curved roof of the Oliver!
Most professional installers are young and inexperienced and it's up to you to make the best decisions for your assets. When the guy doesn't agree with you, just hire a new guy.
Sorry @Wildbrew although your install is yes BEAUTIFUL, a work of art, and you should truly be proud of your exceptional work, it's simply overkill! Could be done with no platform and no large rooftop box. (Still love your work yet hoping to advise many others that less is more).
We are to each our own, yet simple is often better. Think hard about your decision. I did my truck mount install in two days, not a single drill hole into our Oliver, just sayin'!
I was working my job last week, teaching my online PMP class when Sparklight went down, resulting in no household Internet. While my students were waiting for just a minute or so, I connected to our truck-based Pepwave cellular router Wi-Fi, with T-Mobile 5G cellular service only missing a heartbeat or two. They had no idea I was gone for a minute. My truck-based Internet service is my also my business back-up internet service, without an installation hole in the Oliver! 😂
@rich.dev, I was thinking again about running the 12VDC to the closet and knew there was a good example of this. Also, running DC lines from there, you could add a dedicated fuse for the router in the DC fuse panel and eliminate the inline fuse in the wiring.
Note the description and pictures on page one, where Art @MAX Burner fishes two large 4AWG cables from the dinette to the bathroom vanity:
Thanks Jd, I like the idea of mounting the router in the closet where it will not take up usable space, but you also now have me really thinking/considdering doing the TV install, only problem is the Peplink Mobilty 42G does not have the magnet mounting option, so I would have to mount it on the fibreglass cap!
I will have delivery of the Max BR1 Pro 5G and antenna in 3-4 wks, so I have some time to mull it over.
How is the reception inside your trailer with the router inside the TV?
Edit: Bummer, just realised the TV install will not work, we have Blink cameras on the Oliver that we want to be able to monitor when away from it!
Edited by rich.dev
Edit: Bummer, just realized the TV install will not work, we have Blink cameras on the Oliver that we want to be able to monitor when away from it!
Reception is great because these 7-way antennas have 4 cellular antennas for receiving signal, one GPS antenna and 2 Wi-Fi antennas to send signal to your devices. The Oliver being mostly fiberglass construction allows radio waves to pass through (will NOT work with a metal-clad Air Stream where they would install a wired access point internal to the TT regardless of antenna location).
@rideadeuce Mike is having an issue with coverage in the TV. He has a 5-way Cradlepoint antenna mounted on the rear of the Oliver. Your idea of mounting to the front awning bracket should be the best mounting location on the Oliver, except for taking a lot of headwinds, so mount it securely.
Keep in mind the Wi-Fi signal originates in the router, but is broadcasted via the antenna, so mounted inside a closet or wherever does not matter except for it needing some, not a lot, of ventilation. Also, I mounted my router with 3M VHB 4950 tape. The only drilled hole you need in the installation is through the roof for the cables.
The Icotek entry solution you were looking at could be installed by drilling two holes with a hole saw vs. cutting a rectangular opening. You only need the double grommet version with four 5mm holes in each and one plug. The cut-out size on this item is 43 × 24 mm. I'd bet 2x a 7/8" hole saw would be perfect! VHB the housing onto the roof and caulk the perimeter. 90 Degree Cable Entry Frame - 2 Socket - 73mm x 53mm – MobileMustHave.com
Your last edit sentence finally gave me a reason for mounting the router in the Oliver! Thank you for that. There is one downside though, depending on where you travel. Out here we camp in many canyons without cell service. So, you would not be able to connect the Blink cameras anyway. When this occurs, we run the TV out of the canyon on a day trip and connect, use our laptops, etc.
The Pepwave router also has the WAN input to add Starlink or like service. If you were to go this route, you would nearly always be connected. Mike also did a nice Starlink antenna install up front and he ran the cable all the way back on the roof. You could do the same front install and run that cable down the same entry point.
If this upgrade may be in your future, buy this Icotek instead and drill 3 holes. Use a grommet plug until you need the 3rd opening: 90 Degree Cable Entry Frame - 3 Socket - 100mm x 53mm – MobileMustHave.com
Interesting solution @Wildbrew for getting the WIFI over and around the Penguin. As @jd1923 stated I do not have great reception in my TV because the PII blocks it. Mine is in the same spot just not elevated. Because of this, I am seriously considering putting the Cradlepoint and the antenna in the front closet since there is a power outlet it would be simple -- just another hole in the roof. Ugh.
But what @rich.dev said is the reason I keep everything in the Oliver is to keep it connected to the outside world. No matter where I am in the world I can check the temperature, change heat and air settings, monitor cameras, get alerts if it moves, etc.
Best,
Mike
-  Mike  Brentwood, TN  -  2018 Elite II  -  Spirit of Adventure Hull #308 -  2016 Toyota Tundra Limited 5.7L  Class IV hitch with 12k lb coupler, Dobinsons HD 2in Leaf springs, Timbren bump stops, Eibach Pro Truck Stage 2R, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Best,
Mike
Apparently my installation offends some people’s sense of aesthetics but I had solid reasons for choosing the components that I did.  After 2 years and many thousands of miles, I’m still very happy with the results.  We continue to have very usable internet access in places where other people struggle to find one bar on their phones.  In fact, when we’re at home, I run an Ethernet cable from the Oliver into the house and use the Pepwave router to supplement the marginal DSL service available in our area.  (The 5G is much faster, especially on upload speeds than the DSL, I just have to be mindful of the data limits of the two cellular plans that we have).  Oh, and no leaks despite NOT using two tubes of dicor… 😉
Overreact much?
I received the IcoTek 90° cable entry kit from MMH today. It's going to work great, and I won't need a box. I'm going to test drill different diameter holes in some thin plywood, and see how small I can go and still get all seven wires through. Then I'll go with the next larger size that I can find a grommet for. Antenna will be on a mast bracket hanging from the rear awning mount.
As previously noted, my Pepwave MAX BR1 Pro is in the attic, and currently using the stub antennas. Yesterday I added a second SIM card from T-Mobile that I got through FMCA. Three months free (from my Mobile Internet Resource Center membership) gives us time to compare it with the Verizon plan through MMH. The router feeds my Apple TV and UefyCam security camera hub via Ethernet, and our phones, tablets, and Sonos Move via wifi. Later I'll add remote temperature sensing and hopefully a full Victron setup.
The router and antenna on the tow vehicle may work for you, JD, and is an easy install. But I don't have a truck, and have no intention of poking holes in my lifelong dream SUV. And, I have devices that I want to be always connected, and that wouldn't be the case with the system in the TV. There are options we can all chose, and just because I'm not doing it like you, doesn't warrant that haranguing...
Nice, which one did you get Steve?
I ordered the KEL-FG-ER-B4 (Part# 42344) with:
1 x 4-hole grommet KT 4/ø5mm grey/part # 39908
1 x 2-hole grommet KT 2/ø5mm grey/part # 41200
1 x 1-hole grommet KT ø2-3mm grey/part # 39934
1 x 1-hole grommet KT ø1-2mm grey/part # 39941 (just in case the 39934 hole is too big for the GPS wire) and 1 x Blank grommet Part # 41251
On 6/27/2024 at 12:03 PM, jd1923 said:
The Icotek entry solution you were looking at could be installed by drilling two holes with a hole saw...
7 hours ago, Steve Morris said:
Overreact much
 Always trying to help, never meaning to offend, regardless the passion of my wordings. 😟 I guess I made my point though.
The truck installation was actually a bit more complex than the obvious attic location, where you have ample room and pre-wired 12VDC. I just got mine done in two days after thinking it through for a few weeks and waiting on parts.
It's far superior for me, since we use the truck all year and the Oliver some 30-40 days. I offered my example as an idea for others on our Forum. It made no sense to me to spend $1600 in parts and $50 monthly for a 5G business plan, to use it only 10% of the year. It's OK we have our own reasons and go different directions.
I'm not interested in remote monitoring of our Oliver, since when we're not traveling, it's parked safely on my property. I learned here that is an important consideration to others. I hope another suggestion I made here re the closet installation will help other Oliver Owners too, for better reception in the TV. Thanks for reading.
I got it from MMH, but looks like the same bits and pieces, except I have a blank instead of the 2-3 to fill the last opening.
  • 3 months later...
Well my install is done, following the advise of @jd1923 and install by @MAX Burner, I installed the Peplink router, Starlink 12V conversion and just for sh*ts and giggles a 12V fan in the closet.
Also, I initially installed the Peplink 42 antenna to the awning with the included L bracket, but that only lasted about 130miles, the one hole in the plastic L bracket broke out and the bracket was only held on by the other screw! Anyway, that was before I decided to add an entry point for the Starlink to the roof for a later flatmount project. I currently have a pole mount and the idea was to add a
Blue Seas Cable Clam hull penetration adjacent to the 7-pin cable like @MAX Burner did with his dc/dc install.  After the Peplink L brack issue, I decided to go with a box on top of the roof with the Peplink antenna sitting on top, and an RJ45 waterproof connector on the side of the box for the Starlink cable quick connect, either for the roof mount, pole mount, or using the 25' cable on the ground.
Here's the box on the roof, I used a Lifegard Aquatics R270577 1" slip bulkhead fitting to feed the 7 antenna cables and RJ45 cable through to inside the closet. Not pretty, and probably should've gone with a slighly lower profile box!
..and the RJ45 waterproof connector on the side of the box for the Starlink cable quick connect, either for the roof mount, pole mount, or using the 25' cable on the ground..
Peplink Router, Fan, 12v thermostat, Blue Sea Systems 5025 ST Blade Fuse Block and EL6 DC/12V conversion kit for Starlink Gen 3
This install (inside the closet) took way longer than I was hoping for, it's a very tight space, and unless you have the shape/flexibility of a spaghetti, you will end up with scrapes and bruises in places you didn't know existed! If I had to do it all over again, I would attach/mount all the wires to the thermostat before mounting it to the wall like I did, and to make things worse, the Blue Sea Systems 5025 ST Blade Fuse Block was mounted before the thermostat, so I had to basically go in blind to mount the wires to the bottom of the thermostat (not shown in my pictures, bottom of the thremostat is obscured by the top of the Blue Sea Systems 5025 ST Blade Fuse Block), but this is what the thermostat looks like at the bottom, I had to get 18AWG wires into that blue connectors, it was literally a pain in the arse!
23 minutes ago, DaveAndBecky_NorthernMI said:
Which model of Peplink router did you go with?
Max BR1 Pro 5G
@rich.dev - Very clean install, brother!  How do you like the performance of the entire new system?
  • 2022 TUNDRA
Thanks Art. The peplink router and antenna works well. I haven’t done much with it, just tested the antenna where my trailer is stored and a difference of approx. 100gb download speed vs regular cell reception IN THAT AREA, could be different in other areas and I know if no cell reception the antenna means buggerall, hence the Starlink for boondocking spots with no cell reception. The Starlink is paused until we will need it so hopefully the 12V conversion and other mods I made for it will work, I’ll know in about a month when we will be down in Arizona.😊
On 10/11/2024 at 11:14 AM, rich.dev said:
Max BR1 Pro 5G
Same here, that’s the model to get.
Glad the closet location worked out for you and the rooftop junction box is a good size considering the antenna. It all looks great.
I get black-n-blue all over my arms, old man’s skin, every time I work an install, just where long sleeves for a few days. 🤣
And if your Arizona trip brings you by Prescott, we have a spot for you with electric and water and can show you amazing dispersed camping locations all over the county!
lol...Yes I feel your pain, I'm in pretty good shape, but its hard these days maneuvering in tight spaces!
Thank you, will definitely keep it in mind, what's the best route from Quartzsite to Prescott?
I suggest the direct route in dark blue except when getting near Prescott take the west loop. A couple of hairpin turns before Yarnell but NP with our short trailers. US Hwy 60, then US Hwy 89 are the main roads. The Q is at 900 FT, Wickenburg at 2000 and Prescott at 5400 FT. The final stretch is a climb up the Prescott NF. Love to see you!
Excellent Boondocking at Wickenburg along the way and another great AZ town to visit with history, good shops and restaurants. Vulture Mountain, Vulture Mine Rd west of town is the camping spot. The mountain really looks the shape of a vulture, neck down feeding.
Edited by jd1923
28 minutes ago, jd1923 said:
I suggest the direct route in dark blue except when getting near Prescott take the west loop. A couple of hairpin turns before Yarnell but NP with our short trailers. Mainly US Hwy 60, then US Hwy 89 are the main roads. The Q is at 900 FT, Wickenburg at 2000 and Prescott at 5400 FT. The final stretch is a climb up the Prescott NF. Love to see you!
Two and a half hours, home to Quartzsite. That's great, it'll take us a week to get there.
Yeah, and you’re close to the annual OTT National Rally! Pulling the Oliver, heavy decline grade on winding roads, a rest stop, it will be 3 1/2 hours. When I was young driving a sports car, I would always beat these estimated times. Not these days.
This year, let’s communicate on your Quartzsite thread when Oliver Owners will be there and we will drive down to meet you!
I agree on formerly being able to beat the projected travel times. In 1978 a friend and myself left home at 1900 one evening headed west. Twenty Six hours later we were sitting at the North Rim of the Grand Canyon. About 1600 miles. We were driving my brand new 280-Z and averaged over 60 mph.
Think it was February of about the same year. By myself in ONLY a ‘76 Malibu, left Chicago late morning and got to a friend's house in Portland the next afternoon. Just looked it up on my phone map and that was over 2100 miles non-stop. Oh, the adrenaline of youth!
About 10 years ago, drove my truck 1100 miles, Prescott to Austin nonstop. That was the last time for me! We left Prescott a full week ago and so far we’ve just entered west Texas, left Ruidoso this morning and spending tonight, free camping at Yoakum County Park. Our longest day driving on this trip will be 4.5 hours, average 3 hours a day. The beauty of a relaxing Oliver trip!
