Somehow  while keeping the Ollie under a cover we got duct tape adhesive on a solar panel, and I'm wondering how to safely remove the adhesive.  Would using GooBeGone be a reasonable choice?
Thanks for the help!
Mary        My husband and I have Hull # 55.  An Elite 2, bought in 2014
WD40 is my adhesive residue cleaner of choice.   It softens the adhesive enabling removal, yet should not harm the solar panel.  Spray it on, let it soak for a few hours or overnight, then wipe it off with something non-abrasive, like a shop towel.  If necessary, repeat.
I now use residue-free duct tape!
I think the most active ingredient in wd40 is mineral oil. I'd try that. Let it sit. Out of sun .
Don't use any mechanical scrapers, unless plastic, imo. You don't want to damage the panel coatings.
And, no residue duct tape is the way to go, as @Rivernerd said, in the future.
I’ve used WD40 for tape residue and goo gone as well.  A plastic razor blade will help.  Mike
Well, thanks everyone for your great advice!  The adhesive melted in the WD40 while I went for a walk, and  I gently wiped the mess away when I got back.    Neat to learn such an easy solution.  You are the best!
Mary
https://www.zampsolar.com/blogs/solar-101/how-to-clean-zamp-solar-panels
I personally would not use WD40 or any other solvent other than the recommended strong isopropyl alcohol for tree sap. I am a big fan of this glass cleaner.
https://www.invisibleglass.com/clear-dry-formula/
Good point.   I’m guessing the petroleum products could degrade the elastomers or sealants that secure the frame.
Thank you for the additional thoughts.  Invisible Glass; will get some.
