I know from your posts, that you have a newer trailer, but, a little bit of info would help, actually.
Is your trailer running on inverter?  I "think" the fridge is separate from the inverter.
I found a Norcold service manual online and it says for the A Default Code:  No AC power available to refrigerator. Possible reasons: AC cord is not plugged into power board or the F3 fuse is open.
2019 Ram 1500 5.7L V8, 3.92 axle ratio - 2020 LEll - Hull676
6 minutes ago, Coach and JoJo said:
We are headed toward higher elevations and I know the LP will not work.
Hull 806....our Norcold recently worked fine on LP  at ~ 7,000 feet.
8 minutes ago, Coach and JoJo said:
How do I access the Norcold power cord? Remove the drawers?
Recent LE2 .....Yes...and a cover panel on the wall.
Fuses under the dinette. Are you trying to run it on DC or AC? Verify your mode setting, battery SOC etc
Yes, remove the drawers under the galley sink.
I believe the refrigerator is plugged into its own duplex receptacle in the area under the sink.  The solution might be as simple as plugging the cord back into the receptacle, then replacing the drawers.
That fridge receptacle is not on the same circuit as the rest of the 120V receptacles; the rest are GFCI protected, while the fridge receptacle is not.  So, it is also possible that the circuit breaker for just the fridge receptacle circuit has tripped.   If the fridge plug is not the issue, then I recommend you check the 120V circuit breaker panel under the front dinette seat to see if there is a tripped breaker in that circuit.
Good luck!
Removing the drwaers is easy if you do not over-think it 😬 It is easier if they are empty of any heavy objects.
https://olivertraveltrailers.com/forums/topic/6734-how-to-drawers-remove-and-reinstall-your-galley-and-end-table-drawers-fix-loose-or-stripped-screws-and-glue-the-bottoms-for-extra-strength/
The fridge power cord is at the bottom front area of the access opening between the outer hull and the back of the cabinet (after you remove its four screws). Mine looked like,this:
Good luck.
Many thanks to John Davies for including instructions on drawer removal, and removal of the access panel behind the drawers.  The Oliver video linked below includes instructions on removal of the access panel, and shows where the fridge plugs into the receptacle behind that access panel.
Legacy Elite II Drawer Removal & Components
Hope this helps.
PLUG had worked loose due to zip tie slipping off the plug. It had not been pulled tight.  I have a 2022 Elite II. The plug is located under the wooden service panel on the bottom drawer. It is not located behind the drawers but under the drawers!
Do you have a picture of this new location? So it is NOT directly below the water lines? If so that is very good news.
I am sorry the plug slipped out, what tire pressure are you running? Too high makes all sorts of odd things happen from shaking the hull violently.
I run tires at 60 lbs.   The major cause was the zip tie was not tight. The plug is located in a wooden service panel under the bottom drawer...VERY EASY ACCESS
Thanks, I wonder when Oliver started putting it under the drawer? It is definitely a dryer spot, or at least, less likely to get soaked if a pipe fails.
