Hi all, do I need to bring a jack along for the unlikely, but still possible, flat tire.  My 2017 Ford Expedition has a jack.  As I understand it, the stabilizer legs aren't meant for lifting the trailer, but only to stabilize it.  I assume on a 2022 LE2 if I was to ride one tire up on an Andersen leveler that the other tire would remain on the ground.  I am getting a few items in preparation for pick up in less than a month.   I did buy a Proven Lock, yoke and Abus lock because I don't want to have this trailer stolen!
You need to have blocks, either wood or the yellow Camco lego style, You can raise one side up with the stabilizer enough for the tire to rotate and block the underside of the axle on that side if you feel like it. I don’t ever bother unless I am about to crawl underneath the trailer. I really doubt that your truck jack has enough lift without using blocks under it. FYI:
https://olivertraveltrailers.com/forums/topic/6549-recommend-a-heavy-duty-mechanical-scissor-jack/
Thanks John, you and others on the forum have been great with advice for this soon to be Ollie owner.  T- 29 days
I carry a large scissor jack (a military surplus HUMVEE jack with frame adapter, referenced in the other thread link that John posted above) and some pieces of 4”x4” lumber for raising the trailer for tire changes and wheel bearing maintenance.   I lift the trailer with the scissor jack and then put the stabilizer down as a safety backup just in case.   Tire chocks on the trailer wheels on the opposite side, and the trailer still hitched to my truck, so the trailer won’t shift at all while lifting.  This setup has worked well and is very stable and safe when I have to work on the trailer.   I prefer overkill when it comes to safety 🙂.   And I don’t trust just using the stabilizers only to lift the trailer for tire changes after seeing how small the welds are on the stabilizer mounting brackets.
Depending on the situation - a single Andersen leveler may or may not be enough to get that tire off the ground.  Therefore, Frank C's suggestion of carrying some form of "blocks"* (certainly these can be "lego" style that JD mentions)** in order to take lateral "pressure" off the onboard jack is worth considering.  Also, as per Frank C - keep the Ollie attached to your tow vehicle and clock the opposite side.  Try to find as level a spot to do the repair as possible - most roads and their shoulders are sloped such that if the flat tire is on the curbside it will require you to lift more weight than necessary.
Finally, if there is any doubt then call for help.  The couple of hours that you might save by doing the job yourself is simply not worth the possible negative outcomes.
*I carry both wood blocks and lego style blocks.  The wood blocks can be had free either around your own workshop or by "scrounging".
** note - these lego style blocks can also be used for help in leveling the tongue when the throw of that jack is simply not long enough to get your Ollie level from front to back.  Or when the Andersen's need a bit of extra help.  Or when your outside grill can't find a level spot.  Or when .....
"I carry a large scissor jack (a military surplus HUMVEE jack with frame adapter,"
Frank, is the frame adapter something specific to the Ollie frame?    I wonder why these trailers don't have disc brakes (just a side note).  Maybe no trailers do.  🤔. Thanks for the picture.
John, T-28 days to delivery day
You can get them here, on backorder right now though. https://agileoffroad.com/
agile-off-road-scissor-jack-axle-frame-adaptor
AO Axle & Frame Adaptor for H1 Scissor Jack
5.0 star rating11 Reviews
$89.95
Out of stock (place order to reserve)
AO Axle & Frame Adaptor for H1 Scissor Jack quantity
Add to cart
Most travel trailers do not have disk brakes.
There are several members of this Forum that consider our drum style brakes to be "garbage".  However, over the years these drums and brakes have done the job in a simple, cost effective manner without major difficulty.  If one keeps them clean and in good repair they should give you years of trouble free service.  Having said this - there is little question that disk brakes perform better over a higher range of conditions as opposed to drum brakes.  But, RV's are not sport cars or airplanes.  Nor are they normally subjected to the same kinds of wear and tear as even our daily drivers.
"*I carry both wood blocks and lego style blocks.  The wood blocks can be had free either around your own workshop or by "scrounging". "
Bill, thanks for the suggestion of the Lego style blocks.  I gave my cube bag that had about 10 of those 1 inch blocks to the new owner of the pop up tent trailer that we sold in July.  Maybe I will buy again.  Good suggestions.
John,
There is a lot of past discussion about this.  I’ve used the on board jack a number of times to raise tires off the ground for various reasons.  I won’t get under the trailer with just the onboard jack but will change a tire.  YMMV.  Mike
Actually it was JED above that suggested the Lego blocks and they are good to have on board.
Having said this - I've only actually used my legos one time in the last seven years!
We use our Legos everytime we set up.  1-4 legos, 8” wooden block and the jack only needs an inch or two of extension.  Mike
Just goes to show how lazy I really am!  My six inch by 11 inch wood blocks are either placed on their sides (6 inches) on on their ends (11 inches) depending on how much room I have.  Certainly as Mike points out - the less you have to extend the on-board jacks , the better - whether that be for leveling or for changing a tire.
Blocking the rear jacks is prudent… if you have a major brain fart aka senior moment and drive away with the jacks down, they will hopefully survive without bending. I flag my gear shift with red surveyor’s tape whenever the trailer is hitched AND a jack is extended…
Bill, I ordered the Camco stacking jack stands as it seems it makes more sense to not extend the stabilizer jacks so far for reasons of less wear and distance to the ground.  Not so much flex pressure on the mount.  My wife is rolling her eyes when another box is delivered to the house.  It's all necessary though.  TPMS, water pressure gauge, Proven lock, surge protection, etc.
Most of these things are really not "necessary" for you to enjoy your Oliver.  However, they do make the experience more relaxing and or easier or safer than it would be without them.  They tend to save you time, energy, worry and simply make the whole camping/traveling experience more enjoyable because you spend less time working, thinking, worrying and more time doing what you really want to do.
It will not be long now and your delivery will pass you by as if being played in triple fast speed.  Try to resist buying anything but what you feel is necessary and then add later depending on your style of travel and camping.
I never buy anything that I don’t absolutely, positively think that I MAY use one of these days.
  • Haha 3
I am focusing on safety and trailer protection.  There's always the must haves and the wants.  TPMS was expensive but I felt it was a necessity.  That's my approach.  The forum has been great for ideas of those must haves.
Two big thumbs up on that TPMS!
Good for you!
John, I applaud your approach to purchases.  I don’t think we’ve yet had the pleasure of actually meeting each other. But those that know me and have seen our truck, probably recognized the tongue in cheek sarcasm of my post. When we meet, you’ll see what I mean.
Since we have a long, multi-day trip home to Idaho after we take delivery on November 10, I purchased (at John Davies' suggestion) a Safe Jack 6-ton RV Jack.  It includes extenders that should enable it to reach the jacking points on the 2022 Elite II, from the ground.  The kit includes a u-shaped frame adapter that I hope will fit the Elite II frame and enable a more secure connection with the trailer.
https://www.4wheelparts.com/p/safe-jack-6-ton-rv-jack-kit-37m-rv6/_/R-SAJK-37M-RV6?ppcfon=1&gp=1&ecmp=s:google_15843829820___&utm_source=google&utm_medium=cpc&utm_campaign=SC Shopping - Tires & Wheels - Performance Max&gclid=Cj0KCQjwhY-aBhCUARIsALNIC06UbEzgITJgaGQn_rPib0QBhxX7NiH5oVwxeWUM_qjnkqbeLh5T-FgaAsOiEALw_wcB
Not cheap, but worth the peace of mind to me.
I also have a set of the Camco Large Stabilizing Jack Pads, to provide a  solid base for the Safe Jack, if needed.
https://www.amazon.com/Camco-Large-44541-Stabilizing-Jack/dp/B005BNZ9UM/ref=asc_df_B005BNZ9UM/?tag=hyprod-20&linkCode=df0&hvadid=198056825273&hvpos=&hvnetw=g&hvrand=9575626206363820960&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9029558&hvtargid=pla-438289870527&psc=1
If I have to change a tire, I plan chock the wheels on the side opposite the flat, jack up the side with the flat using the Safe Jack on a Stabilizing Jack Pad, then lower the stabilizers to provide additional support and stability.
LE2 2022 Hull 806 here,
I utilize a HFreight ramp I already had on hand....it works great to lift either tire off the ground. It has 6.5" of lift and is as simple as it looks.
I use the ramp to take tires off when I grease the zerks. I hope I never have to use it on the side of the road, but I have complete confidence if I need to do so.
Steve, how much does it weigh?    Do you bring it on the road?
"If I have to change a tire, I plan chock the wheels on the side opposite the flat, jack up the side with the flat using the Safe Jack on a Stabilizing Jack Pad, then lower the stabilizers to provide additional support and stability."
I bought the Camco levelers today and also two heavy duty solid rubber chocks.  The guy at the RV parts store said that once I have the tires in the levelers on the low side and chocked with the Camco leveler and chock, that I won't need to buy two more heavy duty rubber chocks for the low side.  What are you bringing in the chock department?
