I should do a charity fund and have bidding wars.  Great promo for Oliver.  LOL
Chris
2016 Legacy Elite II  o-o  Hull #110  o-o  "Rock'in 110"  o-o  Twin Bed
2020 RAM 1500 Limited 5.7L
Augusta, Georgia
5 minutes ago, Wayfinder said:
Will do.
It will make me feel good after ordering new tires for Wayfinder.  😞
We are at site F50.
Thanks!
Patriot🇺🇸
Well, I am currently camping for the 3rd time in two years, (and twice in two weeks) and now testing weather or not I will like NOT having a bulb seal on the trailer.  So far with a light drizzle it's no issue.  But I also have gutter guards all around.
I am wondering if I'd like gutter guard under the awning mount, leaving a sizable opening between the gutter and the bottom of the awning mount.  It might be a nice compromise.  But, no rush.  Critical thinking and testing to do in the mean time.
Still adding pics to Album, but again, it's raining.  Doesn't look like any astrophotography practice tonight.  LOL
Album so far: https://photos.app.goo.gl/nkozxUcsgrfPp9YeA
The attach pic is showing the rain tripping down over window gutter and showing there's no bulb seal over head.
Chris
Augusta, Georgia
Its hard to tell from the pic above and/or the Google pics but particularly in the rain the awning should be slanted such that the rain can more easily run off and not "puddle" on the awning itself.  Usually the low side of the slant would be at the end closest to the rear of the camper.
Did that for four years and ended up with a trapizoidal shaped awning cover that eventually would barber pole foreward and required replacement.
I no longer slope the canopy away from the entrance door.
On 5/2/2023 at 8:19 AM, Wayfinder said:
I was even considering my left-over gutter guard in lieu of the bulb seal.  That way heavy water, and wind, could still pass thru under the awning mount, yet light to moderate rain could be channeled via the gutter guard?  I'll do some critical thinking on that one.
I am in the process of re thinking all this as well.  Going to take my bulb seal off too.  I believe in some cases like mine Oliver installed it tight against the awning and in others like mine left a small gap. (bad installation)  Debris definitely get stuck in there.  I like your idea of installing gutter guard below say about 2 or 3 inches.  You could even have a high point in the middle gradually sloping down to front and back.  Nothing would get caught up top in a hard to reach area either.  The other thought I had was installing a new bulb or the gutter guard (or something similar) up top in the valley between the top and the awning cutting sections to fit in between the mounting brackets so it would be flush with them for a smooth path.  Also on the brackets, mine are just L brackets with no middle piece to drill a hole through so that is not a problem.
Phil Drye
Hull #246, 2017 Elite II
I find this a very interesting thread, with lots of neat ideas. OTH, I am sorry you guys have to deal with this “rain” stuff. 😉
Because you rarely have rain???
We have 40+ inches a year..
Regarding the installation/attachment of a "gutter guard" or any other adhesive attached items. It was my understanding that if you have  had a ceramic coating applied to  your Oliver adhesives/stickers/decals will not remain attached very well. This was told to me by the company that applied my ceramic coating.
Is this a common understanding?
Yes, it makes sense. You need to remove the coating mechanically where the seal will attach.You probably should contact the company that applied it to see if they have any information that would help. Unless you arme super talented at detailing, I suggest that you hire a pro.
https://avalonking.com/blogs/tips-advice/a-guide-to-removing-ceramic-coating-from-your-car
