Backup Camera Location
I have a Voyager back up camera and monitor that I use with my truck camper.   The Ollie we are buying doesn’t have that option, and I’d like to have one.  Cameras are available for the system, and I am thinking about placing one on the rear cargo box, with the ability to move it to the spare tire cover.  Power would be from the running light circuit.
Has anyone located their camera there?  Thoughts?
Hull #364 - The Roadrunner
2023 F350 CCLB SRW 6.7L
Yes - my first rear camera was/is located in the spare tire cover.  There are a couple of issues - mounting and rainy weather.
Mounting - the spare tire cover is not perpendicular to the ground.  Actually it is off by 6 degrees.  So if you mount the camera without making any adjustments to account for this, the camera will be pointing too far down towards the road.  If you compensate for the entire 6 degrees you will probably find that the camera is now pointing too high.
I made a "puck" out of a material called Delran (similar to nylon) that is easy to work with and cut it at a 4 degree angle.  Thus when mounted on the tire cover you obtain a net 2 degree downward view which is about perfect.
The second issue is rain.  With the camera mounted in this relatively low position (versus the "normal" roof mount), the camera gets more road spray in wet weather.  However, when it is not raining the I prefer this lower view for backing into campsites.
A third issue with the lower mounting position is in heavy traffic you can not see as far behind you because the guy on your bumper blocks most if not all of the view.
Given the above - I now have two rear cameras.
Up as high as possible is best!
https://olivertraveltrailers.com/forums/topic/1973-how-to-install-a-garmin-bc-30-backup-camera/
You want to be able to view any cargo hanging off the back, as well as down the road.
1 hour ago, Wandering Sagebrush said:
The camera my system uses is adjustable up and down, it’s similar to this.
I didn't use this type of camera mount because the camera is within reach of passersby.  That means that anyone can tamper with it and/or can get "snagged" on it with clothing and/or other things.
I mounted my Ford backup camera on the spare tire cover.  It is integrated into the Ford surround truck camera system. It works well in that location, though if I were to carry bikes it wouldn't be so great.  Its probably better up higher, but I didn't want to drill into the trailer to mount it and it was easy to run the Ford cable under the trailer and up to the top of the spare tire cover and keep it concealed.  I couldn't do that for a higher mount, at least not within my limited ability.  On the spare tire cover, the view is great, you just have to keep it clean, as it picks up more dust than a higher mount.  It's easy to reach to just wipe off the camera lens.
2016 Oliver Legacy Elite II.  2021 Ford F250 Diesel
I did the same with my factory Ford camera this past weekend. I really don't plan on using the camera while traveling, just when backing into a camp site. Before backing in I will always park the rig on the road at the site and walk the site down before backing it. When I do this I'll make it my routine to wipe off the camera to prepare for backing in. The Ford camera has a very wide angle view so it allows you to see directly behind the trailer as well as several feet on each side of the trailer. That combined with the side mirror cameras you have a complete view when backing into the site.
States Visited Map
We use our Oliver back up camera and large TV mirrors mainly to monitor traffic and lane clearance behind our Ollie when traveling. It also allows me to keep an eye on our bicycles on the 1 Up rack. I have noticed most vehicles don’t tailgate us as they think they are on video.
It seems to keep most of the tailgaters at bay in my experience. I don’t think I have ever actually used it to back into a campsite. All said, I am spoiled, I cannot imagine not having the Oliver installed high mounted back up camera while traveling.
Patriot🇺🇸
The factory mounted all seeing  👁️
  • Haha 2
North Carolina 🇺🇸
JD:  I like your tree guard!  I have had my RVC antenna whacked more than once.
