HDRider Posted September 14, 2023 Posted September 14, 2023 This will be my first Oliver winter. I want to use the camper through the winter to visit warmer climes.  Does an Oliver need to be winterized if it is plugged into shore power and the furnace is on? Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Dave and Kimberly Posted September 14, 2023 Posted September 14, 2023   You didn't say how low of temps you were talking about or if you were going to be living in it or just storing it until you do "visit warmer climes"... but I'd say, with the furnace on and plugged into shore power you should be good down into the 20's.  The weak point would be the outside shower faucets, due to their exposed position and of course any water hose connected to the city inlet port.    There will be some that have experience at lower temps but I'd be concerned with that unless I was actually living in it at the time to be monitoring things.  For what I am guessing would be intermittent trips... and being stored at home with furnace running you should be good into the twenties.  More than that, I would just learn (if you haven't already) how to winterize it.  It's not a difficult process to winterize/de-winterize and then you would be protected without having to run furnace/aging the systems... while it's not being used. 2 2022 Elite II, Hull #1097 Elli Rose 🌹 and she has the solar panels with the 390Ah lithium batteries. Our tow vehicle is a 2025 Ford Lariat F-250 Super Duty 4wd, 6.7L Diesel with the Max tow package. Elli Rose also has the street side awning and several walnut and cherry mods on the inside.     Â
Moderators Mike and Carol Posted September 14, 2023 Moderators Posted September 14, 2023 It depends on how low your temperatures get and how long they stay there.  I’ve never winterized because we also camp year round.  It routinely gets into the 20s where we live (San Antonio area).  Keeping the heat on and opening the inner hull hatches keeps things from freezing. We occasionally dip into the teens and even single digits and when that happens I open all the inner hull hatches, run the furnace, and have a couple of small electrical heaters - one in the basement area and one where the water pump and all those water lines are.  It’s usually only 2 or 3 days once a year. Mike  1 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins Â
Wandering Sagebrush Posted September 14, 2023 Posted September 14, 2023 It’s a judgement call that depends on the depth and length of cold, and how risk tolerant you are.  As mentioned above, it’s not that difficult to winterize and de-winterize a camper or trailer.  Oliver with the boondocking connection at the rear makes it easier than most.  Don’t forget to get antifreeze in the drain traps. 1 1 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Rivernerd Posted September 14, 2023 Posted September 14, 2023 2 hours ago, HDRider said: Does an Oliver need to be winterized if it is plugged into shore power and the furnace is on? The answer to this question depends, to some extent, on how recently your hull was manufactured. Our late 2022 Hull #1291 with the Truma Varioheat furnace can withstand colder outside ambient temps than earlier models because Truma required a redesign of the duct system that includes a return air vent between the bathroom and the under side of the front dinette seat. See photo below: This return air vent enables distribution of more heat to the underbelly of the trailer, providing some additional thermal protection to the plumbing. Your Hull No. 1423 probably does not have the Truma Varioheat, and, therefore, does not have the updated ducting. The thread below contains lots of information about the performance of Olivers of various ages in cold temps: There are adjustments and mods you can make to help the plumbing system better withstand cold temps. The easy one is removing the outside faucet head and re-installing it on the inside of the hull (underneath the street side bed) when camping in cold temps. I have added some additional return air vents to improve circulation of warm air through the otherwise isolated parts of the trailer. See photos below: The bottom line: the plumbing will not freeze in any Oliver, with the furnace running, down to temps in the high 20's. To be able to use the trailer without winterizing at temps below that level, take the steps detailed here, and in the thread embedded above. Good luck! 1 4  Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Wandering Sagebrush Posted September 14, 2023 Posted September 14, 2023 After a more thorough reading of the posts in this thread, I’m even more in the camp of winterizing, and keeping it winterized until traveling into consistently warmer temps.  The dead air spaces issue, definitely caught my attention. I do have a question about the capped toilet water supply line (we have a composting toilet).  Does the line adequately drain when blowing out the system, or would it be best to uncap the line and let the forced air push residual water into a towel?  Inquiring minds need to know.😊 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Moderator+ ScubaRx Posted September 14, 2023 Moderator+ Posted September 14, 2023 1 hour ago, Wandering Sagebrush said: After a more thorough reading of the posts in this thread, I’m even more in the camp of winterizing, and keeping it winterized until traveling into consistently warmer temps.  The dead air spaces issue, definitely caught my attention. I do have a question about the capped toilet water supply line (we have a composting toilet).  Does the line adequately drain when blowing out the system, or would it be best to uncap the line and let the forced air push residual water into a towel?  Inquiring minds need to know.😊 I admit that I have no direct knowledge of how much that particular line would drain under the circumstances you describe. Compressed air will quickly displace water pushing it the line if the air has an escape route. I've found the best method of evacuating water for the plumbing is to use the on/off method. I usually use about 40 pounds of air pressure. Apply pressure to the lines with all taps open. At first, a good bit of water will flow out. When it has reduced itself to a sputtering gurgle, cut it off and wait a few minutes. This will allow the residual water to run to the low spots and pool. Turn the air back on, water will come out the second time but not nearly as much. Repeat this several times until you've gotten the bulk of the water out. I doubt you could ever get it all out but that's OK. In the case of a closed end line (as with the composting toilet) I believe it would drain out just fine, but if I were worried about it, I would replace the cap with a valve that I could open during the blowing out process and then close again. If you wait until the last stages of the above process, you'll only have a small amount of water from the valve that you have to deal with. 3 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4      Â
HDRider Posted September 14, 2023 Author Posted September 14, 2023 5 hours ago, Dave and Kimberly said: outside shower faucets Where do I turn off the water going to the outside shower?   It seems like I should be OK (someone correct me if I am wrong) if I turn off the water to it and drain the water out. I assume I can drain it by simply turning off the outside shower water source and open the shower spigot until no water comes out. Is that right? Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
HDRider Posted September 14, 2023 Author Posted September 14, 2023 5 hours ago, Mike and Carol said: It depends on how low your temperatures get and how long they stay there.  I’ve never winterized because we also camp year round.  It routinely gets into the 20s where we live (San Antonio area).  Keeping the heat on and opening the inner hull hatches keeps things from freezing. We occasionally dip into the teens and even single digits and when that happens I open all the inner hull hatches, run the furnace, and have a couple of small electrical heaters - one in the basement area and one where the water pump and all those water lines are.  It’s usually only 2 or 3 days once a year. Mike  I assumed running the furnace would heat below deck.  I am trying to go from assuming to knowing. 🙂 1 1 Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
HDRider Posted September 14, 2023 Author Posted September 14, 2023 3 hours ago, Rivernerd said: Hull No. 1423 probably does not have the Truma Varioheat The manual of standard equipment says I have the Truma Varioheat Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Moderator+ ScubaRx Posted September 14, 2023 Moderator+ Posted September 14, 2023 31 minutes ago, HDRider said: I assumed running the furnace would heat below deck.  I am trying to go from assuming to knowing. 🙂 The furnace will heat below deck. You can enhance that by opening some forward hatches to get warm are from the coach into areas that are further from the furnace. 1 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4      Â
rich.dev Posted September 14, 2023 Posted September 14, 2023 (edited) 5 hours ago, Rivernerd said: Hull No. 1423 probably does not have the Truma Varioheat If your hull # 1291 has the Truma Varioheat then @HDRider newer hull #1423 should have it if they opted for it. ***Edit: and scrolling down the posts I see they do have the Truma Varioheat Edited September 14, 2023 by rich.dev **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Moderators topgun2 Posted September 14, 2023 Moderators Posted September 14, 2023 2 hours ago, HDRider said: Where do I turn off the water going to the outside shower?  As far as I know - No Oliver is equipped with a valve that can stop water from getting to the outside shower unless the owner has made a modification to the original plumbing. You can always add extra insulation to that area from the inside and/or the outside which will add extra protection. Bill 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted September 14, 2023 Moderators Posted September 14, 2023 3 hours ago, HDRider said: I assumed running the furnace would heat below deck.  I am trying to go from assuming to knowing. 🙂 We’ve had single digit weather twice since 2016.  When it gets below 10 for a few days I supplement the furnace with small cube electric heaters to help with the lines that run from the water fill/outside shower area around the back to the hot water tank and pump area.  The furnace doesn’t have any ducting there.  I do have my basement door insulated so that helps.  Mike 1 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins Â
Rivernerd Posted September 14, 2023 Posted September 14, 2023 2 hours ago, HDRider said: The manual of standard equipment says I have the Truma Varioheat My oversight. Glad you've got the Varioheat, which means you should have the return air vent from the bath to the underside of the front dinette seat. Our tests last November suggest that, with the Varioheat running to maintain cabin temp at about 70 F, and with the external faucet removed from the hose and re-installed to the hose through the access under the street side bed, the -plumbing in your Elite II should be protected from freezing with outside temps down to about 15 F. As noted above by Mike and Carol, a small electric space heater placed under the rear dinette seat blowing aft can make a big difference keeping the "bilge" areas where the plumbing is located warm. As we like to leave the bed made up in our standard bed Elite II, we prefer the space heater method to leaving the hatches open to allow warm furnace air to circulate. 1  Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Moderator+ ScubaRx Posted September 15, 2023 Moderator+ Posted September 15, 2023 7 hours ago, topgun2 said: As far as I know - No Oliver is equipped with a valve that can stop water from getting to the outside shower unless the owner has made a modification to the original plumbing. You can always add extra insulation to that area from the inside and/or the outside which will add extra protection. Bill I added two motorized valves to the water lines going to the outside shower. I also added an air line to each water line with check valves (to prevent water from back-flowing into the air lines) to facilitate blowing the lines clear for winterization. The air line runs to the front of the trailer to a quick connect. I can use either the compressor system in the Silverado or a compressor at home.  I also re-built the outside shower and dump valve box.  Here is one of the motorized valves with the air connection prior to installation.  Here's a look at the control station mounted in the basement.  4 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4      Â
