Ronbrink Posted March 19 Posted March 19 10 hours ago, Geronimo John said: Thank you Geoff. I will be adding three likely so it would not work well if they are not matching to the OEM. I do appreciate your suggestion. I do agree that the OEM ones are not the best for their intended purpose though. If the OEM ones are no longer available, I may just bite the bullet and replace them all to match. $$$ though.... GJ I’m hooked, have a dozen of these throughout the Oliver! Easy to install; they stay put for the most part; and great for hanging equipment, clothing, towels, hats, bags, you name it. I just twist the suction knob occasionally to maintain a tight hold. Here’s a few examples: 1 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators topgun2 Posted March 19 Moderators Posted March 19 Is THIS the post you were looking for? Bill 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
rich.dev Posted March 19 Posted March 19 (edited) 2 hours ago, Ronbrink said: I’m hooked, have a dozen of these throughout the Oliver! Yes love these Hasko vacuum suction cups, we also have a dozen or so all over inside the trailer, including below the street side bed for shoes…wife’s idea! Edited March 19 by rich.dev 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Ronbrink Posted March 19 Posted March 19 5 minutes ago, rich.dev said: Yes love these Hasko vacuum suction cups, we also have a dozen or so all over inside the trailer, including below the street side bed for shoes…wife’s idea! Wonderful, need to place another order! 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
David and Gail Posted May 12 Posted May 12 I just removed a Hasko suction cup hook and found a brown stain ring on the fiberglass. This caused me to remove another one in the bathroom and it also left a brown ring of stain. I tried several methods of removing the stain. Got most of it off, but you can still see a faint circle if you know where to look. Has anyone other than me had this problem? As for now these will not be going back up. 2018 Ram 1500, 4x4, 5.7 hemi , Anderson WHD 2025 Oliver Legacy Elite ll, Hull # 1585,Platinum pkg, Twin bed floor plan, Street side awning option
Moderators topgun2 Posted May 12 Moderators Posted May 12 David & Gail - If these marks really bother you then I think that you have basically two choices: 1 - Make an appointment with the guys at CGI detailing. I certain they can get it better than new for you. 2 - Polish it our yourself. If you want to go this route (I would) I'd suggest starting with a fairly light polish such as Meguiar"s Ultimate Polish - THIS STUFF. If this doesn't do the job then I'd up the ante to something like Shurhold Buff Magic Compound - THIS STUFF. I believe one of these two will allow you to buff out this stain by hand. After you polish apply protection to the surface with the wax of your choice. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderator+ ScubaRx Posted May 12 Moderator+ Posted May 12 Use some acetone, it won't hurt the gelcoat and I'll wager the stain will come right off. I use it all the time. Will also remove mildew stains from caulk. 6 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
David and Gail Posted May 12 Posted May 12 Thanks, I will try some of those. 2018 Ram 1500, 4x4, 5.7 hemi , Anderson WHD 2025 Oliver Legacy Elite ll, Hull # 1585,Platinum pkg, Twin bed floor plan, Street side awning option
Jason Foster Posted May 12 Posted May 12 I have some Star Bright black streak remover scheduled to arrive from Bezos on Wednesday. That stuff works miracles on stubborn stains on fiberglass. I'm sure it will work on that. 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
ScottyGS Posted May 13 Posted May 13 If you don't have acetone you can try a bit of WD-40 or other penetrant. You shouldn't need much. Spray a dime size on a rag and rub where the marks are. Then wash and put a bit of wax on. Most penetrants use some type of solvent to help it flow into cracks and such and it's the solvent that will clean just about anything. 2 Gregg & Donna Scott and Missy the Westie - The Flying Sea Turtle - 2016 Hull # 145 2024 Nissan Titan XD - Western NC
