jd1923 Posted January 31, 2024 Posted January 31, 2024 Any of you getting to know me as a new Oliver owner, might have noticed I'm not the conforming sort! So, we wanted better cell reception, had the Verizon MiFi before, OMG how do you actually connect an antenna to that junk? Hate Verizon too, but they historically had the best coverage in the west (AT&T is weak out here). Did some research and came across: Mobile Internet for RV & Boats - Unbiased News, Guidance & Education - Mobile Internet Resource Center (rvmobileinternet.com) After hours of more study, we found: Speed Demon Mobile Internet Bundle – MobileMustHave.com and ended up purchasing this bundle. There is a thread here of an amazing installation on the rear of the Oliver: Pepwave Cellular Router Installation - Ollie Modifications - Oliver Owner Forums (olivertraveltrailers.com) Thank you @Wildbrew Great work, but fabricating a platform, a permanent installation on the roof of the Oliver? It's not for us. We do not travel with the Oliver enough for this to be worthwhile. Thinking not only about the HW costs, but ongoing costs of data plans, I needed something not only for camping, but as a backup to my business. Then I found out that T-Mobile has 5G in much of Arizona, even in our small town and more 5G coverage than the rest. The other thought that concerned me is out here in Arizona and the West in general is the elevation ups and downs, the canyons where we often camp. Why not consider a truck (TV) mounted solution? Often, like last week where we camped at Burro Creek, there was no cell service, no broadcast TV, no AM/FM, nothing. However, when we drove up to the highway we got a signal. Of course, when you drive the truck down the road, you cannot stream TV in the Oliver, but you can make calls, deal with an emergency and get on your laptop to receive and send emails. I had the installation finished last weekend. I paid an extra $49 for MobileMustHave to configure the router, and they finished up this morning. Got a new T-Mobile Business account setup in the last few days and everything came together today! The Okla Speed Test came in at up to 242 Mbps download and 26 up, numbers likely much better than many have at home. 2 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators mossemi Posted January 31, 2024 Moderators Posted January 31, 2024 Chris and Cherie of Technomadia and Mobile Internet Resources were early Oliver Elite owners. They moved from a Tab to an Elite before OTT's temporary shutdown and the sold it and moved to a large RV. They are a great resource for mobile connectivity. Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Steve Morris Posted January 31, 2024 Posted January 31, 2024 11 hours ago, jd1923 said: After hours of more study, we found: Speed Demon Mobile Internet Bundle – MobileMustHave.com and ended up purchasing this bundle. I bought the same package in November 2022 during the holiday sale, even before we had our trailer. Mine is mounted in the trailer's attic, but I'm still using the stub antenna. I have the same external mount as you, but just haven't drilled that big hole yet. I'll be mounting mine on the pole mount, but mine will be on thereat awning bracket instead of using a pole. 2 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
jd1923 Posted January 31, 2024 Author Posted January 31, 2024 1 hour ago, Steve Morris said: I have the same external mount as you, but just haven't drilled that big hole yet... Now that I have this installed in the TV, there is no way I would want it installed in the Oliver. No drilling for the antenna, no 7x7 ft of cable in the attic, and a stronger cell signal to boot. I also use my truck around the county pulling dirt bikes for a day trip and drive 3-4 business trips annually without the Oliver. Now we have Wi-Fi on board everywhere. Works well with the diesel engine running, maybe because it sits much higher. Chris can use high-speed internet while I'm driving. Yours has been sitting in your attic for 1 1/2 years (had read your earlier posts) and perhaps this year is the time to do it right! You need to make your mount so that it would sit above the A/C and btw running the air may cause some electromagnetic interference to the signal. They say the Parsec Husky is the BEST cellular antenna and that it does not require a ground plane but would benefit from one. No better ground plane than the steel roof of an extended cab pickup truck! The magnet mount sits tight, just drop it in place. I placed a towel under it until I was sure of position to make it easier to move. With this install all was required was a 1 1/2" square hole in the back panel of the cab behind the rear seat. No Dicor necessary, no caulk, the rubber grommets and housing seal on the Icotek cable entry solution is all you need. I used speed clips for the 4 small bolt holes and 3M VHB tape to mount the Pepwave to the truck cab back wall. Not just Wi-Fi at your camp, but anywhere and everywhere you drive. I can get caught up on work on my computer, while Chris is grocery shopping, or when we are parked at a restaurant! Think about that. 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted February 2, 2024 Author Posted February 2, 2024 Drove the TV today to fill an LP tank for our upcoming camp. At a stoplight I thought why not run "Speedtest by Ookla" again, but this time while driving. Pulled up the app on my phone (phone Wi-Fi connected to the onboard Pepwave router with T-Mobile Business Premium 5G service) and clicked go as the light turned green. The test was bouncing from here to a T-Mobile server in North Las Vegas. Checked the readings when I stopped for LP. While driving in traffic at 40 MPH I was getting better speed (132 down) than the 100 Mbps service most of America has at their homes. I'm not seeing the 5G symbol on my phone in this area but have in other parts of Prescott. Is 4G capable of this download speed? On the way back it just started pouring rain for a few minutes. Tried the Speedtest in heavy rain and speed dropped down to 40 Mbps, still quite acceptable. The new tires felt good in the rain too. It's a rare case getting a rain test down here! There certainly is 5G service in many parts of valleys of Yuma, Quartzsite and the West Valley of Phoenix, where we will travel next week. I will report on how this worked after our next road trip. You got to get one of these! 😂 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators mossemi Posted February 2, 2024 Moderators Posted February 2, 2024 21 hours ago, jd1923 said: I'm not seeing the 5G symbol on my phone in this area but have in other parts of Prescott. Is 4G capable of this download speed? When I was a working man, the best 4G download speeds I ever saw was 78 Mbps. I never see a 4G or 5G signal strength reading while connected to WiFi on my iPhone. Try turning WiFi off and then check your 'bars'. Mossey Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderators SeaDawg Posted February 2, 2024 Moderators Posted February 2, 2024 This is my 5g speed, outdoors, a few minutes ago, on my 5g s23+ samsung phone: 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators SeaDawg Posted February 2, 2024 Moderators Posted February 2, 2024 Indoors, I fluctuate between 4g and 5g, metal roof, uv protection windows. This was 5g. Verizon. Indoors. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators SeaDawg Posted February 2, 2024 Moderators Posted February 2, 2024 I thought the first test was crazy, so I tried it again. Outdoors. 5g verizon. So, for now, we'll just continue with my phone, as a hotspot. We don't "work" anymore. Just need a reliable connection. So, we carry both Verizon and tmobile phones. Most of the time, if there's a signal to be had, we get one. Your setup is definitely better for mobile work, I'm sure. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
jd1923 Posted February 3, 2024 Author Posted February 3, 2024 5 hours ago, SeaDawg said: This is my 5g speed, outdoors, a few minutes ago, on my 5g s23+ Samsung phone: @SeaDawg thanks for this data! Are you in Florida now? The Sunshine State with 8,400 coastal miles, 66,000 square miles of line-of-sight flat land and 22M people, mostly cell phone customers? I know you go to a Carolina home often, but likely not in February and I'm not aware of your Florida location. You should expect these numbers in major metropolitan areas. Prescott is in Yavapai County AZ (population only 240K). Our county is almost the size of the state of New Jersey which has 10M residents, or more if you count the illegals. 🤣 It's amazing to get these speeds up here, at 5400 FT altitude, in the mountains! I was running errands today and noticed the 5G symbol at one point on my phone. Ran the Speedtest and got 332 Mbps! Last year with AT&T we'd get 10% of this speed on our cell phones. 2 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Steve Morris Posted February 5, 2024 Posted February 5, 2024 On 1/31/2024 at 11:12 AM, jd1923 said: Not just Wi-Fi at your camp, but anywhere and everywhere you drive. I can get caught up on work on my computer, while Chris is grocery shopping, or when we are parked at a restaurant! Think about that. That's a good solution with the pickup. But I'n not going to mount that white antenna on the top of my black Land Cruiser. And there's no good way to get the wires in. I tried solar wires on my similar 4Runner, and ended up coming in the door seal. There's just not a good location on an SUV. ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
jd1923 Posted February 6, 2024 Author Posted February 6, 2024 On 2/5/2024 at 10:13 AM, Steve Morris said: That's a good solution with the pickup. But I'm not going to mount that white antenna on the top of my black Land Cruiser. And there's no good way to get the wires in. I tried solar wires on my similar 4Runner and ended up coming in the door seal. There's just not a good location on an SUV. Should have got the black Parsec Husky! 🤣 I understand given our black GX470, but then I tried towing our EII with it and for me the platform was not stable of strong enough in mountain terrains, so we bought the white Dodge Ram 2500 Cummins. If I was to install one in this SUV. I'd likely run the antenna cable by cutting into the rear spoiler where there is a harness already for the rear center brake light, with lots of room for the router behind the side panel in the RR quarter panel (I was back there last year running rear camera wires for a new Kenwood head). These can be too pretty for an antenna, but the roof rack would hide most of it. We're on the road this week and the Pepwave router is working great. It sends a strong Wi-Fi 5GHz signal throughout the Oliver, even 20 feet behind it, and everywhere around the campsite! Good thing we don't own AS trailers. I understand inside those tin cans you need to run a wired Wi-Fi Access Point since a roof-mounted antenna broadcasted Wi-Fi signal will not penetrate the metal hull. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Steve Morris Posted February 6, 2024 Posted February 6, 2024 Yep, the GX is a great vehicle, but not for towing the LE II. The LX is actually better than my Land Cruiser, due to the self leveling system and height adjustment. No need for the Firestone airbags with the LX. 2 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
jd1923 Posted August 27 Author Posted August 27 (edited) While traveling we've used our Starlink Mini often. Though more often with cell coverage we are able to use our our T-Mobile 5G SIM on our Pepwave router. I have also used the Pepwave with 5G service as a backup to our home network. Twice while teaching, in the last two years, our Sparklight service has gone down, and I've logged into the Pepwave Wi-Fi to continue the Zoom class sessions. Over the last two years, 5G service in our neighborhood has gotten better/faster. I decided to cancel our home cable service which has grown in cost from $40/mo eight years ago to $86/mo lately for 300 Mbps service. I've worked out a complex installation that allows us to be logged into the same Home Network whether we are physically at home or on the road with the Oliver! To date we have only used the Starlink powered by battery, connecting via Wi-Fi using the built-in Starlink Router. I just finished a more complete installation where we have the Starlink powered by 12-24V DC-DC charger (thanks Geoff) and connected by Ethernet cable to the WAN port of the Pepwave. This will start to get technical for many of you... Internet connection comes into Pepwave router by means of the Parsec 5G antenna (priority #1) or when needed by the Starlink Mini via the Pepwave LAN input. The Pepwave can if needed also share bandwidth between WAN connections for greater overall speed. The Pepwave router will also broadcast Wi-Fi but like any Wi-Fi broadcast it has distance limitations. The Wi-Fi coming from our truck installation by itself will not pass through the garage and the walls of our home to the other side of the house or our lower level where it's half underground. But it does fine more than 100 ft radius around any campsite. At home, we've been using a Wi-Fi 6 Mesh network, a main with two satellite routers to cover all the area on our 3/4 acre property. Including the Oliver which is parked 100 ft away! Now that we're not using a home-based modem anymore, I thought "How could I repurpose this system connected to the Pepwave?" I installed the Mesh Wi-Fi main unit in our truck connected by ethernet cable to a LAN output of the Pepwave. It's so cool that when I read the label on the 120V power adapter for the mesh unit, the output was stated at 12VDC 3.5A which means all I had to do was to cut off the adapter and connect two wires to the 12VDC in the truck! I mounted it in the back window behind the rear bench seat, behind the driver's head. Out of sight when driving and good line-of-sight out the rear of the truck. Where our truck is parked most of the time, backed into the driveway, the mesh satellite in my office also has line-of-site to the main. Our "Home" network is getting 300-400 Mbps down and about 20-50 up from this installation, 5G cell through the cell antenna on the truck! I then parked the truck in the garage where the Wi-Fi signal must travel through 3 walls. We could still stream TV at about half these numbers. Half speed is also about what the Starlink Mini delivers day-to-day. Yeah, good 5G service is 2-4 times faster than the Mini. I've canceled our cable Internet service. The savings of $86/mo in two years will pay for everything spent in this installation; the Pepwave and antenna, the Starlink Mini and accessories, the converters and cabling, etc. Now here's the real kicker! 😎 I setup a home network on the Wi-Fi mesh. We have all of our laptops, cell phones, network printer, TVs etc. all connected to the same "home" network. We also have the TV in the Oliver on the same network. Regardless of whether we are home or away the network login is constant so no need to reconnect ever to another Wi-Fi. If we need Starlink, when traveling, or for emergencies when at home and the cell network is overloaded, just mount and connect the Starlink Mini and it feeds the same home network. If we wanted to connect to a public or friend's Wi-Fi we can also input that to the Pepwave "Wi-Fi as WAN" so it becomes the Internet source for our home network. It's a lifetime, seamless setup! 🤣 So, you might be thinking a router with antenna, the Starlink Mini and a Wi-Fi Mesh could pull a bit of power from your truck starter batteries. Yes, and it will over time. Earlier I had installed a 100W Renogy flexible solar panel on our truck toolbox along with a small 15A Victron MPPT SC. This small solar setup always keeps our truck AGM batteries to 13V+ and powers everything listed above. It also has ample power for our Dometic CFX5 45l fridge in the truck bed! 😎 One exception is when I have the truck parked inside the garage for more than a couple days. So then I connect a battery charger, quick connect leads already installed above the front bumper. I got done yesterday as the sun was setting and this picture shows it all. Notice the Starlink Mini mounted top right with the small blue power light on. You can see the Renogy panel on the toolbox, the SC is installed inside with outputs to battery and the fridge in a separate circuit. You can see cable looms, going up to the antenna and to the Starlink running across the box. The Mini is removable but the cabling stays. If we ever camp where the Northern sky is blocked where the TV is parked, then the Starlink would be mounted elsewhere, Starlink Wi-Fi login, powered by battery again. We find this is a rare case where we camp most of the time out West. The Pepwave install was shown earlier in this thread and is behind the rear bench seat below. Lastly, notice the blue light in the truck rear window. This is the Arris Mesh. I had purchased this mesh network 6 years ago, so it was great to reuse it, no cost. If I was to purchase new today there are better and smaller products available, though this system as a whole works great. We've got more installed in our tow vehicle than most have in their homes and RVs put together. What a great upgrade! 🤣 Edited August 27 by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Wayfinder Posted Monday at 06:32 PM Moderators Posted Monday at 06:32 PM @jd1923 I'm going to be keeping things as simple as possible when I travel all around that nation soon. I'm hoping just having a Starlink mini will be good enough. Naturally trees as obstructions will kill the Starlink performance. My first thought when I see all the cool things you've done with the cellular booter and stuff is.... "No! I'm doing all that. I just retired from my IT job." Give me all the bad things I'm not thinking about. Maybe I bring some old DVDs, books, and cuddle more with the woman. 😉 Chris o-o 2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110" o-o 2024 Ford F-250 Lariat, 7.3L Godzilla gasser o-o Augusta, Georgia
jd1923 Posted Monday at 07:51 PM Author Posted Monday at 07:51 PM (edited) 1 hour ago, Wayfinder said: My first thought when I see all the cool things you've done with the cellular booter and stuff is.... "No! I'm doing all that. I just retired from my IT job." Chris, didn't I just read you have 122 days left. Yeah do it now, get all of your "IT" work done before you retire! 🤣 Many of my installations are complex. One thing about me, is I'm not afraid of work. I like to work extra in preparation so that we have less work while traveling and when camping. I design systems to minimize the need for campsite setup/tear-down, maximizing time away enjoying our travels! We've been fortunate that in 3 years and 188 overnights to date, my Maintenance & Repair and Mod efforts have all been done at home where I have the time and tools (again, knocking on that large chunk of wood, my forehead)! We add to the to-do list but do not work the list while camping! 😎 This Wi-Fi setup is complete and never again will we need to change the Wi-Fi source on our phones, laptops, TV screens or anything else while traveling or at home. We are connected while towing, at any rest stop and when we first get to the campsite while others are connecting to slow campground Wi-Fi, asking about and entering passwords, setting up their poles, running wires to boot their Minis, we're not even thinking about it. Our systems are always ready, up and running! Should we rush to plug-in? No, first we lay out the camping carpet, get out two camp chairs and make a drink! 😎 Already leveled with the LevelMatePRO, we have 900 Ah power, 35-gal extra water, Inverter and Internet always running, the A/C running has the cabin cooled while towing, and all is ready even before we arrive. No hurry, I may not plug in until the day we're leaving if we need a charge that the DC-DC charger will not handle on the road. Refill the fresh tank, dump waste tanks and we're ready for another week away. Easy on the road only stems from good planning and prework. I love Pareto's Law, the 80/20 rule! I'd say 80% of the time our 5G setup will suffice for campsite Internet connection and 20% of the time when cell coverage is weak, it will take 2 minutes to add the Starlink Mini. Either way, all Internet sources feed the Wi-Fi devices already set to our Home Network. I believe it's worth the trouble and now we're saving lots of money not needing home Internet service. Edited Monday at 07:55 PM by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Wayfinder Posted Monday at 08:10 PM Moderators Posted Monday at 08:10 PM @jd1923 I'll drive out to see you soon enough. I'll bring your favorite ice cream and drink. 1 Chris o-o 2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110" o-o 2024 Ford F-250 Lariat, 7.3L Godzilla gasser o-o Augusta, Georgia
Moderators Wayfinder Posted Monday at 08:12 PM Moderators Posted Monday at 08:12 PM I'm also considering placing the Starlink mini on the cap of the truck, that way it's always available for the truck or camper use. But put it on a removable mount to find clear sky if under light tree-cover. Chris o-o 2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110" o-o 2024 Ford F-250 Lariat, 7.3L Godzilla gasser o-o Augusta, Georgia
DanielBoondock Posted Tuesday at 12:28 AM Posted Tuesday at 12:28 AM The few times so far when I had no connection was a blessing I have to admit 😅 2 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
Ronbrink Posted Tuesday at 01:42 PM Posted Tuesday at 01:42 PM 17 hours ago, Wayfinder said: I'm also considering placing the Starlink mini on the cap of the truck, that way it's always available for the truck or camper use. But put it on a removable mount to find clear sky if under light tree-cover. Take a look at Veritas Vans Starlink mounts, I have the magnetic mount version with bolt-on handle for the Mini and very pleased. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators Wayfinder Posted Tuesday at 06:01 PM Moderators Posted Tuesday at 06:01 PM @ronbrink Which flagpole and suction cups setup is that on the Ollie? Thanks, Chris o-o 2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110" o-o 2024 Ford F-250 Lariat, 7.3L Godzilla gasser o-o Augusta, Georgia
Steve Morris Posted Tuesday at 07:54 PM Posted Tuesday at 07:54 PM (edited) I’m not Ron, but I asked the same question before. It is from Flagpole Buddy, and you need the Airstream version with adjustable angle suction cups. They went on sale last Black Friday. https://flagpolebuddy.com/products/ols/products/airstream-suction-cup-mount-kit-g2-g3-g5-or-mini-adapter-poles-mounts-cable-clamps-pole-bag/v/106967-MN Edited Tuesday at 07:55 PM by Steve Morris 1 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Ronbrink Posted 12 hours ago Posted 12 hours ago 18 hours ago, Wayfinder said: @ronbrink Which flagpole and suction cups setup is that on the Ollie? Thanks, As @Steve Morris provided plus one extra 4’ pole section in my application. 1 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
