  2. Would Donna be amenable to sleeping outside? That way she wouldn't notice. Just Kidding..........
  3. Today
  4. Did you see the manual? It’s got over a dozen diagrams in it, I just did a snip of one of them. Most of the circuits are shown.
  5. Good observation and question! OTT installed an ANL fuse in our hull but only between B+ on the batteries and the inverter. They had a separate 8 AWG wire running from the batteries to the breaker in question for everything 12VDC. New batteries installed, the tech could have changed anything, moved the DC source after the OEM ANL fuse (that's what I did with our Victron inverter upgrade). Or maybe they installed a new one to protect new batteries. Did they install a battery compartment cut-off switch that failed or got turned off accidently? Yes, got to, got to test for voltage! First at the batteries. Then before and after the breaker. If an inverter is installed, is there 12VDC on the 4/0 wire at the inverter connection (after ANL fuse). Any 12VDC to the 12V side of the fuse panel at all? Batteries dead, switch turned off, main fuse blown, 60A breaker defective? It's one of these. Get a ground wire in place and this can be a quick find with the voltmeter. First time I've seen this schematic. Thanks for sharing. Too bad they don't show the important 12VDC stuff! They show the DC fuse panel in the attic but not the main 12V panel. They show all the 12V charging ports, USB ports, but none of the important 12VDC runs, to the fridge, the fans, furnace and all the stuff that matters. They don't share wiring diagrams since installations change often. OTT is a small batch custom house. They don’t have the development practices, nor the configuration management systems to automate publishing schematics annually. It’s a whole lot of bookkeeping otherwise and time better spent is in creating their/our beautiful fiberglass! Sure would be nice to have these main appliances diagrammed and what about all those light switches? 🤣
  6. https://olivertraveltrailers.com/oliver-university/ The best wiring diagram I can find is in the 2019 manual. See link to Oliver University. Many of us have appealed to OTT unsuccessfully for wiring diagrams. I saw a previous post from you that indicated you had LiTime batteries installed by a technician. Did they by chance install an ANL fuse or a circuit breaker? If so, that should be checked. What is the voltage of your batteries? It should show on your solar controller and also your See Level display.
  7. Yesterday
  8. The coldest we have camped is 15 degrees a few nights in a row. We opened the drive side basement hatch/lid in the dinning seat to allow warm air into this unheated area and ran a dehumitifier. Each day the temps were above freezing. In these conditions our Oliver preformed very well. We have never spent time below freezing 24/7 for running days. If we were to camp in below freezing day and night for an extend time as we are currently setup, we would to blow out the water lines, empty gray, black and fresh water tanks and use water jugs for our water source. Maybe 30+ years ago, I would have considered this a good time. Several Oliver owners have modified the weak areas of heating and or insolation i.e basement/outside shower, batteries and the bathroom trailer nose. Solutions I have read about in this forum are adding insolation, running heat duct down the drivers side basement from heating system and pulling the outside shower inside the hull. I believe Oliver's double hull gives you the best change to set up for true winter camping. I'm thinking there isn't such a thing as a full fuctioning true winter camping trailer ready to go off the showroom floor.
  9. First I’ll confess that I have no knowledge of how your trailer is equipped, or how it's wired. However, you have given enough clues to narrow it down: You likely have a 30 or 45 amp converter/charger that's an internal module of the 12 volt DC and 120 volt AC distribution panel. The 60 amp breaker is likely a direct feed from the battery to the converter/charger/distribution panel. It's no surprise you read 12 volts because it’s connected directly to the battery. The AC section of your distribution panel is probably fine because you have power to the microwave. The reason that the refrigerator and air conditioner aren’t working is because they need 12 volts DC for the controls and thermostat. Given all that, you likely have a blown internal fuse in the converter/charger, or a burned termination of the large red wire coming from the 60 amp breaker. Look in your documents for the converter/charger manual, it should show the fuse location within the module. Be sure to disconnect shore power and open the 60 amp breaker before poking around in there. Good luck, Geoff
  10. Unfortunately OTT installed this +bus under the bed and the -bus (ground) under the dinette and every Oliver is wired somewhat differently! 🤣 Checkout my picture below. Ignore the bottom half of the picture which is all stuff I installed, but the ground bus at the top of the picture. Notice the coiled up yellow/red-striped wire center of picture. This is a ground wire I added for testing. I leave it there just wound up, but unwound it's long enough to be a test ground for anything inside the cabin. It's a good tool to have ready. I made this recently to test for voltage at the water pump and switches when our water pump went dead (found loose wire on bathroom switch). Believe it not, for a quick test, you could use the foil covered insulation anywhere in the basement. Most of it is grounded, although it could be a weak ground and not show full voltage. Be careful with hot wires near this foil. If all your lights and jacks are not working, this breaker must be dead or there's no current coming into it. In the original installation of our Oliver, the converter was wired after the breaker. Actually, you can see it in the picture I posted above in my prior post. The wire coming in from the right came from the B+ battery terminal. Notice the red 8 AWG wire on the left post. It runs to the front connected to the 12VDC fuse panel and hence the PD converter that was integrated to the panel. Did you open the battery bay and test for voltage right at the batteries? Do you have 6 or 8 AWG wires connected at the batteries? Do these cables have voltage there where they start? Then you want to get a ground near your breaker and test there. I've read several posts re these breakers failing.
  11. i checked the 60A breaker by just checking to see is if i got a really low resistance value across it as i wasn’t exactly sure where i could get a good ground connection but you are right I do need to check the voltage. I am not sure if this 60A breaker is before or after the converter so if it was good or bad that would tell me about the converter. display lights and fan are on the converter so I am not sure if this says it’s good. . fuses are easier to replace than converters/inverters so when i get back home I will run up a ground wire directly from the battery ground terminal and use it to check for DC voltages. thank you for this.
  12. I was wondering if there is a wiring diagram somewhere. i don’t see it in the manuals
  13. If you have 12VDC at both ends of the breaker, the same breaker that has the 3 big yellow 30A fuses for leveler jacks, the jacks (unless all 3 fuses are blown) and the lighting should work. Something is not adding up. Test again to be sure that +12VDC is on the load end of the breaker, or recheck both sides. Picture below is from our older hull before I changed all that. Ours had a 40A fuse vs. 60A but yours should be similar. The source side is on the RIGHT in this picture where power comes from the battery. +12VDC there means batteries are working. Power on the LEFT post means the breaker is closed (working). You should also see power when touching any of the screws or the metal of this positive bus. Where are you connecting your voltmeter to ground? (battery negative) If the breaker is bad, you could bypass it until you replace it, since all the loads are fused individually.
  14. Yes, I agree—the VHB tape has excellent shear and tensile strength, and on some materials it can even be peeled away slowly when no longer needed, which makes it an even better choice.
  15. I fully agree with these comments but from where we live and travel, perhaps from an opposite point of view... Our 3 seasons are Fall-Winter-Spring. Summers we'd rather stay up here at 5400 ft because as soon as we drive an hour in most directions it's going to be hot. But this is also true: Summers here, even at elevation, I've measured our Oliver rooftop temps to 110F (Ruuvi sensor placed under shade of the solar panels). Inside cabin temps without A/C (windows cracked, MaxxFan and bath vent open), will be 20F cooler. We often run the A/C for the month of August while it's parked at home. Now that we have viable RV air conditioning, we're dabbling more into our 4th season, summer. Out west, elevation is a greater factor than being north or south. Summers we go up, like our July trip NW of Flagstaff at 7600 ft. We did use the A/C some afternoons. Winters we head down to The Valley, anywhere in SW AZ into CA is great winter travel, more than 1/4 million campers at Quartzsite! I would love to camp with our friend Steve and family up the the north central Midwest. We'd go for fall colors or during the spring, certainly not for their winters. 20F at dawn, we see that often. -20F all day long is not happenin'! Yep, I've read a few in our 3 years here. I've seen where the outdoor shower plumbing is removed and both battery and basement exterior access panels are fully insulated. I read another where the Oliver was used as a remote working vehicle where it was used as a dry cabin, all water removed, plumbing not used in a sub-zero climate. The double hull insulated, completely sealed underbelly, tanks within the hull, proper A/C and dual 30# LP tanks, if you want it to be 4-season it can be. But we're not camping in Phoenix summers or Minnesota winters.
  16. I have boondocked at the foot of the Athabasca glacier and on the shores of the Gulf of Mexico. I am NOT Bear Grylls. It’s that easy. I have also done weeklong stays in sub freezing weather, and triple digit heat with hookups. Even easier. YMMV, but Ollie is easy to use, safe and durable IMHO.
  17. Hunker down Greg and family and all of our Oliver Friends along the Gulf Shore!
  18. Very strange! The fresh tank expanded enough to bow the floor. It was holding pressure, for some period of time, long enough to after the fact use the kitchen faucet to release pressure. Water coming out of the overflow seems contrary to this occurrence. Overflow (must have) occurred only after enough pressure was built up to balloon the tank. 35 PSI was enough to balloon the tank but not burst the tank or tank plumbing. If the connection was 60 PSI, like our home plumbing, the tank would have expanded more and at some pressure point the tank would burst or blow off a connected fitting. Of course, this is not normal. Good news is since pressure held, the tank and plumbing should still be good, but keep your eye out for leaking. When our tank overflows, it pours out heavy, measured in GPM like the open hose! I'm always rushing to the shut-off asap, so not to waste much water. The overflow is the only way to know for sure you have a full (small) tank of precious fresh water. You could use a gallon counter at the hose. I've never trusted tank monitors, haven't used our SeeLevel display in at least 2 years. Thank you for bringing this to our attention, but personally I cannot see changing our simple fresh tank filling procedure. IMHO, your tank overflow needs repair or replacement vs. change of process for our community. Anything but waiting for tank overflow would be a once or twice weekly PITA. I would try a flexible scope up the overflow tube. Remove any screen in the path (replace with new) and debris. Is there some kind of nest up there? Our old hull has no access panels under the kitchen drawers (as Bill pictured above). Your newer hull likely does. It would be great if you can reach in and disconnect the hose clamp to the overflow! (Someday I'll likely cut a trench under both stacks of drawers to have such access and replace that awful ducting as far up as possible.) I hope you find the reason soon so that you can get back to life as usual! 😎 We'll be reading!
  19. @Skynyrd, there are several threads discussing this in the forum. Google "Oliver trailers forum Winter camping." There are weak spots in the plumbing that may or may not have been addressed with some of the changes in the more recent model years. Like @DanielBoondock says, any camper can be a winter camper if you want it to. I've seen Airstreams being used all winter here in CT. Full hookups, belly skirts, and lots and lots of propane. Not my cup of tea, though, and we also consider our Oliver a 3-season camper.
  20. Timely posts, as I am in a similar position. Having once towed (50k +) the Ollie II with a GMC 2500 diesel (in dogs' years - another lifetime) I can confidently say a 2500 4wd, crew is the sweet spot. As for engine - I now will go gas engine, GM 6.6, as for Ford has 7.3 V8 I believe. The dino burner is just not (to me) worth the extra initial cost, the pain of oil changes and DEF, and other associated issues. The engine braking was nice, but honestly the Ollie at max 7000 # never pushed us anywhere. Honestly other than styling, or personal like/dislikes I could go GMC/Ford - not any real difference in functionality. I prefer the styling of the GMC in certain options. I had a LEER on mine, and you really have to try to get close to payload limits - Oliver in tow, loaded up, stuff hanging off every limb, truck loaded like the Beverly hillbillies, and still well below. I guess you could carry lead weights and get close. but, I digress. So many ways to outfit the truck bed, sliders, shelves, etc - as I get (got!) older the drop tailgate option in the GMC is really a plus. Luckly, I don't need all my WW boating stuff anymore, so that frees up some space for other stuff I don't need, but have to have. Choices, decisions, options. Darn it, I need a beer, a nice reclining camp chair, and a mountain view, yes thats the ticket. RB
  21. Amen!
  22. Again, wow! I wonder what went wrong? We've filled that way dozens of times. Of course, 35 psi of non-compressible water can still do a lot of damage if it has nowhere to go, but you said it was venting out the overflow tube. Will be interested to hear if your tube is kinked or blocked somehow. Enjoy the rest of your, hopefully uneventful, trip.
  23. Yes, for sure anything prolonged at 32 degrees is 4 season and I'm not interested. For us the 4th season is - go south young man, go south - a little farther, perhaps. Now to be clear, we have spent a few nights in freezing temps at elevation (10,000) and all was fine and toasty. As we are outdoors folks, and generally the really cold temps preclude outdoors - usually. I'll take a south Fla beach, or the Texas gulf over the snow and cold any day. Waking up at 30 degrees, in a tent in Yellowstone was great. It's better in the Ollie, trust me.
  24. I was wondering if there is a wiring diagram somewhere. i don’t see it in the manuals
  25. Well i broke down and went into town and bought a voltmeter. the 60 A breaker is good. batteries appear to be good. there is a 1A in line fuse after the 60A that i should check. it’s getting really hot in the trailer since no AC but I only have one more day and then home. hoping for cooler weather at home to continue the trouble shooting. thanks for the reminder of the manual jack tool. I was beginning to panick but I did find it in the trailer. 😀 I had seen it before but had no idea what it was. so i can lift the jacks to get home 🤞 to be continued.
  26. I'm pretty sure you can use VHB to hold a rocket together - that stuff can be the bomb in certain uses,,,,
  27. Golfnut I owe you a beer 🍺 That’s what it was, I was only getting 40.6v at the plug going into the controller and I couldn’t figure out why. I thought it was hardwired from the breaker and didn’t know about the plug box. Thanks again sir!!
  28. I also like using 3M 4950 VHB tape for mounting to fiberglass. I tested several products and ended up preferring the tape. I used it to mount the solar panels on the roof of our Bigfoot camper, and it’s held strong for 18 years so far. I’ve been following your posts—and others—on the A/C upgrade and plan to tackle mine next spring. Right now, I’m leaning toward the Furrion Chill Cube, but I’ll keep researching over the winter and make a final decision in the spring. I may have questions for you then.
