Million Dollar Highway in a half ton truck with LE2?
Patriot replied to routlaw's topic in Towing an Oliver
Rob, just our 6.7 diesel 1 ton, and we absolutely loved the Million Dollar Highway. We let our diesel engine brake do all the work. We would drive it again in a min.𤩠-
Late-Model RAM Owners - how do you like your ātechā?
Galileo replied to Galileo's topic in Towing an Oliver
Though our 2025 Sierra does interface nicely to Apple CarPlay, I find that I have to pick up my phone to kick off certain apps. Thatās something Iām pretty rabid about not doing. Our 2021 GMC Canyon had apps for The Weather Channel, and Audio Books. Seems I canāt get those any more as GMC ended their contract with TWC - so now - not even a basic Weather app thatās native to the truck. If Iām spending $50-$80K on a truck, I -donāt- expect to have to bring my own phone to get the most utility out of it. As it is, by the time I pay the monthly OnStar subscription - and the additional $$$ for data, I honestly shouldnāt need to involve my phone. Digital rear view mirror was an option, but I figured one more thing to go wrong and leave me without a rear view at all. There are a dozen cameras on the Denali anyway, so parking is already pretty easy. My side mirrors do fine for driving straight ahead. I'm debating paying another $3-$500 for the ātransparent trailerā camera that uses the infotainment system display. Though we do have the Furrion back-up camera on the Ollie (āelectronics packageā) Iāve only used it once and put it aside. That display and cable are just too much clutter in the TV cab for 45 seconds use once every few days or weeks. Iāve gotten pretty good at backing this beast into sites, and if I need eyes - I have my better half and copilot to provide intel. As for the Ollie Electrinics package - the only thing I find useful is the keyless door lock. (Though Iāve already had to replace it.) the cell booster does nothing, and Iāve already mentioned the backup camera. -
You need heavier gauge wire output of the MPPT SC to the batteries. I installed 6 AWG reused from the OEM wiring where OTT had extra wires going to the batteries. With the SC mounted very close to the buses, I only needed 2 ft of wire on the red B+ with the breaker and another 2 ft on the green B- wire to the -bus. And our SC is only the 30A model which is just enough for the 400W Renogy suitcase. Your roof panels are connected with #6 wire. 10-12 AWG wire is good for the high voltage from the solar panels to the input side of the SC. I ran #10 wire from a new rear terminal where the cable TV terminal used to be. This would be similar to your Zamp outlet, as our hull did not have one. I used another 30 ft of 10/2 to make an extension cord for the panels. Two #10 wires are inside the 1/2" black plastic wire loom in the picture and you can clearly see the #6 red and green.
johnwen replied to routlaw's topic in Towing an Oliver
2 years ago on our way back from Glacier we traveled the Million Dollar Highway in our 2019 1/2 ton Silverado, 8 cylinder 5.3 L, 8 speed automatic, with tow package. A couple of stretches had me gear down to 2nd gear at 30mph to keep engine below 4000 rpm. As we are full timers we were just below 7000 lbs on the trailer and about 100 lbs below max weight for the truck. Didn't mind going uphill, but downhill we still needed the brakes more than I would have liked. It was a beautiful drive but once is enough. With 140,000 miles on the truck now I don't need to push my luck. Back then we probably had 80,000 miles on the truck. BTW we had our 1 and only flat tire on that highway and we didn't even know it. Another motorist tried to get us to pull over for several miles. I finally found a place to pull over and sure enough the tire was shredded...luckily no damage other than needing a new tire and rim. The next week I installed a TPMS. -
I changed the Max Charging Amps to 24 Amps from 50 Amps on the Victron 100/50 MPPT. The #10 wires were getting warm going to the battery. These Panels put out a LOT of power but the good thing is even in very cloudy weather they still stay near 100 watts and with any sunshine get near 300 Watts. They easily out produce the OTT Roof Mount Panels I have which I believe are 340 Watts.
Mike and Carol replied to routlaw's topic in Towing an Oliver
Rob, going north on 550 keeps you mostly in the inside lane against the mountain. Going south youāre mostly on the outside lane which can seem more intimidating. This is all between Silverton and Ouray. The western route takes a little longer but we enjoy it too. Ditto on Durango, we love it here. Mike -
routlaw replied to routlaw's topic in Towing an Oliver
Thanks @Mike and Carol all helpful info. When I get down that way just might try both routes just to experience it all. Surprised CO actually plows this route though in the winter though. Our roughly equivalent Beartooth Highway up in this neck of the woods certainly doesnāt. Itās closed for over half the year. Love Durango, nice town. -
Ceiling fan lid motor not working
Golfnut replied to Dennis and Melissa's topic in General Discussion
Check for loose connection to motor , also that unit has a 2 yr. Warrenty. Check your manual.. your unit is only 1 1/2 yr old..good luck..stay safe out there⦠-
When using the Cielo Breez Max phone app, the actual a/c remote āmustā be turned off. However, the touch screen can also be used in the absence of Wi-Fi, but many of the advanced features (think Comfy Mode) are unusable. When using the unitās remote, it is suggested to aim it at the Cielo rather than the a/cās distribution/control panel. Regardless of the control method, the Cielo will display room temp, set temp and humidity level.
Mike and Carol replied to Treasure Coast Vault's topic in Ollie Modifications
Weāre camping in Durango now, only at 6,400ā but it was 52 degrees this morning. Late sept through mid Oct will be cold, and expect Some snow. Some campgrounds between here and Telluride close at the end of September or sometime in October! Mike -
We have done 550 several times each way with our previous Ram 1500ās. The grades up and down were not a big issue. Traffic moves at a leisurely pace and almost everyone drives cautiously and at a reasonable speed. You have to respect the road. Weāve also done the drive between Durango and Ridgway many times towing with our 2500, braking is mostly taken care of by the engine brake. Weāve also done the trip west through Delores and Rico on 160 and 145 that takes you by Telluride. Itās scenic in a different way, a little longer but a nice way to go. Weāre currently camping in Durango visiting our son and family on our way to the PNW. He commuted up 550 weekly to Grand Junction for a year when he was working there. He said it was closed a few times due to heavy snow, but other than that he never had an issue. Mike -
SDG air conditioner installation
mountainoliver replied to mountainoliver's topic in Ollie Modifications
Because of tariffs on imported goods and other variables it would be best to contact SDG in Elkhart directly for a quote. The Tosot air conditioners that I have seen online lately range from just under 2,000 to just over 2,000 plus shipping. There may be some dealers that offer the units for well below the above listed prices. -
What are you listening to? Books
Dennis and Melissa replied to ShallowGal's topic in General Discussion
If I remember correctly from 40 years ago when I read it, the best thing you can do is start a list of names with short notes identifying who they are. 𤣠-
Not one for audiobooks. Recently finished a fun science fiction series named āBackyard Starshipā and decided to delve into something a bit deeper. Iām now enjoying the psychological family drama The Brothers Karamazov, by Fyodor Dostoevsky. Although written in the 1800ās, the strong interpersonal family relationships are lessons still applicable to todayās society.
Thanks for sharing your A/C replacement experience. The Tosot unit looks very attractive compared to the Dometic. Would you care to share the cost of the new unit plus installation? Thanks. Don
You are not the only ones who have opted for the alternate route via 145 for the same reason. I have been to Delores in the past but don't recall the market but will certainly look for it if there again. Have an old forest service friend who lives there too. I understand CO 145 is also very pretty as well. -
jd1923 replied to routlaw's topic in Towing an Oliver
@Mike and Carol Mike wrote he towed the Million Dollar Highway with a half ton truck (when in another thread I wrote I was too chicken for that route)! We went to Ouray then back out to Ridgway, south to Telluride and took CO 145 down through Rico and to Delores. We're heading back up there for a few weeks late Sept to mid Oct. Love the area! If you're ever in Delores go to the Delores Market. It's an amazing market with onsite butcher, fresh local produce and amazing baked goods! It will be our first stop on the way up and last stop on the way back! š - Yesterday
jd1923 replied to Dennis and Melissa's topic in General Discussion
Likely the electric lift motor is fried. You can unplug it and supply 12V to test it. This should be the motor but check the part number on yours to be certain: https://www.etrailer.com/Accessories-and-Parts/MAXXAIR/MA10-20270.html https://www.amazon.com/Maxx-Air-1020270-Maxxair-Motor/dp/B01MTUWAMK/ -
Is you outdoor shower knobs closed tight? Open outdoor faucets have caused similar issues. Update: I was replying to the original post and didn't see the complete threadš
Anyone here ever done this? Planning another trip to the SW and would like to explore more of CO and this road trip is on the bucket list but given the steep grades and descents not sure a half ton with 6 cylinder Ecoboost engine will provide enough engine braking compared to an 8 cylinder or diesel. Curious to hear what others have to say or have experienced. Thanks Rob
Today the lid for the ceiling fan stopped working. The manual crank works fine and the fan still OK. Any ideas?
O Ring size: 9/16 x 3/4 x 3/32 seems to work fine....... Just thought I would throw that out there in case any one runs into the same issue......
Weigh Safe 180 Aluminum hitch with 3ā shank, 10ā drop
jd1923 replied to Patriot's topic in Towing an Oliver
Wow! Canāt do this basic task? He shouldnāt be responsible for towing anything! š² -
rideandfly started following I was awakened by flashing blue lights!
rideandfly replied to Snackchaser's topic in Ollie Modifications
You did get me on the click bait! Nice quality work! -
That's what I said last year! 𤣠But you are correct. Just hope the Greenland, $1275 now with sale price and promo code, is priced as good or better next year. Or maybe an improved version 2 of these inverter A/C models gets released! We don't travel much in summer temps, but had more heat than expected in northern MN, SD, WY and CO this June where we had to put up with our Dometic A/C. Our next trip is SW Colorado late-Sept through mid-Oct. Starting at Delores CO at 7K ft elevation, to points north, 9500 ft at Sunshine Campground near Telluride, so I'm hoping to run our Atwood furnace for a couple hours before dawn vs. needing the Dometic A/C at all in the afternoons!
