We upgraded from the OEM foam pads in the Spring of '25 and absolutely love the Tochta mattresses. After having spinal fusion surgery this past August, my wife is in the process of a year long recovery process, and sleeping comfortably has been a challenge. Between sleeping in a recliner, sleeping on our high end mattress on our bed and sleeping in the Oliver on the Tochta mattress, she says the mattress in the Oliver is by far her most comfortable sleep. I also feel it's a very comfortable mattress for me as well. I'm 6'2" and just under 200# and completely comfortable when sleep in the Oliver since the upgrade.
Curosity concerning Truma water heater straps
John Dorrer replied to FloraFauna's topic in Mechanical & Technical Tips
Checked ours today and found only one strap and it was located in the center of the back of the Truma, top to bottom. It was still in tact. -
We have Tochta and are very happy with ours
We were watching an electrical upgrade on an RV, and in one of the drone shots, Deb spotted an Oliver in the background. Check out IreneIronTravels YouTube channel to see it 27:30 into the video.
- 2
On older hulls they used Scandvik faucets that had "BSP" (British Standard Pipe) threads which are harder to source but they can be found on the Scandvik website. Bought one from them a couple of years ago for a little over $40.
Two things... Be certain as to where it is leaking. Is the water coming out from the threads to the hose? If so, what @Ollie-Haus wrote is likely the simple reason. And given the threads are crossed could be a reason why it's on so tight. Many of us have had a similar leak but not from the hose threads. Instead it leaked in the plastic molding to which the hose connects. Run more water while looking to be sure of the specific location of the leak. If it is cracked above the hose connection you will need a new assembly: https://itcshopnow.com/products/exterior-shower Either way you can pull the shower assembly out from the hull. When standing outside disconnecting these hose(s) a simple task vs. hunched over the basement with one hand in there. This link should take you to where I installed a new shower assembly. Notice there is ample slack to work these connections from the outside. Remove the 4 screws and some caulk.
Yeah, I believe you chose the right place that a custom mattress is a Mod!. I've read several positive comments on our Forum re this brand mattress. They came with when we purchased our Oliver used 3 years ago. Therefore, I do not know the full history, how old they were at the time. Whether there were choices for firmness. If new when the hull was born would make them 7 years old at the time. They were WAY too soft for me. My wife was OK with them. At my 6'2" height with 220+ LBS, I felt like I would sink into the foam, it would limit my movement and it got hot. We replaced ours after only a few nights use. We went with Brooklyn Beddings at RVmattress.com and purchased a 30x75" Dearfoam Essential which I believe is comparable to the CopperFlex Essential today. This product became a little too firm even though we went with the 12" height advertised as medium firmness (but too tall if you like to sit on them). It's impossible know firmness when you are ordering online. We opened a corner on each, measured and trimmed a radius using an insulation knife. Tacked the corners back together and the mattress cover holds it all nicely together. I'm happier with a mattress a little firm which let's me sit up to watch TV. Too soft made me struggle with the bedding and was difficult getting in and out of those little 30" mattresses. Just my take, some feedback for your decision.
The only small item should be a flat rubber washer. BTW from your picture, that fitting appears to be cross threaded onto the faucet nipple. Could be the reason for the leak.
My main concern is when I unscrew the hose pictured in the blue circle. It is on there very tight. I have tried to unscrew by hand and it won't budge. I didn't know if when I unscrew it if there is any springs within or smaller items.
FloraFauna replied to FloraFauna's topic in Mechanical & Technical Tips
This looks like a far better anti-vibration solution than the metal straps. -
I added an extension flex hose for doing dishes outdoors and either the Oliver hose, or the extension hose, had chrome plastic fittings, That plastic can split if overtighteded and cause leaks, and it's it hard to see the crack. Those hoses are mostly all the same fitting sizes and readily available at Amazon and hardware stores. Just over finger tight is usually enough to prevent leaks if the o-ring or sealing washer is good. Good luck!
That’s a solid plan, the switch can replace the factory L–H bridge. There’s also a toggle in the Victron app if you ever want to switch it off without a physical switch. Good discussion! Cheers!
Dean and Mary replied to FloraFauna's topic in Mechanical & Technical Tips
Ron, I think the nylon straps make a lot of sense, and that's the approach I plan to use for securing my Victron MultiPlus II after mounting it to a homemade platform. I also plan to place a section of lightweight interlocking foam floor mat beneath it to provide some cushioning and vibration isolation. It's the same material I used in my battery compartment, and it has worked well while also providing a bit of insulation. The mat may not have the heat protection that is needed for the hot water heater. One can purchase the mats at Home Depot or Lowes or ... -
Ronbrink replied to FloraFauna's topic in Mechanical & Technical Tips
Two and a half years in and found a broken metal strap securing the Dometic furnace. Replaced it and others at the Truma hot water component with cam lock straps. Strips of Marine Starboard were placed as heat protection. Great fix, here’s some pics: -
Hello friends. I don’t know if upgrading your mattress is considered a mod or not but I would like to seek your valued opinion and maybe experience with the custom made Tochta mattresses. Sleeping well is getting more and more important as we slip into our 70’s and a mattress we can depend on is very important. If you are or have been acquainted with Tochta, we would appreciate any feedback to help us make an educated guess. Thanks in advance.
@Snackchaser Yes, I understand and agree with the edit. My current plan is to use a simple manual switch to interconnect the L and H terminals, allowing me to remotely activate via the Orion XS as needed. That approach lets me take full advantage of the unit's built-in engine shutdown protection without relying on any automated control of the L or H pins. Thanks, Dean
Here is the reply from OTT tech support concerning this issue: ********************* 1) Purpose of the strap: The strap helps reduce vibration on the water heater while also locking it down into the water heater mounting bracket. It is considered an inspection item and should be inspected anytime you inspect the water heater, and should be replaced as needed.While a broken strap does not prevent the water heater from operating, we recommend replacing it, since the unit is more exposed to vibration and movement while traveling. The risk of damage goes up with rough road surfaces, uneven campsite terrain, and hard braking. 2) How the water heater is attached: The water heater is attached at the front of the unit through the faceplate. At the rear, it is secured through the strap, which fastens through the water heater mounting bracket and into the water heater. The strap goes over the top of the water heater to the other side and is secured the same way. There are also a few spots where the plumber's tape attaches to the water heater around its back edge. ********************* This is helpful info. My only beef is the fatigue failure-prone strapping is the wrong material. @jd1923 recommended some engineered alternatives that will be more expensive but also more durable. Now with the OTT info, I will focus on a secure vibration control. Thanks everyone for your input. -
Kevin L joined the community
I own an Oliver Elite 2, hull 412. I was winterizing my RV and noticed the outside shower hose was leaking. It looks like a pretty easy fix. Before I attempt to repair, is there anything that I should be aware of? The picture show hose under street side bed and the hose in question. The hardest part would be unscrewing the hose from under the bed. It is kinda in a tight spot.
Nissan Titan XD - Our New Tow Vehicle.... WHY?
ScottyGS replied to ScottyGS's topic in Towing an Oliver
Another update for anyone stumbling onto this old post. You will not need the Anderson WDH with the Titan XD. The towing guide is confusing about "required" vs. "recommended" but does not mention the XD model except for mentioning that a goose neck trailer mounts are available for truck. On Page 10-38 of the manual in the asterisk footnotes for towing with the XD it states recommended when towing over 5,000 lbs. I am still using the Anderson because I am so used to it after 8 years of use with an F-150. But the manual clearly states it is only recommended. On another note... After upgrades to the 5 leaf Alcan springs and the larger Nev-R-Lube Axles, the trailer hits a bump and just settles right down. No bouncy bounce 4-5 times like it did with the ford. Happy Camping, Scotty -
Filtered valve stem cores
John Dorrer replied to Steph and Dud B's topic in Mechanical & Technical Tips
We had them vacuumed out, tires balanced, and metal valve stems put on to comply with TST tire monitors requirement of metal stems. We used the $25 gift card against the bill at the Truck Tire Shop. Work was done in 2023.- 1 reply
- 3
- Last week
Fixed! The threads in the hole looked pretty shallow. I suspect the wrong size drill was used, or a worn one that wobbled oversize. I found a good way to better a ces the hole on to of the EZ Flex. I removed the rear wheel, then lowered the trailer partially onto the front wheel. This pivoted the toggle for easier access. I didn’t go too far, because I didn’t want to flip the shackles. After trying a couple methods to get the M7 fitting started, I resorted to the tried and true method of pounding it in with a socket over the top. 😮 That’s never coming out! I put the nipple back on, greased it, and put the wheel back on. Ready to head to Florida in January! Thanks for the suggestions.
@Dean and Mary Please go back and read my edit on the previos post, it may shine a new light on things!
Thanks Geoff. Since I will have a switched positive signal available from the 7-pin connector whenever the vehicle is running, my plan was to use that signal to pull the H-pin high and turn the Orion XS on. While reading through the Victron documentation, I came across the statement: "Engine shutdown detection should be switched off in the Victron Connect app because physical control via the H-pin tells the charger explicitly when to turn on and off." Your above statement is correct and confirmed, so not sure I need to test it. Okay, I am now rethinking my installation choices. I asked AI to list the disadvantages of using the H-pin & came up with this: When you bypass the integrated Engine Shutdown Detection feature on the Victron Orion XS and instead use the Remote H-pin connected to an ignition source or a physical switch to turn the unit on and off, you introduce several distinct disadvantages: High Risk of Starter Battery Drain: If the vehicle's ignition is left in the "ON" or "Accessory" position without the engine actually running (e.g., listening to the radio, updating software, or running diagnostics), the H-pin will see voltage and force the Orion XS to start charging. At its full 50A capacity, it can rapidly drain or damage your starter battery in minutes. [1, 2, 3, 4] Increased Wiring and Installation Complexity: One of the core benefits of the Orion XS is that it can detect whether the engine is running purely by analyzing the voltage on the main heavy-gauge power lines. By turning detection off, you are required to physically fish and route a separate, auxiliary signal wire from your vehicle's fuse box or ignition circuit all the way to where the charger is mounted. [1, 2, 3] Loss of Alternator Overload Protection: When Engine Shutdown Detection is active, the Orion XS constantly monitors input voltage and can dynamically scale back or temporarily pause charging if the alternator's voltage dips below a safe threshold. Forcing the unit on via the H-pin and disabling detection strips away this intelligent automated cushion, meaning the charger could overwork a smart alternator at idle. This second bullet point does not really apply to my installation, since I already have a dedicated wire from the 7-pin connector terminated in the trailer. However, the other two bullet points have me reconsidering whether I want to use H-pin control at all. At this point, I don't believe I will use that option. That brings me back to my original plan of using a physical switch inside the trailer to enable or disable the L-pin-to-H-pin jumper. I would also have the option of controlling the charger through the GX device or simply unplugging the cable to the tow vehicle. My main concern is those situations when it is late, you pull into a place like Cracker Barrel for the night, and you do not unhitch. In that scenario, being able to flip a switch inside the camper provides peace of mind. It is a positive way to ensure the Orion cannot draw power overnight, regardless of any software settings, detection logic, or wiring configuration. I appreciate being able to use the forum members as a sounding board while I work through these options. Discussing the pros and cons with others often helps me think through scenarios I may not have considered and ultimately arrive at a solution that best fits how I actually use the trailer.
For anyone else with a 2022 that got tires with balance beads in them: We installed the filtered valve cores Oliver provided and run the tires with external tire pressure sensors. This year, when I removed the sensors for the winter, I found that 3 of the valve cores had loosened on their own and were leaking, while the 4th one failed altogether. Here are the replacements: https://a.co/d/0dIxCKgF I recommend you keep some on hand along with a valve core replacement tool.
- 1 reply
- 1
