@jd1923 I too love watching "My RV Works". I also still have the Dometic RM2454. My fridge will not stay on left 5. The light usually goes out after a while or immediately depending on ambient temps (so it seems). Not sure it's the eyebrow or board. I've been wanting to delve into it more, but I'm a bit afraid I will break something worse. I'm such a scaredy cat. I don't mind breaking it with someone with me or if it doesn't work at all. LOL. I'm so complex.
I'm not getting this. Do Oliver TTs have something new in late model units? And I don't recognize the fuses in the picture above. Not familiar with Brightway either. On our Oliver I'm pretty sure the breakaway switch uses power from the house batteries applied to the brakes when the pin is pulled. I often pull that pin manually to test for amperage at the trailer brakes. I have a breakaway battery on a flatbed trailer we own. It needs one since it doesn't have house batteries. Is this not disconnected by design? (so that truck starter batteries and house batteries are isolated.)
New Owners! Picking up Hull #1735 on Sept 8th
Wayfinder replied to Chuck and Beth's topic in Introduce Yourself
Welcome @Chuck and Beth. I took nearly 10 years to decide on a camping vehicle/format. Can't say I rushed into things. Enjoy it and continue to learn how things work on your Ollie here in the forums. - Today
Update on the breakaway unit. The 12V is dead and won’t take a charge, supposition is the 12V is internally shorted. Under warranty Brightway is sending out a new unit as they can’t break out the battery separately. Which brings up a DIY project … I have a Honda 7000is generator which has a similar small 12V SLA. Got it long ago before the EV came along which now powers the house in an outage. Early on I found that the starter battery dies after a couple months of not being used, pretty much like any lead acid. With a battery minder on it doing the conditioning its fine. What about the breakaway battery? If these trailers sit for a couple months off seasons I’d expect those to become very unhappy. When’s the last time you checked your breakaway battery, is it still viable? I think what I’ll do is make up a 7 pin socket to 12V port and make sure it’s plugged in at least once a month to top off. Ideally later with a more permanent solution.
Replacing white plastic pipe with pex...
DanielBoondock replied to johnwen's topic in Ollie Modifications
Yeah that's a boundary condition. If you were a painter that would be the picture frame you're working in, so you don't think of it much (or at least us lab rats don't, the marketing guys do 😅) Like, a 100 ft canvas is off the table, but the market will support a 4' portrait, so figure out how to make a picture within that frame. Which is why govt jobs go off the rails so easily if they're not fixed price contracts 🙃 tl/dr The Oliver is pretty fascinating from a project standpoint. Never ceases to amaze me how the way you set up a project determines where it ends up. The Oliver brothers put 'The Big Idea' as it's called as "Highest quality". So nothing was spared. I marvel at the complex shape they have for this body. They actually molded in a 'glass skirt to hide the frame! But wait, it does more, it also acts as a water basin if any leaks occur. I've gotten a few big one setting up a filter unit. No shorts, the water just collected and drain, no damage at all. Hold on, what else? Those provide inner body channels to run piping and hoses. Finally it so happens to also provide wire run channel under the trailer, for propane and two exterior cameras I installed! Utterly protected and a snap to install. That's some genius design in one feature, just because they're not afraid of doing fiberglass and went the extra distance on the body shape. I'm a weirdo, I'll sit outside my trailer and just admire the fiberglass all day 😂🥰 -
Dr. Mike joined the community
We have the same model RM2454, and we've done the same thing! Chris says I hit the switch with my butt when making a drink. 🤣 I use the shelf above the fridge as a bar top. I've gotten up in the middle of the night and it's dark up that way with no lights on! If all the lights are off, then it got turned off accidently. Our fridge has been holding today on AC power, after it needed LP to cool it down at first. I also realized it was nowhere near level. Checked the LevelMate this morning and the front was almost 6" low! That's the way it is in my driveway, hitched with the truck parked in the garage. I raised the front about 3" this morning but can't get it higher because it has to stay hitched. Richard, I'm glad you are working on getting yours to perform again! I was looking at replacement fridges and they're either too small or too big and too much money. Thanks for the heads up on Dinosaur boards. Yeah, if the Xantrex is keeping Marianna up at night, just shut it down. I sleep above our Victron and if it's charging when I want to go to sleep, I'll turn it off. Lucky I can switch it off by the phone app. At some point I'll figure out how the AC/DC circuits work on our model and how to test them myself. This guy may be worth following.
LisaB joined the community
JD1923: I should clarify my issue. We have a Dometic 3 way RM2454 refigerator. Out charger/inverter is a Xantrex Freedom XC 3000 Pro Inverter. So the situation was: After the 3rd day of camping, we left the campground to go to the fair and was gone 4 hours. Upon getting back to the trailer, the refigerator was off completely. I tried turning the unit on and it would not start up on AC. I then switched it on DC and the Xantrex started up (likely to charge the batteries) and did ot turn off. Since it is under my wife's bed, I know the noise would be too much for her. I then switched it to propane and it ran fine. The next day after I thought about it for awhile, I pushed the auto switch in and out for a few times, as it would not activate the first time and only run on propane. After working the Auto switch a couple of time it finally worked and switched to AC. So the moral of the story is.: 1. I think that one of us had accidently hit the on/off switch before leaving the trailer. The auto swtich had not been pushed for a couple of years, so the contacts may have been dirty. 2. I have always found the button operation to be difficult to get it to ingage, maybe due to dirty contacts. That would explain difficulity in getting the refig started again and switching to AC. 3. After discussing the siuation with a knowledgable friend, he suggested buying a new eyebrow board from Dinosaur Electronics who make a better board the Dometic, which I have ordered. I also ordered a new Dometic board (which includes the face plate) since the cost was less than $5.00. I will now have 2 back up boards when needed. Other explalination would be appreciated.
Pulled our Oliver into the driveway yesterday, since we're leaving for SW Colorado tomorrow. Like Dewdev, I started our Dometic 3-way fridge on DC. It did not seem to work. On the Epoch and Victron apps you could see it was only pulling -4A total and our system pulls -2.5A with almost nothing ON! I think I had the Maxxfan on too, so the fridge switched on DC was not actually pulling any DC power from the batteries! Switched it to AC and the readings changed to -16A which is a good number showing the fridge is drawing amperage so should be running. Two hours later the freezer had cooled down to 26F, the fridge at 62F, ambient cabin temp was 79F. This was going nowhere fast! Later last night, I switched the cooling to LP and started the Beech Lane fan at 50%. I sat at the dinette for 5 minutes to hear the LP ignite. It took two tries because on the first try I had forgotten to first light a cooktop burner to bleed the LP lines. After the bleed, I could hear it go through the click pattern twice to ignite and then I could hear it burning, a soft smooth sound. This should be working now. Got up this morning to read the freezer at 8F and the fridge at 36F (Ruuvi sensors and app). We always keep the fridge cooling setting at #4 out of 5. So our fridge is hardly a 3-way anymore! I will try running on A/C (Victron inverter always ON) while we are towing. Maybe now that it's cool it can sustain running on electric. Last trip we were at 7600 ft elevation north of Flagstaff and the fridge had issues staying lit overnight at altitude. This trip we will always be above 7K+ ft. After all I've done to our Oliver, I'd hate to think fridge upgrade now, but it looks like it's coming soon. At least we have the 45L CFX5 fridge in the truck if all else fails. We're packing light on food with good local markets on the route!
Mike and Carol replied to Chuck and Beth's topic in Introduce Yourself
Welcome to the group and congrats on the new Ollie! Look forward to meeting you out there somewhere! Mike -
I think you forgot the golden rule of design," we gotta make money" which follows all of your design examples. Mossey
Hi all, First off, thanks to all of the Oliver forum members who post comments and Q&As. The info we’ve gained from periodically checking the forum activity was incredibly helpful in our decision to buy an Oliver, and in figuring out which model and options would work best for us. Although it took more than a year of research, we finally made the leap this past June! We will be picking up our 2027 Oliver Legacy Elite II (Twin Bed floorplan) on September 8th — Hull #1735. We were tent campers for about 40 years and spent the last 8 years camping throughout the Carolinas and Virginia in a 15-foot Taxa Cricket. We are really looking forward to the next chapter of traveling and exploring the country in our Ollie. If anyone is around Hohenwald during our pickup week, say hello! Chuck and Beth Lexington, NC
Chuck and Beth joined the community
Pepwave Cellular Router and not the common install
Ronbrink replied to jd1923's topic in Ollie Modifications
As @Steve Morris provided plus one extra 4’ pole section in my application. -
rideandfly started following Amazing ceramic coat job near Lake Norman NC
rideandfly replied to Omward Bound's topic in General Discussion
@Omward Bound Appreciate your post. Very nice looking ceramic application. We're in Lincoln County NC, will give Blake a call when we're ready for ceramic coating. Thanks, Bill -
I hear ya, but unfortunately I’m corrupted by spending the last 32 years continually discussing what ‘good design’ is 😅 There’s many different types, ‘design for test, design for mfg, design for repair, design for usability … ‘ What you really mean is it has poor accessibility design. Agreed, or at least it’s not optimal. However it has excellent manufacturing, repair, and simplicity design. Also my post above points out it has excellent usability - once you get in the cabinets its easy to use, don’t need the documentation (diagram) most of the time. And it has the best aesthetic design. The layout is beautiful, and it doesn’t intrude into the cabin with ugly gubbins. So just back of the envelope, it wins in five categories and loses in one (accessibility). Hey, if you can get that kind of hit rate than yes it’s a good design! Design for repair, and design for repair documentation. You’re complaining about the latter. Basically nobody worries about that, it’s what repair manuals (or support lines) are for. I mean seriously, those fuses aren’t hard to find, I did it in my first trip when the composting fan went out. That fuse is in the same spot, I was glad it was so accessible. Turned out it just needed reseating. Anyhow I’ll stick up for Oliver here. One of the things I appreciate about this trailer is how well designed it is. Because they’re not changing the basic design every year! They have one body and frame - that’s been perfected within the form factor, and they just keep refining the interior components and layout. It’s always massive compromise and I love working on this thing, they’ve balanced it all so well after all these years. I absolutely love how neat and tidy it is, with automotive channel wrap on all the wires. Work of art … Ah sorry, been too long at the farm 😅 -
We bought our used a few months ago. Went to Pennsylvania to pick it up. Love it. We have been staying on Oregon coast a bunch. We reside in Grants Pass Oregon IMG_0858.mov
- Last week
Appreciate the info and thanks for being back to me.
taylor.coyote started following We saw an Ollie
Ollie spotted traveling north on California 101 / Arcata, Ca 12 noon Sept 1st. Black graphics. Not many Ollies' located on the west coast but three known Ollie's are located Arcata/Eureka area.
Steve Morris replied to jd1923's topic in Ollie Modifications
I’m not Ron, but I asked the same question before. It is from Flagpole Buddy, and you need the Airstream version with adjustable angle suction cups. They went on sale last Black Friday. https://flagpolebuddy.com/products/ols/products/airstream-suction-cup-mount-kit-g2-g3-g5-or-mini-adapter-poles-mounts-cable-clamps-pole-bag/v/106967-MN -
We get 100s of hummingbirds in Prescott, with the peak season during August. It just cooled off and the hot summer temps are gone 'til next season, thank goodness. They all know Chris as the bird lady. She puts out seed, water in the bird bath and gallons of sugar water in 4 feeders. She even had a couple hummers drink from a hand feeder! The hummers will start to migrate south in the next few days/weeks. We do have some winter hummers, but only a few. We spend an hour or so on the deck each evening. Soon we'll be wearing winter clothes and have the fire ring going! 😆 Hummers in Prescott v2.MOV
ERIC B joined the community
Wayfinder replied to jd1923's topic in Ollie Modifications
@ronbrink Which flagpole and suction cups setup is that on the Ollie? Thanks, -
"Well thought out?" Any need to move beds and bedding is not a good design. @ScubaRx was first to install motorized ball valves! I believe Steve has his switches outside somewhere. I installed them right under the bed, so Chris throws the switches after I run the hose (the third switch/valve is used to drain the fresh tank). Our 12" mattresses are quite heavy and Chris is particular about the sheets/bedding. I don't touch the beds when made, only when home for mods when the sheets are in the laundry! Notice the underbed duct delete too and the addition of a return duct air filter! 😎 @Dennis and Melissa recently blew the fuse for their front jack. Seeing the (extra) fuse at the front jack, he didn't think about three fuses under the streetside bed. Who would? Honestly, only some book-smart engineer in China, that never in his life traveled in an RV, could find a more illogical place for these fuses! We have yet to have to move our beds while camping. See my mod post below. It's worth the work, at least it has been for us! 😎 Some hand carry water jugs. But we always have an extra 35 gallons in the truck bed and we fill via the "boondocking" valve configuration about every other week when camping. I thought I was the only one who added this extra FWT, but recently @FloraFauna wrote, "wish I had opted for 40 or 45 gallons." I bring 25' and 10' hoses and together 35 ft will get from the truck bed to the Oliver rear while hitched. I could not see hand-carrying water (or moving the bed), for something we use so often when boondocking. As soon as one of us hears the water pump gurgle, start to take air, we'll pump in about 20 gallons, saving the remainder for a couple days later. Double your fresh water supply, will allow you to double your stay! 😍
I am looking forward to meeting you as well and 'the dog house' graphic may be gone by then. I need to get a replacement. Mossey
Omward Bound started following Amazing ceramic coat job near Lake Norman NC
Omward Bound replied to Omward Bound's topic in General Discussion
Hi DanielBoondock, Blake works by himself and is the owner of Triple B Detailing. He works one project at a time so he’s 100% committed to the task at hand. I dealt with only him, start to finish and he was wonderful! We dropped our Ollie off on a Monday and picked it up on Wednesday. The wash, prep, and application was a full 10 hour day. We had everything except the awning coated, including the solar panels. He used Stark yacht products. It’s not really a double coat but is a double step process of base coat/prep, then topcoat. I highly recommend him! If you want more in depth information or have any other questions, reach out to Blake! He is passionate about his craft and I found him more than willing to help us by text/phone/email. -
I was corrected by my wife... the order of bedding components, starting from the "bottom", is as follows: (1) 1" pink foam insulation board, (2) Hypervent layer, (3) OEM Cushions, (4) 2" memory foam, (5) Wool topper, (6) Super Cool Comfort Mattress Pad, (7) Full-size fitted bottom sheet. The 2" memory foam was a hand-me-down from another family member. It is just a piece of uncovered, unlabeled, unbranded memory foam. We had to cut the two rear corners with a large pair of shears to match the curve at the back end of the Elite. The "Legends Hotel Wool Mattress Pad - Natural, Full" came from here a long time ago when it was significantly less expensive: https://www.thecompanystore.com/legends-hotel-australian-wool-mattress-pad/11027D-F-NATURAL.html The "Columbia Super Cool Comfort Ice Fiber Mattress Pad" came from here, also a long time ago and less expensive: https://www.kohls.com/product/prd-3044533/columbia-ice-fiber-mattress-pad.jsp?skuId=63361129 At least for our vintage of Elite I, the rear dinette/bed is an "RV Full" size, which appears to be just over an inch narrower than a standard Full size mattress, and has the 2 curved corners at the rear of the camper. We did not modify the sheepswool pad or the mattress pad; they just fit a bit sloppy on the slightly-less-than-full-sized "RV Full" bed. Clearly what is "comfortable" varies from person to person. This has been working for us; hope you can arrive at a bedding configuration that works for you.
