Factory service - Trust but verify
jd1923 replied to Steph and Dud B's topic in Mechanical & Technical Tips
If you want things done right, … (you know the rest)! -
Progressive Industries EMS Display says OFF
jd1923 replied to Tony and Rhonda's topic in Mechanical & Technical Tips
Does it actually turn the EMS off, or just the display? - Today
Tony and Rhonda replied to Tony and Rhonda's topic in Mechanical & Technical Tips
Thanks @mountainoliver, that was the problem. My display is in the basement/trunk and I couldn't see the switch until I put a flashlight on it. My switch also is not recessed, it sticks out, so something must have bumped it on the road. Thanks again, Tony -
Coddiwomple started following Cracked bushings on Monroe Struts
Geronimo John started following Cracked bushings on Monroe Struts
Geronimo John replied to Roger's topic in Mechanical & Technical Tips
Roger: I note the amount of corrosion in your picture. I don't know where you live or operate, but for a 2021 trailer it could use some corrosion control efforts. Especially the axle tube. GJ -
We just returned from our third trip to the factory service center for warranty work and the same problem presented itself again: poor communication. In this case, they were to repair a gelcoat crack near the water heater and do a visual brake inspection. They had the trailer for 2 days. When we arrived at the factory for pickup at 4:30 on the second day I asked the service writer one specific question, "Did you remove the water heater to fix the fiberglass?" I asked this because it had looked to me that the WH would have to come out to address the crack, but the service writer said no, they didn't take out the water heater. Surprised, I double checked, "I don't have to refill my water heater tank?" Again, he said, "No." When we moved to our site for the night, I discovered fresh caulk all around the water heater and an empty WH tank. This is important because, if we had turned our electric water heater on with the tank empty, we would have destroyed the electric heating element. We absolutely should have been told the tank was empty, and if the service writer wasn't sure, he should have checked with the tech. (The tech was smart, though, and did turn off the WH breaker.) Also, I saw the tech's notes on the counter while we were waiting for our paperwork and he noted that we needed new shocks and bushings. I asked the service writer about that, he looked at the notes, and said it "doesn't mean anything." But, when I looked under the trailer later, the bushings were, indeed, badly cracked. Oliver had the trailer for 2 days. I'm surprised they didn't call and ask if I wanted new shocks while it was in their shop waiting for the resin and gelcoat to set. This poor communication at the shop (communication by email/phone before the visit has always been fine) continues a pattern going back to our first warranty trip in 2023. In that case, we went to pick up our trailer after 2 days and found that one of the major items it was in for wasn't even addressed. Overall, we had become so frustrated with service issues that we mailed a letter to Scott Oliver prior to this visit expressing our frustrations and concerns, hoping things would go better this time. We never received a response. Bottom line for us: factory service is hit or miss. We've had some good work there (the fiberglass repair looks great), but there have been serious communications miscues, too. If you need to get service done at the factory, we recommend you keep careful records of all communications and check and verify all work done and everything you're told. Trust but verify.
- 1 reply
- 4
Heating space between hulls
theOrca replied to Jim and Chris Neuman's topic in Mechanical & Technical Tips
That was my first thought, and a much simpler solution than changing the ducting. The only downside I could see is that it requires 24/7 shore power. -
mountainoliver replied to Tony and Rhonda's topic in Mechanical & Technical Tips
Mine has an on/off switch on the front of the remote display. It’s sort of recessed to prevent accidentally turning the surge protector off. -
Allons-Y replied to Jim and Chris Neuman's topic in Mechanical & Technical Tips
I installed a 500W "xtreme" bilge heater. It is on a thermostat to maintain a temp of ~ 50f. I have used it for the past few winters and have added a special circuit to plug it in. They are available from xTreme heaters and Amazon. -
Get 4 new shocks and you may want to go Bulldog brand vs. Monroe. https://www.oreillyauto.com/detail/c/bulldog-hd-suspension/bulldog-hd-suspension-shock-absorber/bul0/hd12130656/ https://www.4statetrucks.com/bulldog-hd-shock-absorber-replaces-555001-19-050000007 From what I can tell in your picture, the upper bushings on the original shocks were badly over-tightened causing the rubber bushings to fail prematurely. Your picture shows too many threads up top leaving very little spacing for the rubber. You want to tighten these so that the rubber is just mushrooming and not much more.
Thanks everyone for your responses. I tried searching but didn't use the right key words. The other posts are very helpful..
THIS thread directly applies to the bushing question - particularly see the last post regarding the appropriate amount of "bluge" . Bill p.s. by typing in "Monroe Shocks" the Forum's search function will return more information of the subject of shocks in general.
HERE is just ones of those posts on the subject of alternative(s) to the Monroe shocks. Bill
Steph and Dud B replied to Roger's topic in Mechanical & Technical Tips
Some of mine look like that. There's a couple of threads talking about alternatives to the Monroes. -
Tom and Doreen replied to Roger's topic in Mechanical & Technical Tips
It's likely those shocks are shot. -
Ray Kimsey started following Cracked bushings on Monroe Struts
Ray Kimsey replied to Roger's topic in Mechanical & Technical Tips
I would replace the entire shock. The cost of the shocks was not that much and I expect yours are pretty well worn out. I replaced mine on my 2020 trailer about two years ago and what a difference it made. -
When I greased my trailer the other day, I noticed that all of the bushings on the Monroe struts were cracked. I am wondering if I should replace the struts or just the bushings. Has anyone else seen this?
Geronimo John started following Heating space between hulls
Geronimo John replied to Jim and Chris Neuman's topic in Mechanical & Technical Tips
Several owners have added individuall heaters in the intersticial space between the hulls. The top choice is to get heat to the water liness entry area aft of the port bunk. This area tends to freeze first. I recall that he used a 500 watt 120V heater for this purpose. A second area prone to freezing is the cabinet space in the bathroom. For occasional use this would in my opinion be enough. However if you are where The Orca is, a forced air approach would be desireable. Intake air from the cabin and distribute it to both port and starboardd areas with extra air going on the port rear side would be my choice. GJ -
2008RN started following Truma Recall Done
Ya, We were visiting son last year in Kentucky, and decided to go down to the mother ship in Hohenwald. Driving through Nashville wasn't fun. At least the larger roads are better in Oregon. THe back roads in Oregon and Tennessee are pretty much the same. (yuk). We got a truma repair and a new AC. We enjoyed the last year's models on the sales floor. Several updates I liked, but not enough to buy upgrade. Good to know that Salem, Oregon has someone that could do some repairs.
- 1 reply
- 3
Water Pump suddenly stopped. What to do?
Tom and Doreen replied to DonnaDuane's topic in General Discussion
If pulling on wires / switches and things temporarily work don’t discount the possibility that fiberglass dust may have gotten into a connection or switch. I’ve had this happen at times. Look for loose or contaminated connections as a possibility. -
@Grizz000 No worries! I thought you might be out camping! Thanks for the info. Mossey
I'd agree with this if the bottom leaf was an overload type that didn't make contact with the leaf pack until a certain weight was exceeded. With the Alcan springs the bottom leaf is arced and looks to be always adding stiffness to the pack. Could be wrong.. Good question for Alcan.
I must be missing something on the 4 vs 5 spring decision. My physics-fu tells me that the spring return rate is set by the longest one or two springs. You chose the spring length, material and temper to set that rate. You then add more (and shorter) springs to take up more load (if needed) for the same rebound rates. What is gained by taking away the shortest spring???
I did. It should be findable as I posted pictures and instructions. Essentially I opened the third port on the Dometic heater and hard ducted it directly across the rear of the trailer. Turned 90 degrees forward and installed a flow adjuster right after it reentered the underbed area. I placed a diverter at that point, and sent part of the warm air directly down under the drivers side bunk. I also installed a 3" flex line running forward all the way to the forward dinette seat. I have been in minus 18 degree F temps in Republic, and the minimum temp under either bunk was 38 degrees. My friends trailer water froze every night by 9 pm. It is tight, but doable! The electric option just would not work for me as I use my Olly as an Elk Camp Cabin. I wanted an extra propane heat load, not an extra electric load. -
@mossemi I applied it to both surfaces. I spread it with a 1/8" v-notch metal spreader. West Marine actually sells a plastic 1/8" v-notch spreader (and they are widely available,) but I used one I already had. Seemed to work great. The G/flex is easy to work with. Sorry for the slow reply - I either didn't get a notification that there was a post, or I didn't see it. Hope this helps!
