  2. Excellent work! You got a lot done today. 😎 I have no idea how long these bearings are good for once they give the first clue. We're going to find out though, yours being the first experience on our forum. Some of y'all who boo-hooed my bearing replacement thread, time to rethink your position. A little noise in reverse. I think that's better than noise going forward or both directions. I would continue on your planned trip. Every day or two when you're leveling, lift that wheel and give it another spin. You have pinpointed your issue and can see how it progresses with miles towing. Exactly, there is no need. My bet is you'll get back to Texas on that bearing! But what do I know? If it gets bad, the bearing is easy to source, and a good trailer shop can replace it. I'll link my bearing replacement thread below. An Authorized Dexter Reseller should be able to replace it under warranty. You have a 2022 date on that axle and given the 5-year warranty is correct, you should be covered. I do not believe there is an original owner clause but find the limited warranty statement online to understand your rights. OTT, another authorized shop or Dexter direct. Your choice, OTT will just take more time. I'd go with a local authorized shop, hopefully back in Texas. If it gets bad when you're still in Wyoming, you always have the Alcan option. I usually forget it's Saturday too! If needed, you could call ahead to order the part. If so, send them your label picture. BTW, Dexter may not provide warranty replacement for a minor squeal. It needs to get worse and truly fail, the noise will be somewhat louder! 🤣 Don't wait 'til you get home. Given they were correct and Alcan just reinstalled them a bit tight, they have not yet been damaged. Loosen them as soon as you get a chance. They're Nylok nuts and will stay put. You'll be under the trailer with your torque wrench anyway, LOL! The rubber should oval-out some but not mushroom over the support metal like in your picture. I see 7 threads on that stud and 4 +/- might be the right count. Make them all the same. Buy new bushing sets later if they get bad. Keep us posted and do enjoy your trip! So cool, you got this worked out quickly! 😎
  3. Today
  4. Sorry John, somehow I missed this when you posted this earlier! This is turning out to be my lamest mod! I usually do better. Dudley came up with the switch idea, and I didn't take the time to realize the light wiring would come in below the vanity countertop! So I have the doghouse mount with wires showing, new switch hole drilled... I'm bummed. 🙃 I was at first thinking of another porch light up front at the same height as the others. When that didn't seem right, I did not think of mounting something lower. Yes, for sure you can do your idea! You could pull power and put the lamp fuse inside the jack head. You would run the switch leg down the jack post, along the incoming line with the 30A fuse. Catch ground inside. Some kind of loom would make for a clean installation to cover the two wires and the jack fuse. You could use the same lamp as the porch lights. There is also a surface mount version of the light I purchased for the front. I just finished making my custom light bracket today. I'll post a picture when I get it installed.
  5. Yep - me again. Reset 2.0 / Hull 1365 2023 LE II. We are week into a two week loop, and I seem to be finding all the weird noises in the trailer. This one is the furnace. Rebecca describes it as "someone bouncing a basketball." When the heater first comes on - regardless of just being turned on or cycling based on the temp, there is a metalic flapping sound that repeats for a minute to two minutes under the curb side bed. It sounds like something flapping up and down to me, Rebecca is sticking with her basketball metaphor. It does not happen everytime, but I can't establish any type of pattern so far. Sometimes it happens as the furnace starts, just now it make two thumps as the furnace shut down. Any thoughts or suggestions on what to check welcome. It's a maintenance / laundry day tomorrow, so good time to look at it.
  6. I for sure know that "Duhh" feeling. Hope it works out well for you Monday. GJ
  7. Started calling at 7:30 this morning. Made three calls before I realized that in the real world it's Saturday.🤦‍♂️ Will try again on Monday.
  8. Test completed. All wheels turned silently, except the curb rear wheel. On that wheel forward rotation is silent, rear rotation (as in backing up the trailer) generates a dragging squeaking noise from the wheel. Performed this test on all four wheels, including the curb rear indicated above. No movement, and I gave it my best linebacker effort. Did not perform this test given that I had isolated it in the first test. @jd1923 based on my understanding of your troubleshooting matrix, this is pointing towards bearings. I did get a photo of the label on the rear axle and included it below. (I also took a shot of the bulldog shock attachments while I was down there. Thoughts? It looks like they were reinstalled a bit tighter than I had them originally. May pull and replace with new rubber bumpers when we get home. Given that we are second owners on Hull 1364, should I contact Dexter or Oliver about the potential warranty claim? Or am I out of luck on the axle waranty?
  9. The plot thickens. Louis Rossmann weighs in. https://youtu.be/lrORu-N6erY?is=OYjAWpKF-BPF1lrE
  10. Would be pure speculation. When we sold our previous LE I, the new owner got spreadsheets and the handwritten logbook that's like an airplane's log. We didn't receive anything like that, just some vague contradictory statements about how little the trailer had traveled and the distant places that they had visited. Based on several other items (shocks, refrigerator, plumbing) I have my opinions and speculations. I have tried to go through (with the help of the smart people on this forum) each system and bring it up to better than specs. Bulldog shocks, new refregerator, etc. I also try to give back with designs for installing the GasStop units on an LE I and will eventually get around to posting my refrigerator fan design that has a temp sensor to run the exhaust fans when needed. The reason we purchased an Oliver is the community, the bunch of experienced travelers and engineers that will see a panic message on a Saturday afternoon and start throwing out helpful and thougtful troubleshooting tips. Besides the incredible engineering and reliability of our trailers, it's the community that sets our Oliver apart from the Grand Design sitting across from us and the Apex next door. Wow - this response got off topic. Road brain, or possibly the wide open spaces of Wyoming out the window.
  11. That’s only three years old! Any idea why they got so bad, previous owner didn’t grease?
  12. We have a fairly steep driveway, and the front is way up to get the trailer level. It works fine. I ordered a new foot plate from Barker.
  13. Wow! Happy 10th and 50th Mike & Carol from your friends at Ollie-land! 🤗
  14. Yesterday
  15. Our Oliver turned 10 last month. We will celebrate our 50th wedding anniversary this coming Friday. Time flies. Mike
  16. Next time at your storage, take a good look at the jack post to see if it’s straight and can fully extend and retract. If you need a new post, I’ve got one, could ship to you. 😎
  17. Ball was greased. I used a grease remover and cleaned it completely up to a nice shiney chrome finish. I took a number of photos and sent them to a tech at B & W and he didn't see anything strange on the ball.🙃
  18. If this company does what they say they are going to do then I predict that they will soon need a much bigger service building. Good luck to them. Bill
  19. Love you both...Wen and John :)
  20. Boudicca: JD is a outstanding standup guy. Comes across some times a bit gruff (Don't we all?), but is pure of heart and giving to a fault. And Chris can sure cook up a wonderfull mountain of pasta as well. I went thru the same process as you, but had the tools and past knowledge to get to the bottom of it. For grins I would suggest you purchase a new seven pin plug for spare parts or use with JD. More than a few ownes like this one if your are going to run the cable back to the J-box as John Davies suggested. If you have a spare few inches in your existing you could just get the 7-pin end. I had those inches and did just the end. Next time I'll have to get the full cable shown below. Amazon.com or Tractor Supply are both good sources for a lot of what we need. The cable connections are easy, getting the "Right" wire into the proper peg of the cord is complex. Having the same color to color at the box makes life a lot easier. Good luck. GJ
  21. Man this is a real mystery. So glad it ended well and that you and yours are safe! I have been reading all the posts trying to make sense of how this could happen, especially to a Bulldog hitch. If the hitch lever was indeed pinned in place and didn't pop open when you hit that bump, then the options become limited. Some thoughts about this: You didn't show the ball in your pics, but I would have a close look at it for clues, including the possibility that it was out of spec and not the correct size. Or that from lack of lubrication, it was "ground down" to be out of round. This is unlikely but worth checking. If the ball doesn't give up any clues, I would check the pin on the Bulldog that creates the hinge that holds the two clamping pieces together. Do the two halve come together as they should? Did the pin somehow get bent increasing the closed opening of the hitch around the ball? It's just hard to imagine a Bulldog letting go of the ball like that if all was in spec. I assume your hitch setup with your TV is nice and flat, not nose up or down. Just throwing out these ideas to try and figure this out. Hope you will let us know what you find out. Definitely take JD's advice and get a new hitch! Sizing up would be good as you would get a new ball as well. Again, glad everyone is OK, and kudos to you for keeping control of your rig. Cheers, Dave
  22. Okay, thanks. I still can’t imagine the Bulldog popping off of a correctly sized ball. Mine is sort of close fitting. I’d still check the diameter accurately just in case and at least settle that question. Anyway I hope you can figure out what actually happened.
  23. B & W Stow and Go with marked 2" & 2-5/16" on the top of each ball
  24. John, if the hitch was closed and locked closed…..maybe a dumb question but are you sure that your hitch ball is in fact 2 inches and not 1 7/8? Accurately measure with calipers.
  25. high prices, over-charging, service calendars booked months out, shoddy work, all they care about is new RV sales! 🤣 Just hear-say though, since I have no real experience in this area. Years ago, with a Class-C, I called to make an appointment and I replied no-thank-you after hearing they were taking appointments 3+ months out and you'd have to leave it there for a few weeks! They'll "work you in." We have a new business that opened recently in town. It's a great concept! They do not sell RVs, but only service HD trucks and RVs. If you need service, look for a place like this in your neighborhood. Get your TV and TT serviced with one company at the same time! Southwest Truck and RV | Gas or Diesel vehicle repairs | RV Repair
  26. June 7th went by and our Oliver has been parked for a few weeks on the corner of our property. The A/C running, set at 80F on battery (😎) since it's getting hot again. We've had a most beautiful Spring that has literally lasted for months. Clear skies every day until some clouds blew in. Just heard some thunder, always hoping for rain. Maybe a monsoon or two will come early this year... I forgot all about her on our third anniversary! We're not traveling again until Labor Day which starts our new travel season and there's nothing big scheduled in mods like our last two summers. She looks and performs a whole lot better than she did 3 years ago! 🤣 The 7th is also Chris' birthday! I certainly did not forget that nor our 32nd wedding anniversary on the 1st! Charley turned 12 yesterday. He got a summer cut and a bone! He loves traveling in our tow vehicle and camping in the Oliver! (see pic above) Thankful to have our Oliver! It's improved our lifestyle, with the ability to leave on moment's notice and glamp (never really liked that word but how true it is). Looking forward to another great year with our Oliver. Even giving some thought to that Rally...
  27. Yes, but... RV dealers are notorious for not wanting to service RVs they didn't sell. I imagine they'll still do warranty work but I'll bet they won't be interested in non-warranty service of a brand they no longer carry. Time will tell.
  28. Depends on how busy they are. We all got nervous when Oliver attempted to pull service.
