topgun2 replied to Gliddenwoods's topic in Mechanical & Technical Tips
Unfortunately, no Oliver staff is "assigned" to read or monitor the Forum. Therefore, if you really want Oliver to see this post, fill out a Service Ticket or send an email directly to Jason Essary. Bill - Today
Gliddenwoods started following Claremore, Will Rogers and 1536 Hello and Missing screws on cabinet cabinet drawers
Gliddenwoods posted a topic in Mechanical & Technical Tips
The four upper cabinet drawers of the six have a latch/bracket (wrong words?) underneath in the front that should have four screws in each. Two of the screws go in the side slots and one tightens them after correctly adjusting. After that two more screws should go in the single hole on each side to "lock" in the bracket. On my Oliver the second two screws were never installed and the bracket after months of use moves and drawer closing fails somewhat. Maybe check yours and fix the Oliver construction error. Hope Oliver Management reads this and speaks to the staff. -
I had the same issue with my Honda 2000 generator blowing. Like @Tom and Doreen said you can change the setting on your Xantrex to lower the draw. Here is a link to the generator topic with instructions on how to adjust the setting.
Hull #435: I have had intermittent power issues with my front tongue jack. Many times getting ready to leave a campground and the darn thing just doesn't have power. It always started working again?? It seemed like after manually raising or lowering it all the sudden it was working again. I have checked the fuse, changed the switch, and still kept getting the intermittent issue. I assumed it must be an electrical short issue (which is always hard to find). With some help from my nephew who is an electrician I have finally solved the problem. The whole time it was a poor ground connection. I believe the ground connection was made through the metal tongue jack being bolted to the frame as the ground wire was coming from the top of the motor assembly. I ran a new ground wire and it now works perfectly. In fact the motor runs better than ever and the light is brighter! My last step will be to weather proof the hole I drilled for the wire to keep water out of the motor.
FYI those with later model 16” Sumec wheels. I checked an older photo I had from my 2021 E2 and can see weight rating is 3300 lbs. I cannot see the max pressure rating on the photo but will check next time I have the wheels off. Although not as beefy as the older 16” Sendel wheels, it’s re-assuring that they are more than adequate.
Sorry JD, I'm not even going to bite on that one..... Maybe you should re-read all 27? pages of that thread. LOL GJ
Tom and Doreen replied to Gliddenwoods's topic in Submit Your Story
The Will Rogers museum is excellent and a terrific Harvest Host location as well! We were there last year around this time. Really enjoyed the museum, Will had quite the personality; we learned a lot! We had full use of the grounds after hours while overnighting there.- 1 reply
- 2
The OEM springs will keep you "soft and bouncy" and it will get worse with more miles. Running with more tire pressure, than the tire load tables spec, just isn't smart towing. Terrible roads in most states, NM worse than AZ! We traveled to Minnesota and back last year (still had D35 axles and OEM 1750 springs), headed east and a big loop NW and back. Kansas highways were amazing in excellent condition. Western Colorado surprised me as being very nice roads. Texas roads are good in most places. Most other places, you bouncy around, potholes and bridge seems that will bottom out the Oliver (if still on OEM springs). @Geronimo John went with Dexter 2400 LB rated springs to save $$$, not sure why else? My take, they're made with the same China steel and heavier weight does not mean they cannot fail structurally in the same way as the lighter model. Go with the Alcan 4-pack if you're OK with spending some more and want less spring. The Alcan 5-pack is perfect for us and I would NEVER go back! 😎 Like your last comment! I've had issues with the sanity of Design Engineers my entire life! 🤣
Yep, it's my understanding Oliver ran out of 3500lb axles & springs when they installed 5200lb axles & springs on #75. I can only guess the wheel & tire supplier made the mistake when supplying wheels for #75, we had the same original LT225/75R/16 Load Range E tires as many early LE2 Oliver owners. My plan is to replace the ION wheels with 15" Sendel S20T trailer wheels with ST225/75R/15 tires mounted. The original 16" ION wheel's finish are in poor condition after 11 years. Going to check where I can get the best deal, Discount Tire will match wheel/tire prices. My goal is to have the same size & capacity wheels/tires as the spare tire (remember smaller spare tire housing on #75) using the same 15" ST tires Oliver currently installs on LE2 trailers. I will only lose about 1/2" of ground clearance. GJ, the wheels & tires just got bumped to the top of the AFE list! 🙂 Appears to be legal changing trailer wheel/tire size if the change meets or exceeds the original wheel/tire capacities, but the ST tire has a lower speed rating compared to the LT tire. No one should be towing an Oliver close to the ST tire top speed anyway. https://www.rvtravel.com/is-it-illegal-to-change-tire-type-or-size-on-an-rv-rvt-1086/ Sendel 15" S20T (S20-56655T-2+) wheel's capacity is 3200lbs @ 95psi. https://www.sendelwheel.com/wheels/s20t.html
You can see from my truck I'm not afraid to stick out like a sore thumb 😅Thanks for not taking offense. Really I'm just figuring this out for myself, I wasn't designed to take things for granted. On the 1750's I was a skeptic, then mostly a convert, but its still pending taking data. Here I'm a skeptic of airing down, don't expect to convert, but also am waiting for data. I suspect I'll end up with 1750's and 65 PSI, but we'll see. Most likely is it's much ado about nothing regardless I wonder. Yeah personal experience towing back from the factory to California was two things. One the trailer did feel a bit soft and bouncy. Two, I'm quite sure I bottomed out the trailer suspension hard on numerous occasions. Arizona freeways in particular were pretty bad. Terrible porpoising around Albuquerque with bottoming, and hard bottom hits elsewhere. So bad you heard the slam. Anecdotally hand waving, but this makes me suspect a too compliant suspension. If you're worried about jarring, bottoming out is the equivalent of dropping the trailer on the ground with no suspension - high G. At any rate reality is a b*** and as an engineer I'll tell you even the engineers don't know. It's often as much experience and windage than having a hard result. Most of the time we do what's being discussed. Design with extra margin/buffer (e.g. higher rating on the suspension and higher PSI range than lower), then measure in typical conditions. If it looks good, cross your fingers, hope for the best and keep taking data 😅
Muehlmatt joined the community
Check it out. Ken’s wheel is also the SenDel brand. I remember a weight rating something like his wheel. Looking at my exterior picture, I'll bet ours is a SenDel as well. You can see it has a simple face without all the studs like the ION wheel. Hull #75 is certainly a special one-off Oliver! 😎
Here’s a photo of the inside of my original 2017 (hull 208) wheels. You can zoom in and see all of the specifications including the 110 psi pressure rating and load rating for the wheel! I took the picture when the trailer was new and filed it for future reference.
Good decision, Bill. Looks like you're upgrading in Load and PSI rating. I believe the ones you're buying are the 4th row on their website table, 15"x6" with a 6/5.5" bolt pattern. Big improvement at 3200 LB @ 95 PSI ratings! Not that we need a wheel that strong. That 60 PSI on the OEM wheels gets me. S20-56655T-2+ 101073 S1050-425CC / 46879 15X6 6/5.50 0 4.25 3200 @ 95 PSI
We were at the Will Rogers museum in Claremore, OK and found a kind unexpected hello greeting note under our windshield wiper from locals Kelley & Debi of Hull 1535. Thanks and hello back from Mary & Bill of Hull 1246 from Wisconsin. Be well.
- 1 reply
- 4
Lithionics Battery Firmware Update
DanielBoondock replied to Snackchaser's topic in Mechanical & Technical Tips
Good thought, but also I believe the LBCO is for the inverter to prevent loading the battery too much - you get voltage rail droop on high loads. I know this because the factory incorrectly set it to 11.1V when it is supposed to be 12.1V. When I corrected that I was getting less simultaneous use (e.g. microwave and induction) out of the battery. From the manual for this particular battery So interesting, the inverter was off, presumably we’re at 12.0V/10%, but the battery was still on. I didn’t hit the switch, but I checked the lights which worked. Seems like NeverDie didn’t trip, maybe it was 10.X% and 12.05VDC or something, not sure, but seems like I was right on the border. -
It’s got the DOT tag, but I need to look at it, I don’t keep Ollie at home.
This is the fact I got mixed up. I’m going to have to see what’s printed on our OEM wheels. So OTT put 60 PSI wheels on Hull #75 in 2015! Does your hull have a DOT sticker stating 80 PSI! Mine does.
- Last week
John, The original 5 wheels on my LE2 were ION wheels with 60PSI maximum air pressure in the casting, following photo. I finally decided to install four 15" Sendel S20T trailer wheels replacing the original ION wheels next year, instead of refinishing the original ION wheels. https://www.sendelwheel.com/wheels/s20t.html This is the 15" Sendel S20T with Goodyear Endurance ST225/75R/15 tire on the right that replaced the original 16" ION spare wheel with passenger tire on the left, both fit in the smaller fiberglass spare tire housing that will not accommodate a LT225/75R/16 tire/wheel assembly. Bill
I'd say the shine on your Oliver looks great! 😂 I went with a local detailer, for the reasons you cited and cost (I paid 60% of the advertised CGI price). This was one experienced guy, running his own business, with very good references. He worked 2 weeks on ours, on and off between small jobs he had. Missed his promise date, because he wanted two more full days to get it right, NP! This before and after pic shows it all! 😎
- 1 reply
- 4
Snackchaser replied to Snackchaser's topic in Mechanical & Technical Tips
Well said! The battery drops below 12 volts at about 0-5% SOC, and the never die is 10% SOC (greater than 12 volts) as calculated by individual cell voltage. The inverter dropout is around 10 volts. However as @Tom and Doreen stated, it would see less voltage, particularly with a load. The inverter will always have some load from voltage drop and just being on. So it seems like all is working well! -
GEN11 started following Ceramic Coating (Minneapolis area)
I’ve seen what happy reviews everyone’s had with CGI, but I’m simply too far away, and cannot schedule to be in the area of the rally easily. As a result I looked locally, because, I’ve had a couple cars coated and they get parked outside…, with great results (11+ years). If you are looking in the Minneapolis, Minnesota area for a detailed/coater I used O.C.Detail and they used Roar AG (the coating Roar does for trucks and agricultural equipment) given the use case. I brought it home today, and think the results look pretty good. https://ocdetailmn.com. Attention to detail seems to have been great (even the fan is sparkling). and Yes a 2025 LE II fits (barely) into their space.
- 1 reply
- 6
First, I very much enjoy reading your posts. Please do keep questioning and pushing the envelope in an effort for you, me, and others to truely understand the "WHY" question. Glad to hear you are ditching the 1750's. Doing so is half the quest. The other half is deciding "What spring best suites our use of our OE2's"? For what I believe is about 10% of owners, clearly the answer is the super strong and reliable Alcan 5-Leaf springs. For the rest of us it is prudent not to "Over-Spring" our suspensions. The obvious choices are either the Dexter 2400 four leaf or the Alcan four leaf. If you are a 10%er that often puts their OE2 into structural gymnastics, great get the 3,000 pound Alcons. If you don't live off-road then the four leaf is your best choice. If you are budget inclined, as I and others are, then the Dexter 2400's is the answer. But if you have the spare cash then why not go to is the Alcan 4-leaf springs. I have to admit that I have never heard someone use the words "Wussie" and "Oliver" in the same sentence. For sure got a LOL out of me on that one. I get your thought line though. Bottom line is that EVERY design has a life span. Air Stream's do in fact pop rivets and have upper cabinet issues when stressed over time. Their owners tend to not be out boondocking on regular basis. Likewise, stress an Ollie suspension enough and one will see the impacts as well. I think Bill summarized the situtation well: So sure we all at times put undue stress on our hulls with no worries. And I think that our hulls are "NEAR" bullet proof. So we can do so for a long time. But it still is smart to go more gentle when we can. Especially for the electronic's, refergerator, glassware, the ton of stuff in our wire shelves in the pantry, not to mention the frame, battery box, ............. etc. Again thanks for your posts! John
Glad our older hull has switched (not touch) lights with solid glass covers, never a one has failed or gone dead in 10 years (knock on wood)! The shades I installed are great for our lights. The touch lights are of larger diameter. @Fritz who started this post used 4" ABS. I like the simple ON/OFF switches OTT installed on switch panels in two locations. Didn't want to change that or mess with settings. We are going to like these shades! (KISS) 😎
jd1923 replied to Snackchaser's topic in Mechanical & Technical Tips
Most 12VDC appliances, lights etc., will run at voltages lower than 12V. Your inverter cut-off worked as it should. 10% SOC means you're lower than 12VDC! We have Victron and Epoch vs. Xantrex and Lithionics, but it's all the same. I have alarms set at 20% SOC on our Epoch and Victrons apps, where we would stop using any major AC appliances on battery (fridge, oven, electric kettle, etc.), at this point using LP instead. At 20% SOC on 900 Ah, our inverter will still be used to stream TV and run our A/V systems, charge electronics and the DeWalt batteries we use for tools and the Starlink Mini. Never been near 10% SOC! When we get much below 20%, it's time to setup our suitcase solar, or break camp and start towing, where the Victron Orion 50A DC-2-DC charger will on average add 40 Ah every hour on the road! 😎 -
OK, and a one more time... @rideandfly runs their trailer at 40 PSI because they tow at 5100 LB GTW. I run 46-48 PSI because our trailer always leaves with full FWT, pantry and fridge FULL, closet floor full of drinking water/beverages, solar panels (they have none), the heavy Victron MP2 and aftermarket accessories, and more. Our GTW is considerably heavier at 6400+ LBS. 😎 The 60 PSI number was ONLY cited as the spec limit on a Sendel trailer wheel. He purchased one for the spare tire, thinking of buying 4 more to replace the OEM wheels vs. restoring them. I believe the Oliver OEM wheels must be rated for 80 PSI (had a pic of the wheel label, can't find it today), also since OTT installed Load Range tires on them and wrote 80 PSI on the Oliver DOT label. IMHO, towing on 80 PSI is crazy, almost as crazy as owning the ugly Airstream. Most of them are a longer than an Oliver, and at 8 FT wide with their over-laden gaudy interiors, most of them are considerably HEAVIER (not the Bambi of course)! I would not want to tow one, but if I had to it would only be with a new 3500 series truck. Yes, tire pressure required is load dependent! 🤣 Mike runs on 55 PSI. Going HIGHER than this pressure is too high unless you plan to carry MORE than the 7,000 GTWR of the Oliver Elite II.
