  1. Yesterday
  2. Have an elite1 with just a charger. House power cord came disconnected and drained AGM batter totally dead. Was able to recharge it with a commercial charger and now holds 12.5 volts but, I have no power for 12 volts items. I checked the power coming in from the battery and I get power to the bus bar and after that, I'm lost to where to trace for the lost of power. The charger is working because everything is working when useing 115 volts. Can anyone recommend where I should be looking for somekind of breaker I can't seem to find. No power going to the 12v fuse box either. Appreciate any help here....
  3. Batten down the hatches tonight up there on the Parkway - there is a bit of rain and wind coming up from the southwest over night. Bill
  4. Perhaps I am reading the chart incorrectly but it appears you could order a 48x20 as the smallest vertical dimension. It probably wouldn't be too difficult to cut an inch on the top and bottom away from existing cabin to accommodate the slightly larger vertical size.
  5. We met Oliver owner “Rob” from Florida at Manzanita Lake in California! Not many Olivers in these parts and it was a thrill to meet you! I was sorry we didn’t get a chance to chat with the wives together. Our camping group was demanding, and then you were gone. I didn’t find your profile on the forum, so here’s a public shout-out, and I hope your trip was great! Cheers! Geoff and Tanya
  6. It does appear they have made changes to these over the years and perhaps even more than what is readily apparent with the upside weep holes with black plugs that don't work for squat anyway. Have also looked for replacement 8800 series but they appear to be unobtanium anymore or at least in the size we need and I certainly would not want black frames. No way would I cough up $987 a piece for this flawed design, $230 maybe. The 300 FV series looks much more promising as replacements IMHO. Regarding the 8800 series, anyone can take a garden hose to mimic even a light shower if they have the correct hose nozzle by shooting the water up gently toward the top of the camper allowing the water drain down with some water hitting the windows directly. One can actually watch the water flowing into the weep holes due to the 8º upward tilt. Or you can wait till the next shower put your raincoat on and do the same in real time with the same results as I have. The only way to fix this would be create a miniature awning or flashing over the weep holes though I am not sure how practical this would be, but it might solve the issue… sort of. Amazed you can hit them with a pressure washer, not something I would ever attempt in their current state.
  7. Guessing the 3000FV is so expensive because Oliver's 48X18 is much wider than their 3000FV maximum listed size of 36X30. It's going to be interesting to see how Oliver retrofits older trailers. https://corporate.lippert.com/products/rv/windows
  8. I might just take the thing completely off. Watched a couple of videos earlier illustrating how to change the fabric, doesn't look to be a big deal other than the height we have to work at. Might be easier to do this at a lower height as the video shows.
  9. Wow! Select the 48x22" window on the Lippert website link I copied above, click Add to Cart, it comes to $230. This number seems very reasonable and what you were quoted for a custom 14x18" size seems outrageous! I wrote above "over $1000 to replace them all" when I was looking at the $230 number. $987 each would not be a direction worth going. BTW, ours are mounted in mirrored directions, left to right, moveable window to the rear, vents/weep holes always down. The outer frame must disconnect from the window assembly somehow to allow for this. Our windows are different from the time of hulls 70-75, to late 2015 when our 2016 model was built.
  10. Hi all I'm not sure if I did or not. Possibly 3M paint protection film as I had some lying around. I'll have to check. The hitch receiver is not bare metal, btw. You suggestions sound good. Tim
  11. We had two leaks coming out at the windows, but in both cases the source of the leak was above each window. Oliver sign on the rear window and street side exterior light over the dinette window were the causes of our leaks. It was a easy fix on the exterior light leak, but the Oliver Sign probably took 1 1/2 days to remove the sign, clean and reseal the sign. Where we store Ollie, we have to tape the bottom window drains while stored, rubber plugs are installed in the top, or Mud Daubers will plug the bottom window drain channels. These 8800 windows with drains top & bottom could be reversed during installation for the window glass to open in the opposite direction. Out of curiosity I contacted Lippert to see what they charge for Lippert frameless 3000 FV 48 X 18 with screen window assembly, they only come with black frames, Retail $986.95. The interior black frame for this window cost Retail $44.95. Download the flyer to see the 3000FV windows in the following link below 3000 windows. https://corporate.lippert.com/products/rv/windows I'm waiting to see what retrofits Oliver will be offering on the frameless windows, not in a hurry for now, just curious..
  12. Been camping this week at Mt. Pisgah Campground NC @ 5,000' on the Blue Ridge Parkway. Some mornings were in the 50s and highs 60s to 70s. Their campsites do not have water or electricity, with the Federal Senior card $15 per night. They have hot showers. When it's hot and humid in the lower elevations, we head to Mt. Pisgah campground to cool off without using AC system. There are plenty of places to hike and a drive on the BRP is always nice, too.
  13. That is kept very clean by camp hosts from Missouri. It is also the only pit toilet I've ever been in that has a separate chair and small rug that can be used for changing cloths, holding a bag (so you don't have to put it on the floor, holding a jacket and/or other stuff. Hopefully those camp hosts are still there. Bill
  14. Better loosen up that bolt and asks the wasps back!🤣 (Now, I'm not touching mine!)
  15. Wondering did Lippert 8800 windows change through the years? The windows installed on hulls #70, #75 vs. our hull #113 and much newer hulls? I posted a couple pictures of ours for reference. I do see top vents on Rob's and Bill's windows that are not on mine! Rob has leakage issues. Others do as well, but we do not. I'm thankful ours do not need repair, but just wondering what's different? Is it the top vents allowing water into the interior channels? I replaced the outer rubber (only). Replaced the white surround with black, sourced from Pelland, if I remember correctly. There was a 1" gap on the old rubber, likely from shrinkage. I cut the replacement rubber to fill the gap and made it 1" longer, cramming the rubber into place on a warm day, knowing it will shrink again in time. This rubber seal protects the moving half of the window from rainwater. I don't have time to handwash the Oliver except to pressure-wash when we return a dirty mess from boondocking. I'll hit the glass straight-on with 3000 PSI water and our pressure-washer is not a toy! Some dirt followed by a fast stream of water will pour out of the window lower weep holes. No water inside the hull ever in doing this a half dozen times. The first couple of times, I asked Chris to be inside, towel in hand, just in case. After twice taking this precaution, I don't bother anymore. If ours were leaking, I would replace the entire window assembly if available. I took a look here and our sizes are not listed. Wonder if they make the 8800 windows to size. Nominal measurements on our hull are 48x18" on the three cabin windows, 36x20" on the rear and I did not measure the bathroom window. I understand it would be over $1000 to replace them all vs. the cost of seals but you'd have a new window with warranty. Or time to get an awning window if you prefer that style! Lippert 8800 Series RV Window - Horizontal Slider | Lippert
  16. Good grief, after washing and cleaning up the Fiamma this morning, now I can't get the thing to retract properly at all. Both ends are stuck partially open. Can't get in touch with customer support at the company either, messages do not go through.
  17. and a pit toilet at Horse Creek cg.
  18. We really like that campground! Mossey
  19. Scroll to the top of this page. In the "blue" banner at the top look for "home" and left click on it. At the top of the next page look for "RV Education" and "hover" your mouse over it until a "drop down menu" appears. In that menu look for "Annual Owner Rally" and left click on it. A new page will open. Scroll down until you see "Register for the 2026 Oliver Rally" and left click on it. A new page will open - full it out with the requested information, pay your money, see you there! Bill
  20. Thanks Bill, good fix and repair tutorial. Your tabletop is quite secure now. This will get me to take a peek under ours. We've just left our table in place, knowing we wouldn't use the dinette as a bed. Maybe it hasn't been moved for 10 years, and I've never felt it move. But as I get older, I'm often leaning on things to get up! 🤣 And it's not safe if it can move. Tom, this sounds like a painful routine! Certainly, time to execute Bill's simple fix if you don't find a latch that will work.
  21. Update on Lippert 8800 series repairs due to leaking. The new glazing beads from Steele Rubber products arrived late on Tuesday and I went to work on the first one right away. It became obvious right off the bat the application of silicone spray or equivalent lubricant would be needed due to the new rubber having lots of friction. Once siliconed the seals went in easily yet provided actual connection to the sliding window. The window does not slide as easily indicating good connection thus less water intrusion. Thats the good news. The not so good news is the windows channels still take on water but this is due to the weep holes facing 8º tilt upwards toward the sky due to the Oliver body shape. While installing the new weather stripping seals I also took the time to plug the channel where the fixed window is screwed into that channel preventing water from infiltrating this area. Using rope caulk I jammed both the top and bottom area of this potential place for water intrusion. I also discovered the small black plugs installed into the weep holes at the top of the frames DO NOT prevent water from entering into the top of the window and then flowing down through the vertical channels carrying dirt debris mud etc. The top part of those channels on all of our windows were very dirty and stained. Removed all four from one window and found them to be completely encrusted with dirt and debris. Rather than re-install I decided to caulk those 4 slits and will also do this to the remaining other two windows. I had hoped to completely eliminate any water intrusion but early efforts at re-designing weather stripping were an abysmal failure. Effectively the new glazing bead weather stripping will help but certainly not fix the issue entirely. With this in mind what I will do going forward is carry and smallish portable wet/dry vacuum along and clean out the weep holes using wet vacuum mode. I have tried this numerous times now and it works quite well. Just this morning after washing our awning which allowed some water to flow down the Oliver side and window and into the weeps holes I was able to vacuum some 2-3 oz of water from the curb side window. Struck me as quite a bit of water given that the window only got wet indirectly. But for now its a fix for a flawed design.
  22. We have our campsite, but how do we register for the rally through Oliver?
  23. AND - there are fish in Horse Creek - most are 10 to 12 inches but a very good friend of mine can attest to a 17 inch brown that was a bank feeder is there to be enjoyed. On the "interesting" side - be careful to watch for bears. This same friend came back from there one year and said to his wife, "I'm going to need a bigger gun!". In my opinion - sites 2 and 3 are the best sites. No electricity or dump here but there is water available via a hand pump. Bill
  24. Well crap wouldn't you know my earlier unit does not have those adjustments to make. However I did discover two wasp nest buried in the awning compartment and one loose bolt on the mechanism. In fact it was almost all the way out. Doubt this has anything to do with adjustment fore and aft for retrieving the awning into its compartment.
  25. So they are roughly $5 each, and my shipping was $18. Thanks for the confirmation. Shipping is outrageous.
  26. Last year I visited Horse Creek Campground in Wyoming. If you are really adventurous you can continue north all the way to Double Cabin Campground. It's beautiful there, but I didn't tow my Oliver that far; it's a long rough road.
