Is you outdoor shower knobs closed tight? Open outdoor faucets have caused similar issues.
Anyone here ever done this? Planning another trip to the SW and would like to explore more of CO and this road trip is on the bucket list but given the steep grades and descents not sure a half ton with 6 cylinder Ecoboost engine will provide enough engine braking compared to an 8 cylinder or diesel. Curious to hear what others have to say or have experienced. Thanks Rob
Today the lid for the ceiling fan stopped working. The manual crank works fine and the fan still OK. Any ideas?
O Ring size: 9/16 x 3/4 x 3/32 seems to work fine....... Just thought I would throw that out there in case any one runs into the same issue......
Weigh Safe 180 Aluminum hitch with 3” shank, 10” drop
jd1923 replied to Patriot's topic in Towing an Oliver
Wow! Can’t do this basic task? He shouldn’t be responsible for towing anything! 😲 -
rideandfly started following I was awakened by flashing blue lights!
rideandfly replied to Snackchaser's topic in Ollie Modifications
You did get me on the click bait! Nice quality work! -
That's what I said last year! 🤣 But you are correct. Just hope the Greenland, $1275 now with sale price and promo code, is priced as good or better next year. Or maybe an improved version 2 of these inverter A/C models gets released! We don't travel much in summer temps, but had more heat than expected in northern MN, SD, WY and CO this June where we had to put up with our Dometic A/C. Our next trip is SW Colorado late-Sept through mid-Oct. Starting at Delores CO at 7K ft elevation, to points north, 9500 ft at Sunshine Campground near Telluride, so I'm hoping to run our Atwood furnace for a couple hours before dawn vs. needing the Dometic A/C at all in the afternoons! -
Snackchaser replied to Patriot's topic in Towing an Oliver
A friend of ours rented a private trailer this summer, but he had not slid his receiver hitch fully in, and the retainer pin missed the hole in the shank. A dip in the road caused the receiver to slide out, and both safety chains broke. The violent snap caused the propane to break free and hit the windshield of a following car, causing a minor eye injury from glass particles. He said the chains were "hefty." It would be hard to determine the force put on those safety chains, but it must have been considerable! Just sayin, a chain is only as strong as the weakest link! -
After 8 years of use it was time to retire the Dometic air conditioner. I have looked at several brands and for one reason or another I decided on the Tosot brand which is the same as the Atmos brand and probably others as well. Since last summer the Dometic has been making fan bearing noises off and on and I’ve grown tired of climbing on the roof to oil the motor. After eight years I really didn’t want to replace the motor only to have something else fail so this was an excellent excuse to replace it with a higher efficiency quiet unit. We’ve been traveling out west for the past three and a half months and were passing “close” to Elkhart Indiana so decided to drop in and visit the SDG folks. The entire replacement process was perfectly coordinated and our installer Joe knew exactly what needed to be done. We’ve camped out in their parking lot the night before with 30 amp shore power available. The next morning at 8:00 AM I backed our trailer into their shop and about two hours later the job was done. They even printed a custom cover plate to cover up the holes from the old Dometic thermostat. We were able to sleep through the night with the air conditioner running for the first time in 8 years without having to use earplugs, and to watch television at half volume instead of full volume! The air registers force air towards the front of the trailer instead of most all of the cold air being forced onto the bed area. We’re parked in central Ohio for a few days and it’s very hot and humid but the air conditioner is keeping the Oliver very dry and comfortable. On low fan the unit draws about 9 ac amps. Running from the inverter the inverter draws 94 dc amps. The Dometic on inverter would draw between 130 - 140 dc amps under similar conditions. We are extremely pleased with the work that SDG provided and with the comfort and efficiency of the Tosot unit. I strongly recommend the folks at SDG for the air conditioner replacement. They have done several Oliver air conditioner replacements and have experience in replacing/installing air conditioners on many different rv types.
- 1
Ronbrink replied to Patriot's topic in Towing an Oliver
To be clear, the above statement was made in reference to the stats for a hammerlock product I purchased and featured in my comment posted May 11, 2025 of this thread. The ‘link’ being referenced in the above statement was provided by @jd1923 in his November 13, 2024 comment and the stats are for this dissimilar product. -
I need help with my Norcold 412.3 refrigerator please.
Snackchaser replied to Copycat Carlton's topic in General Discussion
Good on you for your perseverance and skill at getting the Norcold fixed! Thanks for providing part numbers and giving hope that problems with these, now obsolete, refrigerators can still be repaired. I think it would be great if you explained how to remove the front panel right here on the forum. I'm sure others would benefit . . if not now, then later. Congrats! Geoff -
After trying to get our Norcold 3 way refrigerator repaired and having Oliver service center look at it twice. The service center quoted us a price of $4800.00 to replace the Norcold with a Dometic 12 volt compressor unit. I decided to try to repair it myself. The power board is easy to change it is the one accessible from the out side lower panel. That didn’t fix it. So I changed the optical display board next part number 628663. This board is located behind the front panel of the refrigerator. This board didn’t fix it either. Next I replaced the front button control panel part number 630619. The fridge is working properly now. I purchased these items on eBay. The removal of the front panel was the most difficult of this process. Message me if you would like an explanation of how to remove the front panel.
ScubaRx replied to Snackchaser's topic in Ollie Modifications
Poor Tommy Lee. He gets blamed for everything. -
Mountainman198 replied to Snackchaser's topic in Ollie Modifications
The cat did it! -
Yes, will definitely be using the app/remote, just like having the display available for a quick look at the temp. I'm also known to lose remotes and phones so it's good to have a backup too...
Treasure Coast Vault replied to Treasure Coast Vault's topic in Ollie Modifications
One thing at a time Grasshopper. While u install the axles more videos and products could hit the market. Heck it will be cooling down very soon now you could prolly coast into March and get it then. -
ScubaRx replied to Patriot's topic in Towing an Oliver
When I follow the link I get this info: RELIABLE STRENGTH. With high-strength steel construction, this threaded hook is rated for a breaking strength of 11,000 pounds and a work load limit of 2,200 pounds -
Are you sure this is not a crime scene? -
Very Nice Work... -
DunnYet started following Texas dealers
It’s simple math. Sell and Oliver, you have a happy customer but their trailer is going to last a lifetime, need minimal service, and provide them a wonderful experience. Sell them a Stick Built, you are going to see them in the service department every three to four months with an expensive slide out issue, leak, electrical failure, or suspension collapse. And in no more than five years you are going to sell them another one. Bonus, you will finance each of these and get the lift on that. We were talking to a couple with a Grand Design at a park a couple of months ago who had been camping 20 years and had gone through 10 trailers. What dealer does not want to have people like that as “customers for life.” (We met them when they stopped to look in our Oliver - they were looking to downsize from their 5th wheel and had heard all the good things about Olivers 😀)
My Dometic Penguin 2 will see your bet of 685 watts and easily raise you another 1100 watts! And it must also be at least 10 dB LOUDER too! Maybe I should take advantage of the Turbro sale. It's a tough call. Just spent over $3K on D52 axles and Alcan springs that I hear shipped today. That's going to be a bunch of hours installation and a A/C unit would have to sit in the box for awhile! 🤣 - Yesterday
If you are going to keep the remote nearby to make adjustments just act like the phone is your remote? The app has a Ton more features. It's very convenient. And you are connected to the AC from anywhere to make adjustments if you have Wi-Fi.
I had the Ollie out in 95 Degree Central Florida Sunshine today and the Pioneer dropped the temperature to 78 and cycled fine. It was drawing around 685 watts. It is also very quiet. I was running off my inverter and the batteries. -
Late-Model RAM Owners - how do you like your “tech”?
Tony and Rhonda replied to Galileo's topic in Towing an Oliver
Thanks Geoff! -
The Pioneer and Turbro Greenland A/C units are remote or phone controlled. The OEM Dometic thermostat shows set temp but not actual temp, so I often have my phone open to the Ruuvi Sensors App to check cabin temp and fridge/freezer and basement temps. Also, I need my phone to level the trailer and check propane tank levels. I'm happy for these Bluetooth apps for so many things. I check battery stats and all Victron devices via the VictronConnect App. Many Oliver owners have installed Victron BMV-712 or Cerbo GX displays, not me! I can see all the same specs, turn our inverter off when needed and all from my phone. Why spend the extra money for a display that can only be used when standing in front of it? Why cut openings in fiberglass walls and complicate the simple interior design of the Oliver? What happens when technology advances and the installed display is no longer usable? I would not purchase the Cielo Breez Max until after a new A/C installation, determine whether we truly need another device. Take another look at the Cielo Breez Max. It appears it can be operated by touch controls on the device itself or by phone app. Likely control by the phone app is not needed on a daily basis after initial configuration setup.
