Everything posted by rideandfly
We've been camping at Stone Mountain State Park NC. The weather was fantastic allowing great views on the Blue Ridge Parkway and we got plenty of hiking in at Doughton Park on the BRP. There was also a Carolina Casita Rally happening here too, we met many nice fellow fiberglass RVers. Woolly Worm Weather Outlook: https://www.thoughtco.com/woolly-bears-and-winter-outlook-3444522
We have towed Ollie (LE2) with 5 different tow vehicles. Found a new 2024 F-350 6.8L (gas) on the lot last summer (2025) and got a super deal on it, lower price compared to many 1/2 ton pickups with an old school normally aspirated gas engine. No weight distribution hitch to worry about and no worry about running out of payload capacity when loading for trips with Ollie connected. Olivers are known for how stable they are when towing, but with the longer wheel base of our Heavy Duty pickup our rig is extremely stable. I used to modify 1/2 ton pickups rear suspension to get rid of rear end sag with either airbags or Timbren systems, not needed with our current rig. Installed a Diamond back bed cover, but we have enough payload capacity to install a fiberglass shell if we chose one, a little over 4,000lbs payload. Heavy Duty pickup trucks have heavy duty brake systems and heavy duty cooling systems for towing in the mountains, too. Best Regards, Bill
Our original Furrion solar port was rated for 10 amps. It was OK with one 100W panel, but did not have enough rated capacity to handle two 100W solar suitcases. Decided to modify the original Furrion 10A solar port to handle 20 amps by installing a Zamp 20 amp port in the existing Furrion port. Should have used the Zamp port to start with. Modified Furrion solar port 20 amps:
Our previous Tundra's name was Stan 🙃, photo taken at W. Kerr Scott Dam and Reservoir,
StarLink mini with StarLink router mini.
rideandfly replied to 2008RN's topic in Mechanical & Technical Tips
We don't have Oliver's factory solar system and inverter. When away from shore power, use a similar switch mounted in Ollie's battery box with our system. Installed two Epoch 105AH lithium batteries, using up to 2 solar suitcase panels for charging or gen-set on poor solar days. Stole @Snackchaser ideal (Thanks Geoff) converting the TV cable inlet to the Starlink Mini power outlet using a 12V/24V to 48V step up DC to DC converter. Need to install a small interior switch so turning the system on/off can be done from inside Ollie, too. -
Thread passed 1,000 replies! Congrats to everyone on such a great thread!
Amazing ceramic coat job near Lake Norman NC
rideandfly replied to Omward Bound's topic in General Discussion
@Omward Bound Appreciate your post. Very nice looking ceramic application. We're in Lincoln County NC, will give Blake a call when we're ready for ceramic coating. Thanks, Bill -
DC-DC Charger Installation - Oliver LE2 and RAM 1500
rideandfly replied to Grizz000's topic in Ollie Modifications
Thanks for posting, educational for me, too. -
Agree, Beautiful Shot!
Agree, started participating in this thread almost 10 years ago. At home working on Ollie, it’s raining, so cannot finish everything today. Hopefully will be on the Blue Ridge Parkway camping soon, will take some “Where’s Ollie” photos, too!
Tractor Supply sells a 2” ball 7,000lb capacity coupler that looks like the hitch on the X23. https://www.tractorsupply.com/tsc/product/tractor-supply-traveller-straight-coupler-2-in-ball-7000-lb-capacity-2526179
Upgrading from a Bulldog 2” coupler to 2 5/16 BD coupler
rideandfly replied to Patriot's topic in Ollie Modifications
Good discussion! Just measured the Bulldog 2 5/16" coupler and 1 7/8" ball mount/ball and discovered the following. With the 2 5/16" coupler with collar lock installed, a thief can easily back up to a trailer with 2 5/16" coupler, lower it on a 1 7/8" ball and drive away (not sure how far the 1 7/8" hitch would make it). My current 2" Bulldog coupler is still on Ollie stored at the airport, doubt it will slip over a 1 7/8" ball if locked with a collar lock like the Bulldog 2 5/16" coupler, but will check. At the most narrow inside portion of the 2 5/16" coupler with collar locked measures 1.91" A 1 7/8" ball measures 1.87" outside diameter A theft deterrent for the Bulldog 2 5/16" coupler needs to have the ball opening covered or filled to prevent this type of theft. I like using the Bulldog coupler latch locked with a long shank padlock while in transit and for storing the chains with the emergency brake cable snap-hook. Also use an inexpensive Universal Coupler Ball Lock that Fits 1-7/8", 2" and 2-5/16" couplers. Previous Bulldog hitch discussion: -
We use a long shank Brinks padlock in the 2" Bulldog coupler. It fits snugly without drilling and hang the chains on the emergency brake cable snap-hook: Tried a short shank Brinks padlock in the new 2 5/16" Bulldog and it fits, too. After making holes in the new Bulldog, will sand and spray paint with aluminum finish for contrast. -
Happy July 4th and 250th US Birthday!!!!!!!!!!!!!!!!!
Our Ollie does not have factory solar or inverter. I use portable suitcase solar panels or a 2000W Honda Gen-Set when away from shore power. Copied @Snackchaser idea converting the Furrion Cable TV inlet to a Starlink Mini power outlet using a 5.5 x 2.1 mm DC Power Jack Socket. Thanks Snackchaser for the idea! Used a 7/16" drill bit to drill the new Furrion power outlet for the power jack socket to fit. Had enough threads on the 5.5 x 2.1 mm DC Power Jack Socket to install water/dust cover, lock washer and nut. Old Furrion inlet on the left: https://www.amazon.com/dp/B0GKB4YSM5?ref=ppx_yo2ov_dt_b_fed_asin_title https://www.amazon.com/dp/B0DLKN8J7M?ref=ppx_yo2ov_dt_b_fed_asin_title Purchased a 12/24V to 48V DC to DC step up Starlink Mini converter and switching with a manual switch to be installed.
That's a great price on the LT225/75R/16 Michelins. Believe one of the local installers for Tire Rack can be Discount Tire, for those who like Discount Tire.
Spare Tire wobbles inside the fiberglass cover
rideandfly replied to Dirt Duff's topic in Mechanical & Technical Tips
Removed Ollie's spare tire housing again and firmly pulled across one area of tire tread to see if the spare tire had complete contact against the fiberglass hull. It moved a little, not as easily as @Dirt Duff tire. The wing nut was causing friction against the wheel, I thought the spare tire was tight contacting the fiberglass hull completely with the 225/75R/15 spare tire. Believe the same thing was happening with the original 215/60R/16 spare tire, too. Both tires were contacting the fiberglass hull previously in areas, but not completely. Cleaned the area on our camper where the spare tire contacts the fiberglass hull and installed four 3 1/4" diameter 1/4" thick door knob pads for the tire to contact like @Hokieman did on his spare tire. With two nuts still on the stud and four 1/4" thick doorknob pads installed on the hull for the spare tire to contact when tightening down the wing nut, the tire contacts all four pads with clearance left between the wingnut and two nuts. I'm keeping two nuts on the mount stud, but in some cases there could be contact between the second nut and wingnut on other Oliver spare tire installations like it would be on @jd1923 trailer, possibly due to small variations of wing nuts, mounts, wheels and tires. Really like the plastic disc @Townesw installed for the wingnut to contact when the wingnut is tightened against the wheel. -
Looks like two Olivers in the photo.
Yep, My original spare tire was a 215/60R/16, even though the DOT tag states spare tire size of 215/70R/16 and my current spare tire I installed is 225/75R/15 to fit in the fiberglass housing. The 215/60R/16 fit tightly against the fiberglass hull like the current 225/75R/15 with two nuts on the stud. Oliver made a change to 225/75R/16 spare tires with larger spare tire housings later after our Ollie was built. Now Oliver's current spare tire is 225/75R/15. @Dirt Duff, you have some good suggestions here to check out that should correct your issue. Edit: For those that have not removed the spare tire cover and tire: -
Yep, That sounds right, it's not likely the elastic locks nuts loosened clamping the plate to the fiberglass hull, but still check when the spare is removed. Good advice! -
I like the pads (assume) you installed on the fiberglass. Ours has two nuts on the stud, but I like the single nut with disc on yours, too. -
@Dirt Duff No that is not typical. On our Ollie the fit is snug when the wing nut is tightened. Is this mounting plate tight against the fiberglass hull? -
@routlaw, We previously had Dometic/Seitz awning style plexiglass windows in another camper that we liked. Most folks here want glass. Yep, Lippert 3000 FVD with two operating windows has a maximum size up to 72X30. The frameless glass dark windows looks really good on an Oliver, always liked having the ability to open the Dometic windows during light rain, too. Like I said, it's going to be interesting to see Oliver's retrofit. I contacted Oliver about window retrofits and they said we would all be notified at the same time when available. 🙂
Here's the Lippert information I'm looking at, 3000 FV minimum size 12X12 and maximum size 36X30: I like canopy style frameless windows instead sliding windows, looking forward to see what Oliver retrofits older trailers with.
Guessing the 3000FV is so expensive because Oliver's 48X18 is much wider than their 3000FV maximum listed size of 36X30. It's going to be interesting to see how Oliver retrofits older trailers. https://corporate.lippert.com/products/rv/windows
