Everything posted by CRM
I see Steve was able to fit three 300ah batteries into his tray. Didn't you have to remove yours to make them fit? Different size trays, or did battery dimensions change?
This one off Amazon should work fine and you shouldn't have to do any rewiring. Waterproof Reverse Polarity Switch
I'm looking at these Vatrer batteries now myself. Can't beat that price for 900ah for what seems to be a decent quality brand.
Haven't bought anything yet, just still in the beginning of the planning stage. And that King antenna was removed within days of buying #45... Ended up bringing it to @mossemiwho also lives here in Tampa. Have to get my son off to college and complete the move to our new place in Floral City Fl, but once that's done, upgrades will be priority #1!
2015 Oliver Legacy Elite I air conditioner replacement recommendation
CRM replied to DBL-R's topic in Ollie Modifications
Actually, according to Morton's testing, the Turbro is a fair amount more efficient than the Chill Cube in BTU's per watts... though I have no doubt that the Chill Cube is quieter and has better temperature control. I still wouldn't recommend the Turbro to anyone not willing to modify it as much as I did mine, though. One I would take a close look at is the new Furrion low profile with heat pump unit that *looks* to be the same outside unit as the Turbro but also *looks* to have fixed most if not all the issues I have with the Turbo, especially the ability to have a wired external thermostat. Going to try and check one of these out in the wild to see how they perform. I have a brother looking to upgrade his Dometic and might give him my Turbro if it works as advertised. -
New axles may not fit all older sub-frames
CRM replied to Wayfinder's topic in Mechanical & Technical Tips
I'm so sorry, that was not my intention! I just didn't want to see you treating them as non-maintenance sealed bearing hubs if they were in fact standard bearings. -
My wife would have made me stop for a pic for sure!
Glad you got out! Situations like this is why having four wheel drive is at the top of my list for a TV. Won't go without a front hitch either.
Good to know... Thanks. Thought they put that on the label from a prior discussion about the Nev-R-Lube axles. -
Are those axles Nev-R-Lube? I thought the Nev-R-Adjust label was only on the standard bearing axles. -
A short clip that some may find useful. It shows just how easily an inverter A/C unit ramps up and how it allows a much smaller generator to run it safely as compared to a standard compressor A/C unit. While this was on a Greenland Turbro, the numbers and ramp up profile should be very similar with any of the current units on the market. This test was using a Honda EU2200I generator and the readout is in volt-amps and not watts. VA actually topped out at 970VA but the video stopped right before the peak. After running 15 min power draw leveled out around 600VA and then down to 400VA after an hour or so. Should be able to get 6+ hours runtime on the .95 gallon tank if the A/C runs continuously. Not my plan to ever have to use the generator to power the Ollie, I just wanted to know how it would perform in an emergency situation where we're left without power for several days. Something everyone here in Florida thinks about during hurricane season! Video Project 8 (1).mp4
Furrion Chill Cube – Product Review and Installation
CRM replied to jd1923's topic in Ollie Modifications
Looks like they modified a Turbro unit like I have and fixed most or maybe even all the features I don't like about it. -
Before the shutdown Oliver was planning something similar with the "Sport" package. Check out the price for the "Appliance Package" add on... 😲
I remember reading in the "Morton's on the move" blog that BTU output was about half it's actual rating but didn't think that would be a problem since my old 9.2k Coleman worked just fine at cooling in our Ollie, and it worked better than others I've used at controlling humidity due to longer run times. I bet you'll get better performance when traveling at lower altitudes. Bottom line, none of these units are perfect, but if you need A/C off-grid inverter compressor units are really your only choice and the Chill Cube seems to be a great one. Only question is durability, which is the same question I have for my Turbro. -
Very nice, especially at your elevation. Probably losing 15% or so efficiency up there in the clouds! -
Very similar to the numbers I see from my Turbro, though I will see low 900's watt range when first starting up and interior temps are 90+ degrees. Once close to setpoint it's in the 500's during a hot sunny day and around 200 watts at night to maintain temps.
Here are the specs for the Houghton 48v unit that's in the Apex. It runs only as low as 660 watts (which matches the 666 watts in the Oliver video) which is higher than either the Turbro I have or the Chill Cube you have seen in real world testing. It also draws up to 1700 watts at full power which is something I don't think either of ours ever get near. Obviously have the loss in the inverter conversion but there's loss in the 48v cabling too... Would still like to see real world data from the 48v Houghton, though...
When the Apex was first announced I looked up the specs on the Houghton 48v units and compared it to the numbers I see from running my Turbro. I'll have to go back and re-check the numbers.
Yep, obviously the Ah is Ah, but what I was trying to say is that running an inverter A/C off of 12v batteries though an inverter is more efficient than the Houghton 48v running directly off of the 48v battery.
I agree. I did some napkin math when the specs first came out and it seemed to make much more sense to have 600-900ah of 12v over 400ah of 48v and run everything though either 12v or the inverter. Even the AC efficiency came out better running a 120v inverter compressor unit over the 48v Houghton unit, especially at the lower BTU rating of the 48v Houghton.
MaxxFan Mod to Add a Fan Motor Switch and Deep Cleaning
It's kind of strange they didn't design it to have that option to begin with... Not sure what make/model I have but it has separate controls so I can turn the fan off while the vent door is open. -
I would assume that I have the same door as all the early Elite 1 models. I wonder if any of those have failed?
Ouch is right, and todays hourly rates are totally ridiculous. I owned an auto repair shop back in the 90's and was charging 42.50 per hour and was getting attacked by customers over it. Dealerships at the time were 50-55. Of course the dollar has lost over 50% of its value since then, but that should have only doubled the hourly rates from that period.
With my Turbro Inverter, once it reaches set temp I'm seeing between 250-600 watts during the day in 85-95 degree weather with 80+ humidity so you're probably pretty close with your numbers- and we keep the inside temps low, too... around 70-72. Haven't monitored during the night yet but obviously the watts draw will be even lower. Don't know why anyone who boondocks would buy anything but an inverter AC/Heat pump.
