Coddiwomple
Everything posted by Coddiwomple
Coddiwomple "to travel in a purposeful manner towards an unknown destination"
Might work but wondering if the L bracket will move when drilling and attaching screws. All is good so far.
Going back to Geoff's original post on this thread, I did this (except for relay) and it works great but have been concerned about water penetration at the exterior socket when Starlink cable is plugged in. I have swapped mine out for a water-resistant component custom designed and made by Tom at Platypus3DDesigns in Mesa, AZ. Although the original socket worked great, it was not water-resistant so I asked Tom to create one that would replace the Furrion Mini TV/Satellite Inlet. Here is the link to his component. https://www.etsy.com/listing/4349330543/starlink-mini-dc-cable-pass-through It has 18 gauge wires attached and a magnet that holds the cap in. In addition, he adds another magnet on the side that can hold the cap when not inserted. I asked for a modification so I could add a lanyard. Tom drilled and threaded #8x32 holes for that. All screws and machine bolts were attached with blue Loctite. I was able to use the original Furrion gasket. I had to drill out the hole in the fiberglass a bit larger and I wrapped some butyl sealant around the barrel upon installation. Here is a link to the lanyards. https://www.amazon.com/dp/B0B4RXTKBH?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 To finish it off, I used a very small amount of dielectric grease on the cap seal and rubber fins on the Starlink cable end. Works great. David P.
More DC to DC charger installation tidbits
Coddiwomple replied to Snackchaser's topic in Ollie Modifications
Hey Carl, you can come over to see how I did mine in our Elite 1 if you like. I don't know if you remember me and Martha but you showed your Elite 1 to us on 9-3-22 when we were considering an Oliver. We are in North Plains. -
Elite I bed across the back and adding some color
Coddiwomple replied to Ron and Phyllis's topic in Ollie Modifications
I don't think it was a custom top. I just told Oliver folks that I wanted a smaller Lagun-type table top and they said they had one available at the factory. I don't know if they still make them. We are very happy with our setup and it works great for us. Cannot think of anything I would do differently at this point except if you have a table top made you will want it to be as light as possible. We always remove ours when traveling. David P. -
Seek Blu Technology Hose Quick Release Fitting Cover
Coddiwomple replied to Gliddenwoods's topic in General Discussion
We have Eley quick connects and contacted them directly. They recommended some covers (along with part numbers) from McMaster-Carr that fit perfectly for both male and female parts. Only problem is that you have to buy a bag full of them. So, you might try contacting Blu T support. With all that said, what works really well for us now is a 2" wide roll of blue painters tape to cover the outlets when traveling to protect from road grime. -
Thank you Geoff. Correct. They did say it is OK to connect and disconnect at the Anderson plug with the engine running, however, they felt it was a "good practice" to have the engine off. Thanks for clarifying that.
I actually asked Artek these same questions and was told that a switch is not needed. Additionally, they said connecting and disconnecting should be done (as a good practice) when the engine is off and no charge current coming from alternator.
I used the following that were recommended by Artek. 1. Blue Seas MRBF Terminal Fuse Block and a MRBF 60 amp Fuse. 2. Blue Seas Series 187 Surface Mount Thermal Circuit Breaker 60 amp. I have attached photos.
No, I did not work with Oliver on this project. -
Thanks Ron. Haven't tried that but will consider going forward. -
I’ve attached photos showing how I mounted the EZ Reach table system. To do this, I used a 12" x 16" aluminum sheet and aluminum L brackets. Additionally, I attached an angled brace from the top of one of the L brackets to the aluminum frame supporting the heater. The setup is very sturdy, and we’re pleased with how it turned out. For the EZ Reach system, we selected a 16" arm and a 12" arm to achieve the level of articulation we needed. The table top was purchased from Oliver. Note: We always remove the table top from the system while traveling. Hope this information is helpful! -
LE1 Generator Selection
Coddiwomple replied to My Imagination's topic in Mechanical & Technical Tips
You do not need this relatively expensive kit, with regulator, if attaching the generator directly to the Oliver onboard LP quick disconnect which supplies regulated LP pressure. Yes with an external tank, but connected to the Oliver only a hose with correct fittings is needed. I just spoke to Derek at Hutch Mountain and he asked me to post this to clear up a misunderstanding. When installing their propane conversion kit, it is required that the large Demand Regulator is still used when connecting to the onboard LP quick disconnect. -
When we had the soft start installed at the Elkhart facility, this is what we learned. 1. They are installing the standard SoftStartRV unit but they add a custom made bracket (which they will not sell to you). 2. The unit is installed with screws and 3M tape on a frame piece in front of the evaporator (bottom-left). Not in a cavity behind the evaporator (as is suggested in a video in YouTube). 3. There is a 2 year warranty on this install. 4. It is easy to do yourself but that would void the warranty if some left. Per the tech, if you install one yourself, and then need work done on your unit for some other unrelated issue, they will refuse to provide service. Warranty or not. -
We drove to Truma in Indiana in September and had the soft-start installed. While there and in the presence of the technicians, I connected my Honda 2200i Companion generator with propane conversion and we tested it. Worked perfectly. The technicians were impressed. When we got home, I tried it again and ran the generator and air conditioner for several hours. I did this test three times. I am very happy with the set up now and confident going forward. Instead of running two generators I can now run one. The big test will be when we get some altitude to see if the generator can handle it - after changing the carb jetting of course. As a side note, I can now run the air conditioner off the 2000 watt inverter. We tested this too at Truma with success. -
Just finished install of Victron Orion XS 12-12 50A charger in my Elite 1. Special thanks to Geronimo John for helping me with my project. His expertise was invaluable. And highly recommend Artek Energy in Milwaukie, Oregon where I purchased most of the components, parts, and materials. They went above and beyond with advice and even helped with the settings on my existing Victron MPPT Solar Controller and SmartBMV712. Everything is now working together smoothly and efficiently. At 80% SOC on the Lithium Batteries, the charger is pushing out 48.8 amps bulk charging at idle. Nice! Replaced OEM 100amp alternator with Mechman 240amp alternator. 1/0 marine grade tinned cable from alternator to battery and then back to Anderson SB175 connector. Then 1/0 to busbars in trailer and reduce to 6 gauge for short runs to/from components and batteries.
Fix for falling shade frames. I tried replacing the clips and applied silicone to help hold. Nope. The large shade frame fell off again on the last trip so I was determined to do something different. The shade frames will never fall off again. I removed all of the clips and their spacers. Cut and installed 4" long sections of aluminum c-channel purchased from Home Depot using original screws along with blue Loctite. Then placed the frames back on, drilled and attached the shade frames with #6 stainless steel screws. Fitment is perfect. Hope this helps others. Photos attached.
SET SCREW .313-18 X .50" per the VIP-3000 manual from Barker Mfg.
We have the Progressive Industries EMS-PT30X which is supposed to protect against high and low voltage and surges. Is there something about the Hughes Autoformer that I should know about that is better? I understand it can be mounted inside for theft protection but I am more concerned about damaging the electronics, appliances, and equipment.
We have a 2023 Elite 1 with Goodyear Endurance ST225/75R15 tires. We were told to inflate to 65psi. I just found the load chart and it indicates that we should be inflating to about 45psi if I am reading it correctly. I am assuming the weight listed in the chart is per tire (so half the total weight). On the scale, the trailer weighs just under 4,000 lbs loaded. I uploaded a snippet of the load chart. Can someone confirm this?
Fresh water tank electric drain valve
Coddiwomple replied to C&MCurrie's topic in Ollie Modifications
Thank you C&M Currie for the great info! I did this modification and followed your advice on all the parts and components except I opted for the two wire version. Works great!! -
Xantrex Inverter Issues? Try a Hard Reboot
Coddiwomple replied to Rivernerd's topic in Mechanical & Technical Tips
For the Elite 1 Folks...... I too have been working with Jason E on this and have an Elite 1 with the 2,000 watt inverter. After changing the LBCO to 11.5 volts through the app and testing multiple times (4 cups water for 4 minutes in microwave), I was able to succesfully use the microwave all the way down from 100% SOC to 14% SOC with no alarms or overload cutoff. Happy with results.
