propane issue
has anybody had issues with not getting propane pressure using the  forward and aft quick connects on the propane lines.   I can not get enoough propane to fire up my coleman portable stove. It works fine with the small disposable propane bottles.  I am getting gas through the line but very low pressure.  Any ideas out there would be appreciated
thankyou
skip nielsen
hull # 822
Have you removed the regulator on the Coleman stove? It won't work correctly if you haven't.
There are lots of YouTube videos on how to remove the regulator on the Weber Q series regulator so that it works on the quick connects.  I bet there are also videos on how to do the same with the Coleman.
You can use a Coleman Road Trip Grill with an adapter hose available on amazon with the quick connect. Weber, Blackstone, and some Camp Chefs will also work with a mod removing the regulator.  Lots of You tube videos. Those are low pressure devices. They run at 11wc.  Coleman stoves and others are high pressure running at 15wc. They will not work well even with a mod.  Need to know whether your device is low pressure or high pressure. That sometimes means calling the manufacturer.  I use a Coleman Road Trip. I wanted to switch to a Coleman Cascade 3 in 1 because it is smaller and lighter. Just went down the internet and RV forum Rabbit hole to find this out.
Bill Thomas 2019 Elite II Hull # 534
2020 Chevrolet Silverado HD 2500
To use a Coleman Road Trip grill you would still need to do some piping to bypass the trailers regulator. Won't work right, or at all, if you just use the adapter on the grill side and plug into the trailer quick connect.
thanks for all the information.   I would guess that the coleman stove I have needs high pressure like what comes out of a disposable propane bottle. I think I will stick with the diposable bottles for  now.  I bought a 30' hose and had the gas company connect a fitting that screwed into coleman regulator and the other end the quick connect.  yes,lowpressure gas.  seems like a pain so will hold onto the hose for the future .
skip  #822
skip  #822
seems to me the quick connect ports on the trailer are pretty useless since I can not connect the grill.  Lots of work and hassle to bypass the trailer regulator.
We use ours all the time for our fire pit, Blackstone griddle and Weber Q1000 (regulator removed).  No mods necessary for the Blackstone or fire pit.
Very useful for us! I have a quick-connect 12 ft LP line to a quick-connect T. Then we connect our Weber Q grill (maybe buy a proper grill?) and this fire-ring. Removed regulators on both. Don't really need a YouTube if you have a good local hardware store to find the right brass fittings. Very happy not to carry an extra LP tank for outdoor use.
Bond Bond Signature 18.5-in W 54000-BTU Bronze Portable Steel Round Propane Gas Fire Pit in the Gas Fire Pits department at Lowes.com
Is your heater and cook top stove working properly?
skip  #822
If you have the room, you could always bring along a 15lb propane tank and connect to your grill using an adapter hose. Less expensive and wasteful than using hose small tanks plus it could be a backup for your Oliver's tanks. Personally, I'd try and remove the regulator and add a quick connect to the grill so I could use the Oliver's quick connects.
Same here. 👍🏻
North Carolina 🇺🇸
No the Road Trip will work off the quick connect. The regulator for the Road Trip is a removable. You can buy an adapter hose on Amazon with a connector that screws into the same fitting as the regulator used for the 1 lb green bottles. No need to by pass the trailer regulator. Weber, Blackstone, and others will work. There are kits where you remove the grill's regulator so it will work off the quick connect. They are all low pressure. The issue is with high pressure devices like Coleman and other camp stoves. Even if you remove the regulator they will not run at proper temperatures. For those you do have to by pass the trailer regulator. Some solutions is carry a spare tank. Or they make Y connects you can use on one of the trailer tanks.
Hope this helps
  • 1 month later...
