rideandfly Posted 8 hours ago Posted 8 hours ago (edited) Our LE2 originally came with Dexter 5200lb axles & 5 leaf springs. Right now our ready to camp weight with empty water tanks is 5100lbs. No one has reported the original 5 leaf Dexter springs failing, yet. With the 10,400lb total axle/spring capacity combined with a 5100lb LE2 weight, I always tried to reduce the overall accumulated fiberglass/frame/component stress from the impact of higher capacity springs by running lower air pressure in the LT load range E tires and by towing slower on rough pavement. We purchased our Ollie used in 2016 and ran 50PSI like the previous owner without issues until seeing the LT tire pressure/load charts in different threads here like the ones posted earlier when I reduced the pressure to 40PSI for the last one or two years without issues. Edited 8 hours ago by rideandfly 1 Bill 2015 LE2 #75 2024 F350 6.8L
DanielBoondock Posted 7 hours ago Posted 7 hours ago (edited) 8 hours ago, Geronimo John said: Short Version: Springs because dozens of us have had them FAIL. Axles because a boat load of us have tons of miles on the 3500 Dexters, and the cost of replacement of the brake assemblies is insane, and besides we want the braking power of the 5200's. Misunderstanding, I know why we're upgrading the springs and I'm doing it too. I just meant 'why do we all invest in a high end suspension if we don't believe it'll cushion the ride sufficiently?' Basically, we invested in a high end robust trailer - one of the most if not the most robust and well build. Additionally we beef up our suspension. I don't get then why we pamper that trailer like it's a wussie Some Other Trailer - especially when I see tons of Airstreamers running 65 PSI with these tires no problems. 8 hours ago, Geronimo John said: I can assure you that the fiberglass does flex. Of course it does. During a factory tour it was discussed how they have to add honeycomb panels into the glass to reinforce because the panel cutouts lowers the rigidity. And generally you don't want a perfectly rigid structure; the vibration has to damp somehow. And no doubt 'there have been issues', but its anecdotal without details. OTOH when I was there a tech told me about a recent trailer they got back in. The guy fell asleep at the wheel, the trailer flipped over on it's side and got dragged down the road a long distance. With a pretty good rug burn you can imagine 😅(more later). But the tow company just put it back on its feet and ... guess what ... just towed it back normally! The hitch was mangled I think but they chained it up just fine. So the insurance wanted an assessment, and you know they could have actually repaired it just fine. The engineers issue was liability. It has burned through the belly band on that side pretty well, sure they could repair but then they have to support it. Wasn't worth messing with and they called it a total loss, except it wasn't really. Anyhow you speak to common sense but I don't think that is a good guide here because it's too hard to judge. My common sense says underinflating - with a trailer this robust, is adding risk for no benefit. We need numbers. From the spring thread I suggested taking measurements. I recommend a vibration app for you phone, tape that to the floor and test how much vibration the trailer is getting. Test and different PSI's. I'll bet it's small, and dropping significantly (e.g. recommended 65 to 35) doesn't greatly help, while lowering efficiency, increasing heat and overall risk. I'm taking a trip next month and will measure how I'm beating my trailer to hell at the factory recommended 65 PSI and post the results. Another member said he's upgrading his springs soon and will also measure, which will tell us the spring performance, and how much vibration we're getting. Edited 6 hours ago by DanielBoondock 1 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 500 mile pack)
jd1923 Posted 4 hours ago Posted 4 hours ago (edited) 11 hours ago, Geronimo John said: To be clear you and I both recommend 40 PSI. Right? OK, and a one more time... @rideandfly runs their trailer at 40 PSI because they tow at 5100 LB GTW. I run 46-48 PSI because our trailer always leaves with full FWT, pantry and fridge FULL, closet floor full of drinking water/beverages, solar panels (they have none), the heavy Victron MP2 and aftermarket accessories, and more. Our GTW is considerably heavier at 6400+ LBS. 😎 The 60 PSI number was ONLY cited as the spec limit on a Sendel trailer wheel. He purchased one for the spare tire, thinking of buying 4 more to replace the OEM wheels vs. restoring them. I believe the Oliver OEM wheels must be rated for 80 PSI (had a pic of the wheel label, can't find it today), also since OTT installed Load Range tires on them and wrote 80 PSI on the Oliver DOT label. IMHO, towing on 80 PSI is crazy, almost as crazy as owning the ugly Airstream. Most of them are a longer than an Oliver, and at 8 FT wide with their over-laden gaudy interiors, most of them are considerably HEAVIER (not the Bambi of course)! I would not want to tow one, but if I had to it would only be with a new 3500 series truck. Yes, tire pressure required is load dependent! 🤣 Mike runs on 55 PSI. Going HIGHER than this pressure is too high unless you plan to carry MORE than the 7,000 GTWR of the Oliver Elite II. Edited 4 hours ago by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted 2 hours ago Posted 2 hours ago 4 hours ago, DanielBoondock said: I know why we're upgrading the springs and I'm doing it too. I just meant 'why do we all invest in a high end suspension if we don't believe it'll cushion the ride sufficiently?' Basically, we invested in a high end robust trailer - one of the most if not the most robust and well build. Additionally we beef up our suspension. I don't get then why we pamper that trailer like it's a wussie Some Other Trailer - especially when I see tons of Airstreamers running 65 PSI with these tires no problems. First, I very much enjoy reading your posts. Please do keep questioning and pushing the envelope in an effort for you, me, and others to truely understand the "WHY" question. Glad to hear you are ditching the 1750's. Doing so is half the quest. The other half is deciding "What spring best suites our use of our OE2's"? For what I believe is about 10% of owners, clearly the answer is the super strong and reliable Alcan 5-Leaf springs. For the rest of us it is prudent not to "Over-Spring" our suspensions. The obvious choices are either the Dexter 2400 four leaf or the Alcan four leaf. If you are a 10%er that often puts their OE2 into structural gymnastics, great get the 3,000 pound Alcons. If you don't live off-road then the four leaf is your best choice. If you are budget inclined, as I and others are, then the Dexter 2400's is the answer. But if you have the spare cash then why not go to is the Alcan 4-leaf springs. I have to admit that I have never heard someone use the words "Wussie" and "Oliver" in the same sentence. For sure got a LOL out of me on that one. I get your thought line though. Bottom line is that EVERY design has a life span. Air Stream's do in fact pop rivets and have upper cabinet issues when stressed over time. Their owners tend to not be out boondocking on regular basis. Likewise, stress an Ollie suspension enough and one will see the impacts as well. I think Bill summarized the situtation well: 6 hours ago, rideandfly said: I always try to reduce the overall accumulated fiberglass/frame/component stress from the impact of higher capacity springs by running lower air pressure in the LT load range E tires and by towing slower on rough pavement. So sure we all at times put undue stress on our hulls with no worries. And I think that our hulls are "NEAR" bullet proof. So we can do so for a long time. But it still is smart to go more gentle when we can. Especially for the electronic's, refergerator, glassware, the ton of stuff in our wire shelves in the pantry, not to mention the frame, battery box, ............. etc. Again thanks for your posts! John 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
