Our LE2 originally came with Dexter 5200lb axles & 5 leaf springs. Right now our ready to camp weight with empty water tanks is 5100lbs. No one has reported the original 5 leaf Dexter springs failing, yet. With the 10,400lb total axle/spring capacity combined with a 5100lb LE2 weight, I always tried to reduce the overall accumulated fiberglass/frame/component stress from the impact of higher capacity springs by running lower air pressure in the LT load range E tires and by towing slower on rough pavement. We purchased our Ollie used in 2016 and ran 50PSI like the previous owner without issues until seeing the LT tire pressure/load charts in different threads here like the ones posted earlier when I reduced the pressure to 40PSI for the last one or two years without issues.
Edited by rideandfly
Bill 2015 LE2 2024 F-350 6.8L
8 hours ago, Geronimo John said:
Short Version:
  • Springs because dozens of us have had them FAIL.
  • Axles because a boat load of us have tons of miles on the 3500 Dexters, and the cost of replacement of the brake assemblies is insane, and besides we want the braking power of the 5200's.
Misunderstanding, I know why we're upgrading the springs and I'm doing it too. I just meant 'why do we all invest in a high end suspension if we don't believe it'll cushion the ride sufficiently?' Basically, we invested in a high end robust trailer - one of the most if not the most robust and well build. Additionally we beef up our suspension. I don't get then why we pamper that trailer like it's a wussie Some Other Trailer - especially when I see tons of Airstreamers running 65 PSI with these tires no problems.
I can assure you that the fiberglass does flex.
Of course it does. During a factory tour it was discussed how they have to add honeycomb panels into the glass to reinforce because the panel cutouts lowers the rigidity. And generally you don't want a perfectly rigid structure; the vibration has to damp somehow.
And no doubt 'there have been issues', but its anecdotal without details. OTOH when I was there a tech told me about a recent trailer they got back in. The guy fell asleep at the wheel, the trailer flipped over on it's side and got dragged down the road a long distance. With a pretty good rug burn you can imagine 😅(more later). But the tow company just put it back on its feet and ... guess what ... just towed it back normally! The hitch was mangled I think but they chained it up just fine. So the insurance wanted an assessment, and you know they could have actually repaired it just fine. The engineers issue was liability. It has burned through the belly band on that side pretty well, sure they could repair but then they have to support it. Wasn't worth messing with and they called it a total loss, except it wasn't really.
Anyhow you speak to common sense but I don't think that is a good guide here because it's too hard to judge. My common sense says underinflating - with a trailer this robust, is adding risk for no benefit. We need numbers.
From the spring thread I suggested taking measurements. I recommend a vibration app for you phone, tape that to the floor and test how much vibration the trailer is getting. Test and different PSI's. I'll bet it's small, and dropping significantly (e.g. recommended 65 to 35) doesn't greatly help, while lowering efficiency, increasing heat and overall risk.
I'm taking a trip next month and will measure how I'm beating my trailer to hell at the factory recommended 65 PSI and post the results. Another member said he's upgrading his springs soon and will also measure, which will tell us the spring performance, and how much vibration we're getting.
Edited by DanielBoondock
  • Care 1
Sierra EV AT4 2026 (max range 530 mile pack)
11 hours ago, Geronimo John said:
To be clear you and I both recommend 40 PSI. Right?
OK, and a one more time...
@rideandfly runs their trailer at 40 PSI because they tow at 5100 LB GTW.
I run 46-48 PSI because our trailer always leaves with full FWT, pantry and fridge FULL, closet floor full of drinking water/beverages, solar panels (they have none), the heavy Victron MP2 and aftermarket accessories, and more. Our GTW is considerably heavier at 6400+ LBS. 😎
The 60 PSI number was ONLY cited as the spec limit on a Sendel trailer wheel. He purchased one for the spare tire, thinking of buying 4 more to replace the OEM wheels vs. restoring them. I believe the Oliver OEM wheels must be rated for 80 PSI (had a pic of the wheel label, can't find it today), also since OTT installed Load Range tires on them and wrote 80 PSI on the Oliver DOT label.
IMHO, towing on 80 PSI is crazy, almost as crazy as owning the ugly Airstream. Most of them are a longer than an Oliver, and at 8 FT wide with their over-laden gaudy interiors,  most of them are considerably HEAVIER (not the Bambi of course)! I would not want to tow one, but if I had to it would only be with a new 3500 series truck. Yes, tire pressure required is load dependent! 🤣
Mike runs on 55 PSI. Going HIGHER than this pressure is too high unless you plan to carry MORE than the 7,000 GTWR of the Oliver Elite II.
Edited by jd1923
First, I very much enjoy reading your posts.  Please do keep questioning and pushing the envelope in an effort for you, me, and others to truely understand the "WHY" question.
Glad to hear you are ditching the 1750's.  Doing so is half the quest.  The other half is deciding "What spring best suites our use of our OE2's"?  For what I believe is about 10% of owners, clearly the answer is the super strong and reliable Alcan 5-Leaf springs.  For the rest of us it is prudent not to "Over-Spring" our suspensions.  The obvious choices are either the Dexter 2400 four leaf or the Alcan four leaf.  If you are a 10%er that often puts their OE2 into structural gymnastics, great get the 3,000 pound Alcons.  If you don't live off-road then the four leaf is your best choice.  If you are budget inclined, as I and others are, then the Dexter 2400's is the answer.  But if you have the spare cash then why not go to is the Alcan 4-leaf springs.
I have to admit that I have never heard someone use the words "Wussie" and "Oliver" in the same sentence. For sure got a LOL out of me on that one.  I get your thought line though.
Bottom line is that EVERY design has a life span.  Air Stream's do in fact pop rivets and have upper cabinet issues when stressed over time.  Their owners tend to not be out boondocking on regular basis.  Likewise, stress an Ollie suspension enough and one will see the impacts as well.  I think Bill summarized the situtation well:
6 hours ago, rideandfly said:
I always try to reduce the overall accumulated fiberglass/frame/component stress from the impact of higher capacity springs by running lower air pressure in the LT load range E tires and by towing slower on rough pavement.
So sure we all at times put undue stress on our hulls with no worries.  And I  think that our hulls are "NEAR" bullet proof.  So we can do so for a long time.  But it still is smart to go more gentle when we can.  Especially for the electronic's, refergerator, glassware, the ton of stuff in our wire shelves in the pantry, not to mention the frame, battery box, ............. etc.
Again thanks for your posts!
John,
The original 5 wheels on my LE2 were ION wheels with 60PSI maximum air pressure in the casting, following photo.
I finally decided to install four 15" Sendel S20T trailer wheels replacing the original ION wheels next year, instead of refinishing the original ION wheels.
https://www.sendelwheel.com/wheels/s20t.html
This is the 15" Sendel S20T with Goodyear Endurance ST225/75R/15 tire on the right that replaced the original 16" ION spare wheel with passenger tire on the left, both fit in the smaller fiberglass spare tire housing that will not accommodate a LT225/75R/16 tire/wheel assembly.
This is the fact I got mixed up. I’m going to have to see what’s printed on our OEM wheels.
So OTT put 60 PSI wheels on Hull #75 in 2015! Does your hull have a DOT sticker stating 80 PSI! Mine does.
It’s got the DOT tag, but I need to look at it, I don’t keep Ollie at home.
Good decision, Bill. Looks like you're upgrading in Load and PSI rating. I believe the ones you're buying are the 4th row on their website table, 15"x6" with a 6/5.5" bolt pattern. Big improvement at 3200 LB @ 95 PSI ratings! Not that we need a wheel that strong. That 60 PSI on the OEM wheels gets me.
S20-56655T-2+ 101073 S1050-425CC / 46879 15X6 6/5.50 0 4.25 3200 @ 95 PSI
Here’s a photo of the inside of my original 2017 (hull 208) wheels. You can zoom in and see all of the specifications including the 110 psi pressure rating and load rating for the wheel! I took the picture when the trailer was new and filed it for future reference.IMG_3627.thumb.jpeg.6d9af5ff18d3e0b7ba5f6ffd17d4cb36.jpeg
2017 Elite II, Hull #208
2019 Chevy HD 2500 Duramax
Check it out. Ken’s wheel is also the SenDel brand. I remember a weight rating something like his wheel.
Looking at my exterior picture, I'll bet ours is a SenDel as well. You can see it has a simple face without all the studs like the ION wheel. Hull #75 is certainly a special one-off Oliver! 😎
Edited by jd1923
You can see from my truck I'm not afraid to stick out like a sore thumb 😅Thanks for not taking offense. Really I'm just figuring this out for myself, I wasn't designed to take things for granted.
On the 1750's I was a skeptic, then mostly a convert, but its still pending taking data. Here I'm a skeptic of airing down, don't expect to convert, but also am waiting for data. I suspect I'll end up with 1750's and 65 PSI, but we'll see. Most likely is it's much ado about nothing regardless I wonder.
Quote
Yeah personal experience towing back from the factory to California was two things. One the trailer did feel a bit soft and bouncy. Two, I'm quite sure I bottomed out the trailer suspension hard on numerous occasions. Arizona freeways in particular were pretty bad. Terrible porpoising around Albuquerque with bottoming, and hard bottom hits elsewhere. So bad you heard the slam. Anecdotally hand waving, but this makes me suspect a too compliant suspension. If you're worried about jarring, bottoming out is the equivalent of dropping the trailer on the ground with no suspension - high G.
At any rate reality is a b*** and as an engineer I'll tell you even the engineers don't know. It's often as much experience and windage than having a hard result. Most of the time we do what's being discussed. Design with extra margin/buffer (e.g. higher rating on the suspension and higher PSI range than lower), then measure in typical conditions. If it looks good, cross your fingers, hope for the best and keep taking data 😅
Yep, it's my understanding Oliver ran out of 3500lb axles & springs when they installed 5200lb axles & springs on #75. I can only guess the wheel & tire supplier made the mistake when supplying wheels for #75, we had the same original LT225/75R/16 Load Range E tires as many early LE2 Oliver owners.
My plan is to replace the ION wheels with 15" Sendel S20T trailer wheels with ST225/75R/15 tires mounted. The original 16" ION wheel's finish are in poor condition after 11 years. Going to check where I can get the best deal, Discount Tire will match wheel/tire prices. My goal is to have the same size & capacity wheels/tires as the spare tire (remember smaller spare tire housing on #75) using the same 15" ST tires Oliver currently installs on LE2 trailers. I will only lose about 1/2" of ground clearance.
GJ, the wheels & tires just got bumped to the top of the AFE list! 🙂
Appears to be legal changing trailer wheel/tire size if the change meets or exceeds the original wheel/tire capacities, but the ST tire has a lower speed rating compared to the LT tire. No one should be towing an Oliver close to the ST tire top speed anyway.
https://www.rvtravel.com/is-it-illegal-to-change-tire-type-or-size-on-an-rv-rvt-1086/
Sendel 15" S20T (S20-56655T-2+) wheel's capacity is 3200lbs @ 95psi.
Yeah personal experience towing back from the factory to California was two things. One the trailer did feel a bit soft and bouncy. Two, I'm quite sure I bottomed out the trailer suspension hard on numerous occasions. Arizona freeways in particular were pretty bad. Terrible porpoising around Albuquerque...
The OEM springs will keep you "soft and bouncy" and it will get worse with more miles. Running with more tire pressure, than the tire load tables spec, just isn't smart towing.
Terrible roads in most states, NM worse than AZ! We traveled to Minnesota and back last year (still had D35 axles and OEM 1750 springs), headed east and a big loop NW and back. Kansas highways were amazing in excellent condition. Western Colorado surprised me as being very nice roads. Texas roads are good in most places. Most other places, you bouncy around, potholes and bridge seems that will bottom out the Oliver (if still on OEM springs).
@Geronimo John went with Dexter 2400 LB rated springs to save $$$, not sure why else? My take, they're made with the same China steel and heavier weight does not mean they cannot fail structurally in the same way as the lighter model. Go with the Alcan 4-pack if you're OK with spending some more and want less spring. The Alcan 5-pack is perfect for us and I would NEVER go back! 😎
Like your last comment! I've had issues with the sanity of Design Engineers my entire life! 🤣
Sorry JD, I'm not even going to bite on that one.....
Maybe you should re-read all 27? pages of that thread.  LOL
  • Sad 1
FYI those with later model 16” Sumec wheels.   I checked an older photo I had from my 2021 E2 and can see weight rating  is 3300 lbs.   I cannot see the max pressure rating on the photo but will check next time I have the wheels off.    Although not as beefy as the older 16” Sendel wheels, it’s re-assuring that they are more than adequate.
Good to know
Quote
To be fair - says the forum (Disclaimer: see blow). The manufacturer says differently. Handwaving arguments about Oliver having been wrong before, went overboard initially with 80 psi, this and that are not evidence that their recommendation today is wrong. I spent an hour looking for current documentation from Goodyear and couldn’t find it - have a link? There’s an old 2017 pdf, and a couple tables of indeterminant provenance that get reposted. I suspect Goodyear is not posting this information anymore and leaving to OEM’s. So having some tables isn’t convincing to me.
I did find a lot of engineering common practice information which warns against too low a pressure for safety reasons, not too high. Low pressures are commonly used for low speed offroad traction use cases. I’m not seeing it done to avoid jounce. Does anybody here lower their TV pressures? Why not? I don’t understand why it’s OK for our trucks to be at specified pressures, but not our trailers. Or our cars. If your wife complained about a bumpy ride would you drop her pressures in half? Think about that for a second, now it becomes a safety issue.
But this is me handwaving now. As it happens, today I’m mooch camping for a family thing (poor me writing from my Ollie tonight 😅). I didn’t take measurements because I needed my phone on the way out. One the way back I’ll definately be taking measurements and analyzing. Specifically doing a spectral power density and comparing it to some example charts. This won’t be definitive - nothing is definitive. But it will be a demonstration of how much of the road rumble makes it past the suspension. Little point discussing it more until we have data - that’s for sticking with me
Disclaimer: I’m an engineer and for 40 years have been arguing technical points with others as a part of the job, just business as usual and no feelings involved. Take this discussion in that spirit - a search for best practices and not a keyboard warrior food fight. I’m happy when others disagree, I don’t claim to be always right, but through a healthy discussion can perhaps get somewhere. Reality is the final arbiter as my EV 6k trip proved, and I’m planning on doing the same here and will be delighted to find if I’m dead wrong. With the springs discussion for example you saw me switch sides (pending data)
Of course, when towing fully loaded, run the specified PSI listed on the DOT label which is calculated to be safe at the full GVWR.
But for example, when driving a pickup around town, no cap installed and empty bed, and I know I won't be towing or carrying a load for days on-end, I’m certainly not running the rears at 80 PSI! I'll bring them down to 60-65 PSI so the rear axle won't be bouncing down the street without a load to carry!
On my sports cars, I run higher pressures, because I like a slight skid into a hard turn! I owned a 1975 Alfa Spyder during my 20s, through my 40s and learned over many miles. Now I run my 1992 Lexus SC400 a few LBS over spec and the car handles like a dream. 😎 There is a reason tire pressure is adjustable!
And Yep, we air down our AWD GX470 when we have a bit of weather or washboard dirt to travel. But on this truck, I upgraded the OEM P-rated tires to LT tires C-Load Range. (didn't want the harshness of E-Load tires for this application). The DOT label states 32 PSI, but LT tires don't stand up nicely at pressure this low (also 32 PSI is below the lowest level on the Cooper load table for this A/T tire). For around town and highway driving, I chose to run 44 PSI, but we air down as low as 24 PSI for a day out playing in the dirt. I put a bit of thinking in what works best for the situation. Engineers and manufactures often wrongly use the "one size fits all" approach, and when lawyers get into the mix, they just throw physics right out the window in lieu of Indemnification! 😒
The DOT label on our relatively light TV, a 2WD long-bed capless truck is 55/80 PSI at 8800 GVWR. Our 2WD truck is hundreds of LBS lighter than its 4WD counterpart. After we setup camp, the truck is only 6800 LBS with all passengers and tools. Add all our camping stuff, the 35-gal tank full of fresh water, the bed fridge pretty full, plus 580 LBS measured tongue weight and we’re still 500 under the GVWR, fully packed for a long trip! I regularly run slightly lower than the GVWR at 52/72 PSI for our combination of state and county highways, dirt and gravel roads. At 80 PSI, when our TV rears hit the bottom of a dirt wash (think 2WD), they could spin some, but less likely with a little less pressure. When we traveled more on Interstates, like our Minnesota trip last summer, I increased the rears to 78 PSI, while 80 PSI is the stated MAX.
Dan, I do agree that engineers should speak their mind. I too often get accused! 😎
On 4/21/2026 at 5:09 PM, jd1923 said:
Do they also print a weight rating? The OEM wheels are rated for 80 PSI, but 60 is all you need with margin. The OEM wheels are weight rated, don’t remember exactly, but the 4 added to 11K+, so with D52, Alcan springs on Load E tires and OEM wheels, it’s only Oliver frame capacity keeping these from being actual (not legal) 10K GTWR! I would hope the frame is also over-engineered!
Mr. Jim Oliver told me personally that the frame was engineered to support 3X the GVWR. He stated that it was good to 21,000 pounds. Actually Oliver's GVWR of only 7000 pounds is due to their continued use of the underrated four leaf spring pack (the same ones that are breaking). This causes the otherwise 5200 pound Nev-R-Lube axle to be de-rated to 3500 pounds each.
  • Love 2
On 4/21/2026 at 1:42 PM, rideandfly said:
I only run 40PSI @ 5100lb ready to camp weight with the ION wheels that came on our Ollie. Another piece of interesting information is it looks like the maximum pressure for these particular wheels, 60PSI.
Started suspension maintenance today, so got a pic of the back of our wheels. I can zoom in, to see the SenDel brand trailer wheels, made in China, 6x16jj rims, 110 PSI Max, 3,200 LBS load rating.
Edited by jd1923
Received new SenDel S20 wheels to install on our Oliver replacing the original ION wheels. Purchased 16X6 wheels, installing the LT225/75R/16 Coopers already mounted on Ion wheels for two more years, before replacing tires.
#75 tag, Installed Goodyear Endurance ST225/75R/15E 80PSI spare tire mounted on SenDel S20 15X6 3200lb wheel, since a LT225/75R/16E will not fit in the 2015 fiberglass spare tire housing:
Nice Bill, your new Sendel wheels are beautiful 😎 and a little stronger than their same model of 10 years ago. I was wondering why the load on mine stated 110 PSI with both 3,200 and 3,750 LBS weights listed?
Yours has PSI ratings 80 / 100 and load ratings 3,300 and 3,960 LBS, so the load weights must be based on the two PSI numbers. Most of us run 45 - 55 PSI and carry 6K +/- LBS GVW.
I built a weight table for our upgraded Oliver Suspension:
If your still towing on OEM Dexter 1750 springs, then 7K is Max and you should worry about this common point of failure until you upgrade. Installed the 4-pack Alcan set? Then @ 2,250 each, 9,000 LBS is the Max Load. Oliver EII DOT stickers all state 7,000 GVWR anyway.
On 4/27/2026 at 9:36 AM, ScubaRx said:
Jim Oliver told me the frame was engineered to support 3X the GVWR.
If you've seen Steve's custom interior work and other additions, the weight of Hull #50 is right up there at the top in Oliver GVW! 3x may be an exaggeration, but if it's >10K then we have a 10K suspension with these upgrades, legal or not.
