jd1923 Posted Friday at 09:23 PM Share Posted Friday at 09:23 PM In what I've read so far, at least @Overland and @Ty J, and more recently @rideadeuce have upgraded to the Victron 3KVA Multiplus or MPII. Maybe others? If I remember correctly, Overland installed the original Multiplus and others went with MPII. Does the Multiplus II truly have necessary features. I read 1 amp less draw on stand-by, thinner (but not actually smaller), anything else? I see just fitting the Multiplus in my current Xantrex location (rear dinette seat), where the MPII would certainly be too long. I'd like to avoid adding extra 12V cable length installing it under the bed area or front dinette seat, though there is nothing but room up front and I haven't yet moved that bed since I've been working on the other side. Overland worked a novel installation! He also stated (cannot find the quote today), something like you could keep the batteries in the battery bay or install the inverter there (he wrote it better). Wow, thank you, that got me thinking! Overland also commented the Multiplus was not noisy except when supplying a large AC load or upon shore power connection/bulk charging. It is quiet enough under the dinette seat when just using small AC appliances like when watching TV? Is the MPII truly more efficient? Could it be quieter? I just purchased two 300AH Epoch batteries and I cannot believe FedEx tracking says they will be here on Tuesday. It only makes sense to work these installs together. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
rich.dev Posted Friday at 09:52 PM Share Posted Friday at 09:52 PM Just waiting for the Xantrex 3000 in our 2023 to kick the bucket when I will definitely upgrade to the Victron multiplus II, mainly for the power assist/load sharing functionality of it….explained nicely in this video. 1 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Solar, 3000W Xantrex Inverter) Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted Friday at 10:10 PM Moderators Share Posted Friday at 10:10 PM 17 minutes ago, rich.dev said: Just waiting for the Xantrex 3000 in our 2023 to kick the bucket when I will definitely upgrade to the Victron multiplus II, mainly for the power assist/load sharing functionality of it….explained nicely in this video. We rarely replace working equipment, also. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
jd1923 Posted Saturday at 02:56 AM Author Share Posted Saturday at 02:56 AM @rich.dev has the 3KW Xantrex. I hope your model has built-in ATS. I'm replacing for sure and will purchase next week now that our batteries are on the way. My criteria for replacing is the 2KW inverter is first that it's borderline on running the A/C for any period of time in HOT conditions. Also, I've never purchased an inverter without built-in ATS, can't have the goofy 15A outlets. Those are for those that cannot wire an AC outlet, just plug in the blow dryer right into the inverter! 🤣 My inverter must have built-in ATS with hardwired 120V AC IN and OUT terminals (I also want to know if the Victron Multiplus fails, is the fail-safe condition is that it still allows pass-thru shore power AC). So, back to the questions posed above... Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
katanapilot Posted Saturday at 10:55 AM Share Posted Saturday at 10:55 AM Following. Our Victron MPII just arrived, along with all of the other Victron equipment. Install to commence next week. Like others, the power assist mode was the primary driver. I found when running on generator power (dual Honda EU2200i) paralleled and in ECO mode, the generators could not start our Houghton heat pump. So I had to run them with ECO mode off all the time. I'm hoping that with power assist from the Victron, I can run the Honda's in ECO mode and still start the Houghton. Considered adding soft start too, but will wait and see if the power assist works as advertised. 1 2020 Elite II Hull #628, Houghton Heat Pump, Victron install in progress... TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension Link to comment Share on other sites More sharing options...
Ronbrink Posted Saturday at 01:34 PM Share Posted Saturday at 01:34 PM 10 hours ago, jd1923 said: Also, I've never purchased an inverter without built-in ATS From viewing the above video, the Victron Quattro is the only inverter said to have a built-in ATS. Just passing on what I heard, however should be verified. 2020 OLEll, Twin, 579 2012 Silverado 1500 4x4 No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, Hughes Autoformer, dual Lagun tables Link to comment Share on other sites More sharing options...
jd1923 Posted Saturday at 06:05 PM Author Share Posted Saturday at 06:05 PM 3 hours ago, Ronbrink said: From viewing the above video, the Victron Quattro is the only inverter said to have a built-in ATS. Just passing on what I heard, however should be verified. From the Mulitplus manual: "Automatic and uninterruptible switching In the event of a supply failure or when the generating set is switched off, the MultiPlus will switch over to inverter operation and take over the supply of the connected devices. This is done so quickly that operation of computers and other electronic devices is not disturbed (Uninterruptible Power Supply or UPS functionality). This makes the MultiPlus highly suitable as an emergency power system in industrial and telecommunication applications." The ability for the inverter to choose between an AC source or DC battery power is what I meant by internal ATS and ALL Victron 3KW inverter/chargers (and greater models) have this functionality. They all also have Power Assist, which is not only internal switching but smart partial switching when shore power is lacking in covering the full load, it pulls what's necessary from the battery bank. Another way to word this is these more capable inverters do not require an external switch, like the Xantrex PROwatt SW (see pic1) or the KISAE TS20 that some of us have added to switch the air conditioning between AC/DC. The common usage of the term ATS in a RV is the switching between generator and shore power, like the PD5100 (see pic2) installed in our Olivers. The Quattro can switch AC/DC uninterruptable as the Multiplus and ALSO has the capability to switch between 2 AC sources like the PD5100, hence the PD could be eliminated if installing a Quattro. I thought about this for about a second, but it's more expensive and I'm not running a generator anyway with a 3KW inverter and 600AH in new LiFePO4 batteries. I had a PD5100 fry in our Bigfoot RV that I replaced, but if it does so in the Oliver with this upgrade we'll just run on the inverter. It's funny in the video, he used the name Multiplus all through the video and in his last sentence he said "Quattro." The 3KW Multiplus, MPII, Quattro, and other high-end models, all have a 50A line1 output. In my hull the Xantrex PROwatt SW is wired to all AC circuits but the air conditioner. The purpose of the KISAE TS20 is to add another ATS for the air. When the Multiplus is installed, given 50A output for a 30A panel, it will be wired to all loads on the panel, including the air conditioner, and no need for external switches like the Xantrex PROwatt SW and KISEA TS20! Why not? 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
Ronbrink Posted Saturday at 06:54 PM Share Posted Saturday at 06:54 PM I’m glad I part my hair down the middle! 1 2020 OLEll, Twin, 579 2012 Silverado 1500 4x4 No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, Hughes Autoformer, dual Lagun tables Link to comment Share on other sites More sharing options...
rich.dev Posted Saturday at 07:49 PM Share Posted Saturday at 07:49 PM 16 hours ago, jd1923 said: has the 3KW Xantrex. I hope your model has built-in ATS. What is automatic AC transfer switching? All Xantrex Inverter/Chargers incorporate an automatic transfer switch. This switch senses when outside AC Power is present and transfers the load from the inverter to the source of incoming power (shore or generator). The unit also automatically switches from invert mode to charge mode. 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Solar, 3000W Xantrex Inverter) Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison Link to comment Share on other sites More sharing options...
jd1923 Posted Saturday at 08:21 PM Author Share Posted Saturday at 08:21 PM 29 minutes ago, rich.dev said: All Xantrex Inverter/Chargers incorporate an automatic transfer switch... That's a good way of wording it. My 2WK Xantrex is inverter only (no charger and no ATS). All it does is supply 120V AC to two plug-in outlets. The switching in this system occurs in the PROwatt SW, an external switch. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted Saturday at 11:17 PM Moderators Share Posted Saturday at 11:17 PM https://www.currentconnected.com/product/victron-48v-multiplus-2-5kva-120v-inverter-70a-charger/ 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
jd1923 Posted Saturday at 11:50 PM Author Share Posted Saturday at 11:50 PM 12 hours ago, katanapilot said: Our Victron MPII just arrived, along with all of the other Victron equipment. Install to commence next week. Why MPII vs. original Multiplus? What other Victron HW? Thanks Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
rideadeuce Posted Sunday at 12:24 AM Share Posted Sunday at 12:24 AM 13 hours ago, katanapilot said: Following. Our Victron MPII just arrived, along with all of the other Victron equipment. Install to commence next week. Like others, the power assist mode was the primary driver. I found when running on generator power (dual Honda EU2200i) paralleled and in ECO mode, the generators could not start our Houghton heat pump. So I had to run them with ECO mode off all the time. I'm hoping that with power assist from the Victron, I can run the Honda's in ECO mode and still start the Houghton. Considered adding soft start too, but will wait and see if the power assist works as advertised. I would install the SoftStart. It will make everything run smoother and more efficiently, even if MP2 can run AC without it. "From the Dometic Penguin II label. Compressor surge rating of 52a, higher than the Atmos, which is 48a. The Dometic 52a translates to 6240w and 480a at 13vdc. A Xantrex Freedom XC Pro 3000w Inverter has a surge rating of 6000w. The MP2 has a surge rating of 5500 watts. So, no RV air conditioner above 13k BTU should be run from Inverters and Lithium batteries without a soft start added. The Truma Aventa has an even higher surge rate of 58a." From Sprinter van forum that is very informative on this topic. Even if you have a 11k BTU of lower surge rating, it still makes sense to install SoftStart. The people installing the Atmos for me recommended it as well. Power assist as I understand it and used so far is helpful when connected to shore power not boon docking or traveling. Best, Mike - Mike Nashville, TN 2018 Elite II - Spirit of Adventure Hull #308 - Toyota Tundra Link to comment Share on other sites More sharing options...
rideadeuce Posted Sunday at 12:38 AM Share Posted Sunday at 12:38 AM 36 minutes ago, jd1923 said: Why MPII vs. original Multiplus? What other Victron HW? Thanks The MultiPlus-II combines the functions of the MultiPlus and the MultiGrid. It has all the features of the MultiPlus, plus an external current transformer option to implement PowerControl and PowerAssist and to optimize self-consumption with external current sensing (max. 32A). - Victron The MultiPlus-II is a newer model; it is also a single inverter/charger unit, but it has some improvements over the original MultiPlus. It has a more powerful microprocessor, which allows it to provide more accurate and precise control over the charging process. - Victron MP-II form factor is longer and slimmer. So, depending on install may be easier to mount. Idle power draw is less for the MP2 11w vs 25w for the original. Having installed it, in retrospect, I might look at using Victron Lynx power distribution instead of DIY bus bars. A lot to think about. Best, Mike 1 1 - Mike Nashville, TN 2018 Elite II - Spirit of Adventure Hull #308 - Toyota Tundra Link to comment Share on other sites More sharing options...
jd1923 Posted Sunday at 02:52 AM Author Share Posted Sunday at 02:52 AM 2 hours ago, rideadeuce said: Power assist as I understand it and used so far is helpful when connected to shore power not boon docking or traveling. Given the PD5100 ATS, the MP inverter would treat a small generator as a form of under-powered shore power and the Power Assist would kick in, adding required power. But yes, adding the SoftStart lowers the initial surge to allow running on a household 15A circuit without tripping a breaker. The extra features of the MP2, I will likely not use. It is the dimensions and +1AH more on idle is 24AH per day. Still what fits best will make the decision. Next week I will open all street-side basement panels, measure, plan, decide and purchase. Given the MP2 is better, why can I buy one for $997 and the MP is $1,169, from authorized dealers. Another point for the MP2! 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted Sunday at 09:44 PM Moderators Share Posted Sunday at 09:44 PM You may want to call Victron or Victron rep and have a chat. They're both great units. Same warranty. Some many discussions on victron forum https://community.victronenergy.com/questions/63741/difference-between-multiplus-and-multiplus-ii.html 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
rideadeuce Posted Sunday at 10:48 PM Share Posted Sunday at 10:48 PM 19 hours ago, jd1923 said: Given the PD5100 ATS, the MP inverter would treat a small generator as a form of under-powered shore power and the Power Assist would kick in, adding required power. I have already forgotten about using the generator traveling down the road and the usefulness of the power assist probably because I used a Yamaha propane generator that ran the PII without difficulty with a soft start. Since converting to lithium I have forgotten about it already. I was thinking from a lithium powered standpoint. It would be useful for an owner trying to use a smaller generator. - Mike Nashville, TN 2018 Elite II - Spirit of Adventure Hull #308 - Toyota Tundra Link to comment Share on other sites More sharing options...
Ronbrink Posted 18 hours ago Share Posted 18 hours ago On 7/13/2024 at 7:24 PM, rideadeuce said: From Sprinter van forum that is very informative on this topic. There is a new post and a video in said forum of interest; in short, more corrections to misinformation. Anyone considering a Gree (Eco Cool/Atmos 4.4) product should take time to read/watch the very pertinent information and discussions provided therein. I have learned nothing that would change my mind about purchasing an Atmos 4.4, looking forward to my pending delivery and details on your install. 2020 OLEll, Twin, 579 2012 Silverado 1500 4x4 No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, Hughes Autoformer, dual Lagun tables Link to comment Share on other sites More sharing options...
MAX Burner Posted 18 hours ago Share Posted 18 hours ago On 7/13/2024 at 6:38 PM, rideadeuce said: I might look at using Victron Lynx power distribution instead of DIY bus bars. We're definitely considering the Lynx PD unit as well for when we drop the hammer on upgrading to the MPII - its a very clean option as compared to our Blue Seas bus bar, IMO. 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
