The white neoprene rubber (I think) gasket that is installed just below the awning to sort of but not really divert water on my Elite II was deteriorating and rotting significantly. This afternoon I finally decided to take the thing off which has now left a long line of black rubber where it was glued down. I have tried Acetone, denatured alcohol, naphtha, and mineral spirits to loosen or dissolve the remainder none of them worked. Its my understanding heat guns will only harden neoprene and it doesn't sound like a safe method around FG anyway.
For those of you who have removed this gasket just curious what method you used to remove the final residue?
Thanks
Edited by routlaw
Legacy Elite II #70
Thanks
Use a plastic razorblade in conjunction with a safe solvent. There have been several who have removed that gasket. Hopefully they will chime in.
Same here - orange plastic razor blades and Goof Off worked for getting ours off...
  • (SOLD) 2022 TUNDRA
Thanks for all the suggestions. Was able to remove it with bug and tar remover but still a lot of messy work. Will do a final clean, polish/wax later today if it doesn’t rain. Not sure why Oliver ever made the decision to install these things in the first place. All mine ever did was create a damn for debris and organic detritus.
Thanks again.
Legacy Elite II #70
It's for those of us who live in rainy climates, and don't want a waterfall running down the side of the trailer, and soaking everything within a couple of feet. It has rained every single trip except one since we bought our trailer! ⛈️😠⛈️
  • Like 7
Steve - Northern Ohio, USA
Facebook - Instagram
Yep. I get home and spray all along there. Then follow up with mop and soap. I would never consider removing it. To each his own🙃
I pulled ours off after 4 years, it came off cleanly with very little residue.  Haven’t missed it…. Mike
Must be something with that Texas heat, took me a few hours of really messy work. You are lucky.
Legacy Elite II #70
Never seen one. If ours had one, a prior owner removed it. We haven't camped a rainy day, yet! 🤣
If I ever decided to remove it, I would consider installing the 1/2" rain gutter the entire length and as close to the awning so it didn't stick out and look unsightly. That way the area would be open and easy to clean, and keep most of the rain out.
This "awning dam" appears to be a geographically necessary option.  In the Great SW USA, we haven't missed ours in the least - however, if we lived east of the Mississippi, we'd probably have left it up there!  Cheers, all!
