Steve Morris Posted October 28 Share Posted October 28 I've seen similar filter and water softener additions. Here's mine. I recently saw that James at FitRV released a single 2.5" X 10" water filter element to replace the standard 3-stage system. I've considered one of the smaller 3-stage systems as an upgrade, so I thought I'd give this a try as a less expensive alternative. Of course using one 3-stage filter instead of three separate filters is going to mean a shorter interval between replacement. But the cost difference should be negligible, and I won't have to find a place to store a 3-stage system. Here's the FitRV video and article: YouTube: https://youtu.be/t_SQNVapBEw?si=FfufAl7n4p_80Eys Web article: https://www.thefitrv.com/rv-tech/our-new-rv-water-filter-the-fit-rv-3-in-1-filter/ I bought a cheap filter canister from Amazon, that arrived with horribly oversized 3/4" NPT pipe threads, and enough slop that the filter moved over 1/8" up and down. That's not going to work at all, so back it went and a GE housing was ordered. Much better! I assembled with a 3/4" NPT to 3/4" GHT (garden hose thread) on each end; one male-to-male, and the other male-to-female. Then I gave it a test fit on Curiosity's rear bumper. Dummy! The hoses would interfere with the trailer body and the drop down sewers cover. :facepalm: Back to Amazon for a pair of 90° 3/4" GHT male-to-female connectors. In hindsight, I should have used a 90° 3/4 NPT to 3/4 GHT set, but looking today, I couldn't find that combination. This also allowed me some flexibility in the angle of the input and output. Back when I ordered the Oliver, and spent those agonizing months waiting for delivery day, I accumulated a bunch of bits and pieces to get ready to go. (Didn't we all?) One was an adjustable water pressure regulator. I didn't realize that Oliver would supply a fixed 40 PSI inline regulator, and the inline unit was convenient to store with the Camco inline water filters I've been using. So now's the opportunity to get it off the garage shelf and put it to use! I drilled and tapped two threads into the side of the bumper support, and screwed and LocTited in two stainless screws. These are used to hang the whole contraption while in use. It'll be stored in my bucket during transport. I hope this is helpful for anyone wanting to upgrade from an inline water filter. List of components: GE Filter Housing: https://a.co/d/7cbaS28 FitRV 3-in-one filter: https://a.co/d/b0NzDt8 Camco 4' Potable Water Hose: https://a.co/d/eVeV4BJ 3/4" NPT to 3/4" GHT fitting: male-to-male (2-pack): https://a.co/d/5MopLFL 3/4" NPT to 3/4" GHT fitting: male-to-female 2-pack): https://a.co/d/dE1gWDC 90° 3/4" GHT Elbow: male-to-female (2-pack): https://a.co/d/24kw8xO Teflon tape for NPT threads Total cost: $133 plus tax Question: The fixed pressure regulator that came with the Oliver is 40 PSI. I've set the adjustable water pressure regulator to the same 40 PSI. What pressure do those of you with adjustable regulators use? 2 8 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray Link to comment Share on other sites More sharing options...
Geronimo John Posted October 29 Share Posted October 29 (edited) Very excellent post. I am sure many OTT owners will follow your lead. I especially like your mounting concept. When being used, it is secure and out of the way. Since your picture shows it feeding water to the fresh water tank, I suspect that when the tank is full, you secure the system elsewhere. One possible alternative to the "Black Water Area" of the OTT trailers would be to use you exact set-up, but drill the holes into the Basement Storage area lid. (Using flat stock on the inside for reinforcement). This alternative mounting location would get it away from potential contamination of the OTT sewer outlet leakage and Black/Gray tank dump process. Additionally benefit is it would be higher and easier to use for some of us RoF's. 🙂 Other than that I think you have hit a home run! GJ Edited October 29 by Geronimo John 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trany, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
jd1923 Posted October 29 Share Posted October 29 5 hours ago, Steve Morris said: Question: The fixed pressure regulator that came with the Oliver is 40 PSI. I've set the adjustable water pressure regulator to the same 40 PSI. What pressure do those of you with adjustable regulators use? Steve, this is an excellent mod! I had not heard of a 3-stage in one filter and shorter filter life is fine for us who travel occasionally. I spent double building a dual filter system with Clearsource components an it’s heavy / bulky. Your build is perfect! Your water pump is likely 50 PSI or more. I installed a variable speed pump at 60 PSI. You can run anywhere in the 40-60 PSI range. PEX is rated at 100 PSI. Our older hull has built-in pressure restrictors, not regulators, which can be seen in this picture. The plumbing diagram only shows back flow preventers, but it has both inline devices on Fresh and City water inlets. They truly impede water flow and I will remove ours eventually and add an external adjustable regulator like yours. if we use the City water connection, the water flow rate is poor due to the restrictor. When we fill the Fresh Water tank, it fills slowly, but the onboard pump delivers much better pressure. Not sure if all Olivers have the internal restrictor but something to look into since whatever pressure you’re setting it reduces the flow rate (GPM) at the faucets. 1 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
Patriot Posted October 29 Share Posted October 29 (edited) Steve, Very nice install. I purchased and installed these Ely quick connects on my city and fresh tank connectors a few years ago on XPLOR. They are a little pricey but 💯 brass and USA 🇺🇸 made not CCP 🇨🇳 junk. They really do make quick work of hooking up your water sources during take set up or take down of your base camp. One of my top smaller mods for sure. https://www.eleyhosereels.com/products/garden-hose-quick-connectors?_pos=1&_sid=dc579a2e3&_ss=r Edited October 29 by Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸 https://olivertraveltrailers.com/forums/uploads/monthly_2024_11/MAP.jpg.50b5b70e70e454e07f7750b90d6f166f.jpg Link to comment Share on other sites More sharing options...
Steve Morris Posted October 29 Author Share Posted October 29 8 hours ago, Geronimo John said: Since your picture shows it feeding water to the fresh water tank, I suspect that when the tank is full, you secure the system elsewhere. Honestly, I just hooked it up for the photo, and didn’t look at which port I attached it to. 🤪 Usually, I fill up at home without a filter for trips under a week. I use the filter when on full hookups or when we need to refill on the road. Heading to Florida for two months this winter, any the timely release of this new FitRV 3-in-1 filter prompted this upgrade. I considered the proximity of the hanging location to the septic outlet. But we rarely use full hookups sites. The filter would be stored in my bucket at a dump station (which we also rarely use, as I use a macerator pump at home into my septic tank for trips under a week.) Hanging on the basement door would work and maybe be a more sanitary location. I’m in the basement frequently, so not ideal in full hookup settings. Both have compromises. It could be placed in a stand on the ground, too, and moved under the trailer. Lots of options. Thanks for your input! 3 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray Link to comment Share on other sites More sharing options...
Steve Morris Posted October 29 Author Share Posted October 29 6 minutes ago, Patriot said: I purchased and installed these Ely quick connects on my city and fresh tank connectors a few years ago on XPLOR. Thanks, David What do you use to cover them to prevent contamination and dirt while on the road? ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray Link to comment Share on other sites More sharing options...
rideadeuce Posted October 29 Share Posted October 29 (edited) 1 hour ago, Steve Morris said: Thanks, David What do you use to cover them to prevent contamination and dirt while on the road? https://www.rvwaterfilterstore.com/products/kwik-link-connect-system-90?srsltid=AfmBOoqDmJNms7camHGuO4lzVh1ExSXi1dzYkfr0DoPzl1VMP0qVfYAE Similar quality to Eley products and they come with a cover. I have had them in use on all water connections for 6 years. Work great. They use to have one that was less than 90 degrees, worked great on the city and fresh water inlets. But I don’t see it now. I zip tied the OEM threaded cover to the rubber cover to keep it safe and out of the way. Leaving the QC on semi-permanently and then attaching QC to all your hoses makes setup and takedown much easier and quicker. 120 degree? 90 degree Edited October 29 by rideadeuce 1 1 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar, Custom rear bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires Link to comment Share on other sites More sharing options...
Steve Morris Posted October 29 Author Share Posted October 29 (edited) 4 hours ago, Patriot said: They are a little pricey but 💯 brass and USA 🇺🇸 made not CCP 🇨🇳 junk. Unfortunately, not since 2006. 🤨 They list the couplings under "Watering Tools" Fabrication & Packaging United States - Garden Hose (Reno, NV) China - Hose Reels & Watering Tools 2 hours ago, rideadeuce said: They use to have one that was less than 90 degrees, worked great on the city and fresh water inlets That's an interesting idea! 45° or 60° would have been great. I'm not sure coming in from straight down would be beneficial. Edited October 29 by Steve Morris 2 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray Link to comment Share on other sites More sharing options...
Patriot Posted October 29 Share Posted October 29 (edited) 10 hours ago, Steve Morris said: Thanks, David What do you use to cover them to prevent contamination and dirt while on the road? Never had an issue with contamination or dirt, I use the OEM black caps on a chain. This method has served us well. Edited October 29 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸 https://olivertraveltrailers.com/forums/uploads/monthly_2024_11/MAP.jpg.50b5b70e70e454e07f7750b90d6f166f.jpg Link to comment Share on other sites More sharing options...
Ronbrink Posted October 30 Share Posted October 30 23 hours ago, Patriot said: Steve, Very nice install. I purchased and installed these Ely quick connects on my city and fresh tank connectors a few years ago on XPLOR. They are a little pricey but 💯 brass and USA 🇺🇸 made not CCP 🇨🇳 junk. They really do make quick work of hooking up your water sources during take set up or take down of your base camp. One of my top smaller mods for sure. https://www.eleyhosereels.com/products/garden-hose-quick-connectors?_pos=1&_sid=dc579a2e3&_ss=r I did the same couple years ago, easy one-hand operation and full hose flow to boot! 1 2 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, Hughes Autoformer, dual Lagun tables, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Dreiha Atmos 4.4 a/c upgrade. 2019 GMC Savana 2500 Cargo Van: 6.0L V8 Vortec, 6-Speed Automatic; Explorer Limited SE, Low-Top 7 Passenger van conversion, RWD. Link to comment Share on other sites More sharing options...
