rideadeuce Posted February 19 Posted February 19 After 7 years, the CO/propane detector needed replacement. The alarm stayed on and wouldn’t reset. Got on Amazon and ordered the one linked below, perfect fit. Says to replace every 5 years. 2 min. Job. Even came with its own quick connects. I know there are previous posts about this, just thought I would update with a new one since this topic will be coming up for others soon. Amazon link: https://a.co/d/eDhKYr5 NEW ONE OLD ONE 3 4 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
chuckstovall Posted February 26 Posted February 26 (edited) Thanks rideaduece. Same boat here and ordered the same replacement. I do notice that the Atwood had 2 red wires and 1 black and the RV brand one only requires 1 red and 1 black. I'm assuming you just twisted the 2 reds together to attach to the red on the RV detector? Edited February 26 by chuckstovall 2
Derek B Posted February 26 Posted February 26 19 hours ago, chuckstovall said: Atwood had 2 red wires and 1 black I did this swap few weeks ago and immediately noticed the same thing, however once started tracing the red wire back and pulled back some of the wire loom found the red wire is one wire coming from power source with a y splice to make 2 red wires. I just cut the red wire at the splice and ran 1 red to new detector. 1 2 1 Derek and Deana | 2019 LE II, Hull #484 | 2023 F150 EcoBoost | SE Louisiana
chuckstovall Posted February 26 Posted February 26 2 hours ago, Derek B said: I did this swap few weeks ago and immediately noticed the same thing, however once started tracing the red wire back and pulled back some of the wire loom found the red wire is one wire coming from power source with a y splice to make 2 red wires. I just cut the red wire at the splice and ran 1 red to new detector. Thanks Derek. Very easy swap.
John Dorrer Posted February 28 Posted February 28 Late last year a number of us experienced the alarm going off after winterizing with RV Antifreeze. I purchased the same one and used small Wago connectors. The install was easy. However I must have touched wire ends, as there was no power to the unit. Turns out I blew the fuse for it. This fuse is under the street side bed, below the 3 jack fuses and is black. I also carry a battery operated one as back up. 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
jd1923 Posted March 1 Posted March 1 2 hours ago, John Dorrer said: Turns out I blew the fuse for it. This fuse is under the street side bed, below the 3 jack fuses and is black. I wrote a mod post on this. I strongly suggest moving the bus under the street side bed to the area under the rear dinette seat. Blow a fuse and remove a bed, what was OTT thinking?! 🤣 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galileo Posted March 2 Posted March 2 On 2/28/2025 at 6:53 PM, jd1923 said: Blow a fuse and remove a bed, what was OTT thinking?! 🤣 We didn’t blow that fuse - but had to pull it when the original CO/Propane detector started throwing false alarms - at 3am of course. No fun being awakened without real cause, being deaf for 5 minutes, or having to dislodge the two panicked cats from the ceiling. And yes, it’s not an ideal location for a fuse. I was loathe to replace the failed detector - still supposedly WELL within its stated service life - with another unreliable one. So we ordered this one. https://a.co/d/3SUEvPm It sticks out a bit further, and it’s brown instead of white (which I actually like) but it has the advantage of actually having a readout that shows the propane or CO PPM that it’s detecting. 2 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Moderators topgun2 Posted March 2 Moderators Posted March 2 (edited) On 3/2/2025 at 4:26 AM, Galileo said: We didn’t blow that fuse - but had to pull it when the original CO/Propane detector started throwing false alarms - at 3am of course. There's a thread here on the Forum that deals with the installation of an on/off switch for this detector. This sure does make dealing with that errant detector a 2 or 3 in the morning a bunch easier. Note that the pic below shows the bracket for the switch with the opeing for the detector in the background. Also note that it is good practice in using this switch you also have a method of warning yourself that the detector has been turned off and that there is actually NO propane and/or CO present. 2 inch square bracket for propane switch.PDF Edited November 4 by mossemi added detail 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Galileo Posted March 2 Posted March 2 1 hour ago, topgun2 said: There's a thread here on the Forum that deals with the installation of an on/off switch for this detector. This sure does make dealing with that errant detector a 2 or 3 in the morning a bunch easier. Note that the pic below shows the bracket for the switch with the opeing for the detector in the background. Also note that it is good practice in using this switch you also have a method of warning yourself that the detector has been turned off and that there is actually NO propane and/or CO present. 2 inch square bracket for propane switch.jfif2 inch square bracket for propane switch.jfif2 inch square bracket for propane switch.jfif2 inch square bracket for propane switch. 246.65 kB · 3 downloads I guess if detector false alarms are common enough, the switch makes good sense. I’m sure some safety expert somewhere is shuddering at the thought of people selectively disabling their CO/propane detector. The “reminder” I have that my detector is inoperative is the replacement sitting on the counter goading me to install it. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Steph and Dud B Posted August 15 Posted August 15 We just replaced ours, 2 years before its expiration date, because of false alarms. It appears to have become hypersensitive and was alarming because of errant exhaust fumes coming from the Norcold fridge. 2 problems there. I sealed the large gap at the top of the lower fridge access panel with metal tape (discussed in another thread) and then I replaced the detector with a new one. I did the same as @John Dorrer, using Wago connectors to make the next replacement easier. 3 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
TimD Posted November 4 Posted November 4 That fuse placement is ridiculous. Once found it isn't hard to remove, but getting back in was a struggle. Hopefully it has been moved closer to the detector itself in current production. Tim
TimD Posted November 5 Posted November 5 Here's what I did to cover the hole formerly occupied by the OEM detector. The plywood is held in place with 2-sided tape, which is now under mild compression due to the tension of the backing plate screws. Screws are #6 x 3/4". Tim 1
