I have recharged, insulated, etc etc this Isotherm “not a fridge” in hull 1364. Still not a fridge. At best it takes 10 degrees off ambient.
Has anyone replaced the Isotherm with a Dometic or any other fridge that works? What model and mods were needed?
Need to figure this out because hauling a extra dometic cooler to replace the fridge when the weather is above freezing is getting old.
Current: 2023 Oliver Elite II - Hull #1364 "Reset 2.0" (Second Owner)
Tow Vehicle: 2023 Ford F-150 XLT 3.5L EcoBoost /w 3.55 axle and Max Tow Package "SIlver"
Original: 2022 Oliver Elite I - Hull #1030 "Reset" (Sold)
Original Tow Vehicle: 2022 Subaru Ascent "Blue Moose"
Home Base: Duncanville, TX
That’s weird, maybe an issue with the compressor? Our isotherm works great. Have you always had this issue with it?
**Sold😞**
If this has been occuring for sometime and you have a 2023 trailer, this should have fallen under warranty. Did you enter a service ticket with Oliver? Did you call Isotherm and get support. Most warranties on appliances are for 2 years, which means it should still be under warranty.
This doesn't make any sense. Can you please share what Oliver shared and what Isotherm technical support and their warranty department said.
Isotherm is a reliable work horse in the RV industry, and they have a great track record.
Edited by John Dorrer
Updated Comment
Unfortunately we purchased 1364 from the original owner, so no factory warranty for us. Jason looked at it when we were at the Texas Rally last year and suggested possibly putting additional insulation in the wall behind the fridge. I also got advice on recharging it. I thought I would have to put in a pin valve but I found the artfully concealed recharge port under the shrink tubing and tape.
I can’t even find anyone who will work on the thing (as hard as it is for me to admit I am out over my skies on this). I called the Isotherm dealer in Dallas who basically said they did not do service but if we wanted to roll the dice again and buy a new one they would be happy to help.
Currently it’s 77 in the evening here in Central Texas. The camper interior is 78.2 and the fridge is 60. The high point for the day (84 degrees high) was 62 - not sufficient to keep food safe. The overnight low on the fridge interior was 52.
I must admit I am stumped.
  • Sad 1
When we purchased the trailer the previous owners included the Chinese knockoff fridge freezer cooler that they used to keep food. As LE I owners we didn’t think much about that since we were used to the Tri Fuel and the small amount of space. We should have tested the fridge more. Our first trip to Colorado we pretty quickly learned to not keep anything we expected to be food safe in the Isotherm.
That is a bummer to have to deal with. Sorry this is happening. A mobile tech that is licensed by Isotherm would be a good direction to try
I guess my concern is that getting a mobile tech to come look at it will cost what a new one would, and then I would still have to buy the new one. (Facepalm)
Some people are scared of spiders, I’m scared of hiring skilled professionals 😆
You might be right and just replacing it. There are some size restrictions, so replacing it will most likely mean with the same unit.
If you have time to investigate other options look at the drawer fridge freezers. I know several of my old truck camper buddies installed the drawer type and were very happy.
Typo
I am totally unfamiliar with the Isotherm refrigerators, but the first thing I would check would be to make sure the compressor is actually running while temps are above the setpoint and if not then test the thermistor for correct resistance. I would also check to make sure that I'm getting full voltage to the unit, and that the condenser coils were clean and cooling fan(s) were operating if it has them. Could be a refrigerant leak that's causing it, but in my experience, more often than not it's something other than low refrigerant levels when there's a lack of cooling.
Probably for good reason!
  • Love 2
I replaced the Dometic 3 -way with the Canadian made Nova Kool R5810 with the tried and true danfoss compressor and it has been a terrific upgrade. So much so, I seldom check the temperature any more. One less headache. Good luck. There is some great information on installation from other forum members.
Although, I would try to dive deeper into why the fridge is not cooling as others above have stated. I don’t think it would be that much to have someone do some basic electrical diagnostics.
NOVA KOOL R5810 Selection and Installation (great PDF attached at the bottom of linked info) Guide link:
Edited by rideadeuce
When you got this advice, did you get pressure/temp specs for your exact model and have gauges on both the suction and discharge sides when charging? If not, it's very possible that you caused another issue on top of the original problem. Small systems like these have very precise charge amounts and they're almost always recharged by recovering whatever refrigerant is still in the system, evacuated, and then re-charged by using the weight of refrigerant required according to OEM specs.
Thanks all - I actually did find a mobile tech back at our home base that quoted me $280 for the visit - diagnose - and fix if no extra parts are required.Scheduling for Friday so I will update this with his findings.
Hopefully this is all fixable and my frustration will turn to delight.
 Nope - and yes being that refrigeration is not my wheelhouse you are likely correct.
I just read all the stuff that you real engineers do on the forum and convince myself that a computer “engineer” can do it to. 🤣
However, since we have an Oliver I never sleep in a Holiday Inn so should be careful with that.
I did stop a Chinese threat actor in 8 minutes last week, so that counts for something…. 😁
Edited by DunnYet
Had more to say - not more that was useful, just more.
Glad you found someone at a reasonable cost to check it out for you. Hope it's something simple and easily fixed!
Thank goodness, our 10-year-old OEM Dometic “absorption” fridge is still working like a champ!
God bless one past forum member, @John E Davies, argued emphatically that we all must replace these or likely when the trailer was not perfectly leveled, it would blow the side of our trailer clean off! (he showed pics of 100 occurrences). 🤣
Please notice the picture of our Ruuvi sensors last week while camping not far from home. We get better numbers most of the time (was near zero before we refilled an ice cube tray). I installed the Beech Lane dual fan system for when it’s hot and the numbers are equally as good when hot out!
When anybody finds a modern compressor fridge with a full, left-to-right freezer, let me know! This freezer holds 2 full ice cube trays, 2 steaks, 2 chops, some vacuum-sealed veggies and a half gallon of ice cream, that it keeps frozen!
Edited by jd1923
Our 16 year old Dometic is still going strong too. As long as I start it up 24 hours before leaving on a trip the temps stay in the 30's the whole time no matter the conditions. Adding external fans really helped and I have no idea why they weren't standard equipment.
  • 2 months later...
(Warning - rant which may or may not be justified.)
I promised an update after the RV Texh came out. Well - lesson learned. Not only are Isotherm refrigerators garbage, their business practices align quite tightly with their quality.
RV Tech found power board problems ($280) and called isotherm. Three weeks later Isotherm got back to him, said it would be under warrenty if he did an additional test. So today he came out and did the additional test. ($140) called Isotherm and they wanted him to bring in a different person to do an additional test. Oh and they have determined that, regardless of the test he did today, the unit is not covered under warranty as the warranty is not transferable.
So I spent $420 to learn what I already knew - it does not work. That’s spending a 1/3 rd of the cost of a new unit for absolutely no benefit.
Trying to call Isotherm tomorrow because I  think they should cover the $140 since they lied to the tech, but pretty sure that’s tilting at windmills.  But next time I’m just replacing whatever it is myself rather than having a professional tell me “it’s broke.”
  • Wow 2
  • Sad 2
DunnYet please check your private messages. I provided some general compressor fridge information and troubleshooting information as well. I had some electrical damage to the compressor inverter drive on my NovaKool fridge and had to replace the inverter. This was one example of the surge protector not being a good thing. We were at a campground that was having serious voltage issues and we were running the fridge on shore power. We were not at camp for most of this but caught some of the instances and shut everything down but a little too late for the fridge. The voltage would spike to about 190 volts then just as quickly drop back to 120. The spikes would occur in rapid succession so the surge protector would disconnect and reconnect just as rapidly. My fridge inverter was one that could run on dc or ac so would switch back and forth between ac and dc rapidly which damaged it. It probably would have operated just fine if left alone with no surge protector. It is capable of running on 120 to 240 volts ac 50-60 HZ or 12-24 volts dc and switches seamlessly between the two. With the voltage spiking to 190 I don’t think it would have even cared. Anyway you may just have a bad compressor inverter and yes the dc only ones are around $200 and the ac/dc ones are around $300. They are easily replaced being a simple one plug connection. If the Freon charge has not been lost (which is seldom the case) then the inverter is really the only thing that can go bad. I hope this helps some.
2017 Elite II, Hull #208
2019 Chevy HD 2500 Duramax
