wolfdds Posted May 31 Posted May 31 (edited) After a heavy rain we have water leaking out of the port the TV wires come through? Has anyone had this problem? The attic is dry?? It seems to be coming from between the fiberglass layers. My initial guess was either the AC or the Oliver Sign. There is no leak around the AC unit directly in. The seal is completely dry and the Ollie sign seems fine. I have not had a chance to go onto the roof to investigate. Edited May 31 by wolfdds Added content. 2019 Elite II Hull 435, 2022 Toyota Tundra
Moderators topgun2 Posted May 31 Moderators Posted May 31 Your guesses make for a good starting point. I'd get up in the attic with a bunch of blue paper towels. Take the panels on both sides of the attic down - you don't have to remove them or disconnect any of the wires. Lay and/or tape the blue paper towels near/on the areas that you suspect (i.e. around the "Oliver" sign, around the hole into the main cabin, in the area of the rear view camera, as far as you can reach towards the a/c, etc.). Go outside and give this area a good soak with the garden hose. Go back inside to look for "dark" spots on the blue paper towels which will give you an indication as to where the leak is coming from. Good luck! Bill 4 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
wolfdds Posted May 31 Author Posted May 31 I took the sides off in the attic. It is completely dry, even dusty. The only place that is even damp is right around the hole. I also took the inside cover off the AC. The inner seal is completely dry. I'm on the road and it's still raining, so I'll have to investigate on the roof more at home. 2019 Elite II Hull 435, 2022 Toyota Tundra
Moderators topgun2 Posted May 31 Moderators Posted May 31 OK - I'd lay those blue paper towels around the hole. This will tell you which direction to look for the water flow. That direction may (or may not) give you a better idea of where the water is coming from. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
wolfdds Posted Tuesday at 05:53 PM Author Posted Tuesday at 05:53 PM (edited) After returning home I was able to better investigate the water issue. Turns out the attic was not dry. It was wet underneath the white insulation layer. I was able to easily peal the the insulation up. The leak was coming from the Oliver Sign. The caulk had dried and cracked. It is actually amazing how much water could get in from that source. All things considered this was the best scenario for the source of the leak. I was able to remove all the old caulk and re-caulk the sign. Edited Tuesday at 05:55 PM by wolfdds Typos 2 4 2019 Elite II Hull 435, 2022 Toyota Tundra
John Dorrer Posted Tuesday at 05:56 PM Posted Tuesday at 05:56 PM (edited) On 5/31/2025 at 8:45 AM, wolfdds said: After a heavy rain we have water leaking out of the port the TV wires come through? Has anyone had this problem? The attic is dry?? It seems to be coming from between the fiberglass layers. My initial guess was either the AC or the Oliver Sign. There is no leak around the AC unit directly in. The seal is completely dry and the Ollie sign seems fine. I have not had a chance to go onto the roof to investigate. Cut out the sealant and recaulk it Not sure what sealant Oliver uses. Give them a call. Install gutters over the sign and windows. Edited Tuesday at 05:59 PM by John Dorrer Updated Comment 2 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
DavePhelps Posted Tuesday at 07:52 PM Posted Tuesday at 07:52 PM So the rear Oliver lense strikes again.... I would also check those marker lights. The one under the O of the Oliver sign especially. If it leaks, the water would run down its supply wire where it looks like it touches your TV cables. The water would then continue down that cable and into the cabin. All those wires up there with no drip loops designed in are are major pathway for water to travel to far off places. I had drips out my rear speaker from one of those marker lights.... Cheers, Dave 4 2015 Oliver Elite 1, Hull 107 2025 GMC Sierra HD 2500 AT4, 6.6 L8T (gas)
Moderators Mike and Carol Posted Wednesday at 01:59 AM Moderators Posted Wednesday at 01:59 AM My only leak has been the Oliver sign. Cleaned and recaulked and problem solved maybe for another 6 or 7 years? Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Moderators SeaDawg Posted yesterday at 01:10 AM Moderators Posted yesterday at 01:10 AM (edited) We went overboard on the Oliver sign, but i think it's permanent . Replacement lens, Butyl tape, mechanical fasteners, plus caulk. 5 years in, and good. https://olivertraveltrailers.com/forums/topic/4823-third-taillight-reinstall/?_rid=33 Edited yesterday at 01:12 AM by SeaDawg 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
wolfdds Posted 22 hours ago Author Posted 22 hours ago All set. But you have to question the logic behind putting a hole in a solid fiberglass camper just to caulk a plexiglass sign into it!! 1 2019 Elite II Hull 435, 2022 Toyota Tundra
Moderators topgun2 Posted 22 hours ago Moderators Posted 22 hours ago 2 minutes ago, wolfdds said: But you have to question the logic behind putting a hole in a solid fiberglass camper just to caulk a plexiglass sign into it!! There is a long storied history in this regard - much of which I don't know. But, as with virtually all other "engineered" things in the Oliver even this is not as "simple" as it may seem. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
rich.dev Posted 21 hours ago Posted 21 hours ago 48 minutes ago, topgun2 said: There is a long storied history in this regard - much of which I don't know. But, as with virtually all other "engineered" things in the Oliver even this is not as "simple" as it may seem. Bill, the new (2024+) don’t have the fridge vent holes on the side anymore, so wondering why (with new molds anyway) couldn’t they leave out the Oliver sign hole, or maybe they have? 1 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Moderators topgun2 Posted 18 hours ago Moderators Posted 18 hours ago (edited) 2 hours ago, rich.dev said: Bill, the new (2024+) don’t have the fridge vent holes on the side anymore, so wondering why (with new molds anyway) couldn’t they leave out the Oliver sign hole, or maybe they have? Well - As with the fridge vents Oliver really doesn't HAVE to cut out these spaces to include the space for the sign hole. In fact, when the new fridge was adopted Oliver simply didn't cut out that part of the outside hull and to help "cover" the now flat area they engineered a fold out table in that space. So, that begs the question as to why Oliver has decided to continue with the "third brake light" Oliver sign. All I can tell you is that there has only been one Oliver Travel Trailer that has come off the production line without that area lighting up as an "Oliver" sign*. That trailer is mine and when Mr. Oliver happen to see it on the production line he was not happy and ordered that every Oliver would have that sign that says it is an Oliver from then on. I'd suggest that this shows how strongly Mr. Oliver felt about using that space for advertising exactly what brand of trailer was going down the road. Bill *note: there are at least three Olivers other than my "Twist" that also do not say "Oliver" in that third brake light space. But, in each of the other cases the owner had the Oliver lettering replaced with another name. "Olivia" and "ILUVHER" are two of the others and I can't remember the third. Edited 18 hours ago by topgun2 added detail 1 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators bugeyedriver Posted 17 hours ago Moderators Posted 17 hours ago 1 hour ago, topgun2 said: Well - ... All I can tell you is that there has only been one Oliver Travel Trailer that has come off the production line without that area lighting up as an "Oliver" sign*. That trailer is mine and when Mr. Oliver happen to see it on the production line he was not happy and ordered that every Oliver would have that sign that says it is an Oliver from then on. Bill You REBELL !! 2 Pete & "Bosker". TV - '18 F150 Super-cab Fx4; RV - "The Wonder Egg"; '08 Elite, Hull Number 014. Travel blog of 1st 10 years' wanderings - http://www.peteandthewonderegg.blogspot.com
Dennis and Melissa Posted 14 hours ago Posted 14 hours ago I don't have any leaks, but... What caulk do y'all use for these sorts of things? You see, I was washing my Ollie after a long trip. The start of that trip was in Hohenwald for our first "annual maintenance". Don't get me wrong. I'm happy we had it done. They did a number of things under warranty, and I learned a few more things, but.... Part of what they did was re-caulk everything. And, while I was cleaning the roof, I got my first look at that part of their work. Some of it is genuinely sloppy. Maybe even useless. And, of course, it's in places that are really hard to get to. 🤪 1 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
jd1923 Posted 13 hours ago Posted 13 hours ago 1 hour ago, Dennis and Melissa said: Part of what they did was re-caulk everything. And, while I was cleaning the roof, I got my first look at that part of their work. Some of it is genuinely sloppy. Maybe even useless. And, of course, it's in places that are really hard to get to. 🤪 I hate that! I still have it on my list to remove all the old caulk on our 10-year-old hull. Our hull went for OTT service in 2018 and 2020 according to receipts I have. They must have done all the messy caulk on top of caulk work, yes sloppy to say the least. What a shame on your only 1-year-old hull! There is no reason in the world they should have gone over yours. Caulk should last YEARS and caulk over caulk is never a good idea! Here is an example of the handywork of such an over-zealous artist! 😞 Picture is after travel on a dirt road which makes it show fully -- 2 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
