Markmck Posted July 13, 2025 Posted July 13, 2025 wondering if anyone greased their hitch? we have a 3/4 ton diesel so we no longer use the Anderson. Just curious about everyone thoughts. thanks Oliver 371
Steph and Dud B Posted July 13, 2025 Posted July 13, 2025 We do. I use this: 3inOne Trailer Hitch Gel Lube https://a.co/d/7Kz5pKB 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
jd1923 Posted July 13, 2025 Posted July 13, 2025 (edited) 3 hours ago, Markmck said: We have a 3/4 ton diesel so we no longer use the Anderson. When not using the Anderson WDH, make sure you are also not using the Anderson hitch at all, meaning specifically the ball on the cone. Without the WDH boomerang piece bolted through the bottom, the ball is merely held in place by a snap ring which could fail allowing the cone and ball to come up and off. With a standard ball it is common practice to grease it. Get a rubber cover for when detached before it soils your pant leg! Use any thick grease so it stays put. I use red wheel bearing grease since I have several tubes of it on hand. Edited July 13, 2025 by jd1923 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted July 13, 2025 Posted July 13, 2025 (edited) A little dab will do ya…https://www.amazon.com/Reese-Towpower you can probably pick it up cheaper at a local auto parts store. Edited July 13, 2025 by Patriot 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Markmck Posted July 13, 2025 Author Posted July 13, 2025 Thanks very much! Excellent advice about covering the ball. 1
Zodd Posted July 14, 2025 Posted July 14, 2025 I use some white lithium but to each their own. Here is a good video on it and he even calls out how the Anderson hitch is different than others. 3 Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
FloraFauna Posted July 14, 2025 Posted July 14, 2025 11 hours ago, jd1923 said: With a standard ball it is common practice to grease it. Get a rubber cover for when detached before it soils your pant leg! Use any thick grease so it stays put. I use red wheel bearing grease since I have several tubes of it on hand. Same here. 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
Ronbrink Posted July 14, 2025 Posted July 14, 2025 My preference: 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
John Dorrer Posted July 14, 2025 Posted July 14, 2025 1 hour ago, Ronbrink said: My preference: This is what we use😊 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
John Dorrer Posted July 14, 2025 Posted July 14, 2025 I bought 2 ball covers, but soon found the grease would still get on them. I ruined 2 pair of shorts. My fix is a sealable sandwich bag, which can get a few uses before I replace it. I seal the bag and the grease keeps the bag from coming off will out and about. 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Ronbrink Posted July 14, 2025 Posted July 14, 2025 9 minutes ago, John Dorrer said: This is what we use😊 I like that it is colorless, so no staining of clothes; to @jd1923’s point, use a ball cover! I like the CURT brand; standard 1-7/8” to 2” or 2-5/16” diameter ball sizes. I’m also a fan of the Mission Automotive dielectric grease, which I need more of when back in stock. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
John Dorrer Posted July 14, 2025 Posted July 14, 2025 8 hours ago, Ronbrink said: I like that it is colorless, so no staining of clothes; to @jd1923’s point, use a ball cover! I like the CURT brand; standard 1-7/8” to 2” or 2-5/16” diameter ball sizes. I’m also a fan of the Mission Automotive dielectric grease, which I need more of when back in stock. I had 2 of those hitch ball covers, but the grease gets all over them and me. There is no way to get off and back without exposed grease 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Ronbrink Posted July 14, 2025 Posted July 14, 2025 3 minutes ago, John Dorrer said: I had 2 of those hitch ball covers, but the grease gets all over them and me. There is no way to get off and back without exposed grease I apply sparingly and never had that issue. It is a push and tug to put on and take off, respectively; as in air compression and suction actions! 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
John Dorrer Posted July 14, 2025 Posted July 14, 2025 8 minutes ago, Ronbrink said: I apply sparingly and never had that issue. It is a push and tug to put on and take off, respectively; as in air compression and suction actions! 👍 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
MAX Burner Posted July 15, 2025 Posted July 15, 2025 15 hours ago, John Dorrer said: I had 2 of those hitch ball covers, but the grease gets all over them and me. There is no way to get off and back without exposed grease We occasionally drink "Truleys" (a carbonated fruit flavored beer alternative) -- the cans are a perfect diameter to fit over the greased hitch ball. Just cut off about 3.5" from the bottom of the can, place it over the ball and pinch the cut-edge below the ball to keep it from flying off when driving. No more grease marks on your legs.... 1 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
