Moderators Mike and Carol Posted Friday at 04:24 PM Moderators Posted Friday at 04:24 PM 16 minutes ago, BoondockingAirstream said: Those who have or had electric braking issues... how were yours resolved? My brake issue was resolved after I posted my issue on this forum and another owner offered that he had the same issue and what he did to solve the problem. It turns out that it was a Dexter issue of excess wire wear due to how they ran/configured the brake wires. Several other owners have also had this issue. It will be interesting to see what your mobile tech finds out. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
jd1923 Posted Friday at 05:46 PM Posted Friday at 05:46 PM 2 hours ago, BoondockingAirstream said: We are in the Desert. No moisture issues here. No corrosion, Do not blame the messenger. When this problem is discovered and resolved... I will be the first to mention it. No salted roads in the Summer months. Take a close-up pic of the 7-blade plug on your Oliver. Have you used dielectric grease? We have that iron-oxide dirt out here in the desert. I wonder when this issue happened for you. Why was it working last year but not now. What has changed? I believe power to the brakes at the wheels comes to the first wheel (front-streetside?) and then they are daisy-chained, front to back and down each axle to get to the curbside. I may be wrong as this is from memory from two years ago when I replaced wheel bearing and all the electrical crimp parts. If this is true, to have NO brakes, there must be an open before the first wheel. If the wire down the axle is bad (open) it would affect only one wheel. I'm also opposed to the camp that has replaced the interior axle wire to one zip-tied behind the axle. Now you have annual zip-tie maintenance and the chance of the wire being damaged by highway or offroad debris. I would use the old axle wire to pull a new one that is a step heavier AWG and one with heavy water-proof insulation like wire rated for burial purposes. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galway Girl Posted Friday at 05:48 PM Posted Friday at 05:48 PM 5 hours ago, mossemi said: hot side of the of the 20A auto resetting breaker Oh yes....it does show that on the schematic. Sorry for the red herring. 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
BoondockingAirstream Posted Friday at 06:04 PM Author Posted Friday at 06:04 PM M&C... I read those Threads and they were my first to check out. It is also the first place to look on Airstream wiring. Most often the exposed wires catch onto something and pulls them apart. Seeing the bundles of WIRING folded up inside the Dexter Axle Tube has no excuse. Poor supervision, or the wire has to be so many FEET LONG. Checked the outside wiring for any loose connections. Then did the Spin the Wheels on each side in the Air... pulled the Brake Away Switch... and ALL FOUR brakes operated perfectly. Reinserted the pin... they spun freely. That resolved the shorted brake wires, unless I missed something. If this removes the worn insulation option... it does narrow things down. To what? I may soon find out once a technician gets out his electronic equipment. 🙂 The Mechanical visual checks I was able to do. Now it is the... what and where is the Trailer/Vehicle problem or issue? From posts I have read... ground issues. Wife and I checked each other's visual and tested wires screwed down. Those in the two photographs. I was told by Olive Inc. there was Brake Wiring behind the wall in the Bathroom. We removed that several days ago and no wires, but solid tubing probably to run wires into the trailer. I did notice a decently done white caulk on the back side of the Oliver Plug. Most likely to Seal the exiting bundle for any water. We live in the Desert. Water and Salt issues have been ruled out 99%. Maybe from Oliver Inc.. I have no Oliver known in the area, so can do anything else. This will get resolved. I hope soon.
BoondockingAirstream Posted Friday at 06:08 PM Author Posted Friday at 06:08 PM Gatway Girl and I most likely have the same wiring for brakes as theirs is Hull 505. Made within a week or so from one another? Also a F350 Diesel King Ranch... mine is a 2016.
jd1923 Posted Friday at 06:15 PM Posted Friday at 06:15 PM 6 minutes ago, BoondockingAirstream said: Checked the outside wiring for any loose connections. Then did the Spin the Wheels on each side in the Air... pulled the Brake Away Switch... and ALL FOUR brakes operated perfectly. Reinserted the pin... they spun freely. Yes, this means brake wiring at all 4 wheels are good. And given you have tested for brake voltage at the rear of the truck or same day the truck pulled the airstream brakes working, you have an open circuit between the 7-blade plug on the Oliver and the first wheel. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
BoondockingAirstream Posted Friday at 06:39 PM Author Posted Friday at 06:39 PM (edited) jd1923... Which? Front street or curb side wheel? Probably the street side with the Progressive Dynamics box? I did see the 1" diameter or so, black electrical cord, on the bottom floor behind the bathroom wall. It is way down and low. This same cord seems to go into the Progressive Dynamics: Automatic Transfer Relay 5100 Series. My education is making some 'head way', but being ignorant is my only defense. (Added: The brakes never worked. Since the Tow Vehicle works perfectly on the Airstream, I figured it was some quirk in an Oliver and F350 combination. Edited Friday at 06:42 PM by BoondockingAirstream
BoondockingAirstream Posted Friday at 06:59 PM Author Posted Friday at 06:59 PM I searched www.progressivedyn.com and entered my 5100 Series name and "No matching records found". Found a PD5118610 on the side and those 4 digits do not come up with anything as... It is the black 'box' in one of the photographs. They show a metal junction container with cooling fins. And a Fan. Called a converter on their website. Must be somewhere else... but so far a black plastic box that you cannot miss. I appreciate any help. Just to track down anything obvious, but not bothering wiring or connections. Like entering a Coal Mine and someone wants to light up a cigarette... is also not a good idea. Any help is greatly appreciated by myself and others who are curious. Going back into the OLIVER to... sniff around,
BoondockingAirstream Posted Friday at 07:10 PM Author Posted Friday at 07:10 PM In this same second area under the seat where the PD5118610 is located there is also a Smart Surge. There is a woven cover in black, at the bottom corner, where is is truncated about five inches from the box. May be in the photograph of the components in one photo. Smart Surge EMS-HW30C I am going to contact Progressive Dynamics and inquire to cure my ignorance, if possible. Those who do not have an issue... may want to help someone who does. I need the help. You could in the future.
jd1923 Posted Friday at 07:23 PM Posted Friday at 07:23 PM 34 minutes ago, BoondockingAirstream said: jd1923... Which? Front street or curb side wheel? Probably the street side with the Progressive Dynamics box? I did see the 1" diameter or so, black electrical cord, on the bottom floor behind the bathroom wall. It is way down and low. This same cord seems to go into the Progressive Dynamics: Automatic Transfer Relay 5100 Series. My education is making some 'head way', but being ignorant is my only defense. (Added: The brakes never worked. Since the Tow Vehicle works perfectly on the Airstream, I figured it was some quirk in an Oliver and F350 combination. Just from memory I believe the first wheel in line is the front streetside wheel. No, the <1" DIA cable is the 10/3 shore power cable coming from the front generator connection. The "Progressive Dynamics: Automatic Transfer Relay 5100 Series" switches between the 2 shore connections, front or streetside, to the one that is live. Your 7-wire trailer cable likely enters the front of your Oliver hull right next to the 10/3 shore power cable. If you get your head under where the LP tanks are mounted you could see the entry points. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
BoondockingAirstream Posted Friday at 07:24 PM Author Posted Friday at 07:24 PM Called Progressive Engineering and discovered THEIR HARDWARE and wiring coming in and out have: NOTHING TO DO WITH THE BRAKING SYSTEM. Drew explained to me what their system is for... nothing to do with brakes. Internal electrical system for the interior components. Scratched that off my observations. If you have an inside power issue: 269-781-4241. Service Department
BoondockingAirstream Posted Friday at 07:53 PM Author Posted Friday at 07:53 PM (edited) Airstream 2019 uses a Borgman a female plug into the Tow Vehicle. It appears the wiring is molded into the plug... solid cable and secure. Probably made just for the length of the trailer and has the Plug molded on and the length of cable required for the length needed. Oliver Elite II 2019 uses a Pollack that secures the cable... AFTER?... the wiring is secured within the interior. Totally opposite to the Airstream process? The white caulk sealing the cable exiting is nice quality, seals the cable going into the plug, Why I ask? Totally different methods. I prefer the Airstream as the Plug and Wires seem to be MOLDED to secure the wiring. The Oliver secures the wires AFTER installation. I do not know, but sure looks like this could be an issue. If Oliver Inc. had a Service call from the FIRST owner about braking... but did not mention anything to me on my phone call, and after being on hold for five minutes.. and then said they could nothing to help me. I am would believe they record all calls going out, or in. Maybe this is an Oliver Trailer Plug issue? Anyone had an issue? Or am I unique? Anyone have to replace an Oliver Trailer Plug to Tow Vehicle? I am getting curious. Will know in a few days, but something just makes no sense. When something makes no sense... this makes me more curious. Curiosity killed the Cat... kind of thing. Go for the simple solutions and then proceed. You cannot get any simpler than the Plug INTO the Tow Vehicle. Edited Friday at 08:03 PM by BoondockingAirstream
BoondockingAirstream Posted Friday at 08:28 PM Author Posted Friday at 08:28 PM (edited) After eliminating the Progressive system... it has nothing to do with trailer/tow vehicle Electric Brakes. But... my wife is a Human Bean and methodical. We did agree on one very simple issue that I cannot test due to not having the equipment. Let's say the previous owner knew little about towing, travel trailers and no aptitude to fix... anything. If the electric vacuum quits... it is tossed and replaced. I take it apart to find the problem... then if it is beyond repair... out it goes. Let's say the new owner had perfect braking when connected at the factory lot. Never towed before, but everything worked. Maybe not. When at home, he detaches at the RV Storage. Returns to go camping, and he, or the storage employee attaches the Oliver to the owner's tow vehicle, going in or out to where the trailer is stored, The cable is a bit long, so the cable may have been wrapped... to take up some slack. The cable will not drag on the ground... but if you make a sharp turn... it will tug onto the plug and connection. It is very secure at the plug connection. Possibly pulling out the wire shown on an earlier post in wonderful color. Then no braking. The repair shop could not figure it out. Just towed it, maybe not, as it was very clean and I paid through the nostrils... for its wonderful physical condition. Even my lovely wife agreed with this possibility. I always have slack towing the Airstream on this cable. The Oliver plug has its weakness. It is not molded into the plug. It is attached and then a screw snugs things up Well... I think my sniffing around from complex to a simple cause may be coming. I will check the length of the Airstream and Oliver cables outside the interior. For the 'want of a nail, the war was lost'... was something I heard as a young Neanderthal. We will see... Edited Friday at 09:37 PM by BoondockingAirstream
BoondockingAirstream Posted Friday at 09:38 PM Author Posted Friday at 09:38 PM (edited) I left a message with the Mobile Service Company to have a new replacement 7 way RV Plug, in the event this is the problem. Otherwise... I am finished with my discovery of complicated to simple. Working forward to the 7 Way Plug, as the most convenient problem. The Oliver has 28 inches of cable to the end of the 7 way plug. My Airstream has 27 inches of cable to the end of the 7 way plug. So the cable lengths are close to identical. Rather too long, than too short. But... it comes down to the Plug in my opinion. If not the plug... then that is a 'horse of a different color'. With the feedback from other owners... maybe we all are coming to the same conclusion. For me... it would be an expensive solution, but I will watch the service tech and learn something in the process. (I edit AFTER I WRITE. An idea is like watching a movie in color. If I do not get it out of my imagination in print... the ideas disappear.) Edited Friday at 09:39 PM by BoondockingAirstream 1
Steph and Dud B Posted yesterday at 12:37 AM Posted yesterday at 12:37 AM 6 hours ago, BoondockingAirstream said: I did notice a decently done white caulk on the back side of the Oliver Plug. Most likely to Seal the exiting bundle for any water. 4 hours ago, BoondockingAirstream said: Airstream 2019 uses a Borgman a female plug into the Tow Vehicle. It appears the wiring is molded into the plug. 4 hours ago, BoondockingAirstream said: Oliver Elite II 2019 uses a Pollack that secures the cable... AFTER?... the wiring is secured within the interior. This is NOT Oliver factory equipment. Oliver uses a molded plug/cable combination like Airstream, and no caulk. Sounds to me like your trailer has an aftermarket replacement plug on it, similar to this one: https://a.co/d/hD8H9JV If you disassemble that Pollak plug you'll probably find screw terminals inside. The one for the brake wire may be loose or corroded. 1 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Moderators SeaDawg Posted yesterday at 12:52 AM Moderators Posted yesterday at 12:52 AM (edited) My experience with electric brakes is, they mostly work. We did have an issue back in 2008 or 9. Mostly going down mountain," nc " would pop up on the tekonsha. Certainly, unsettling. Turned out to be a loose ground wire . Couldn't blame anyone but us, as we drove /drive a lot of rough paths. No problem since. Same Tekonsha. Moved it from 2004 Volvo to 2005 Chevy to 2008 dodge ram. Guessing we are driving more "vintage" vehicles than you are. They are actually pretty simple mechanisms, all things considered. Since your brakes appear to work properly with the Airstream connected, you likely have a bad connection somewhere in your Oliver. Please keep us posted on what the mobile tech discovers. Edited yesterday at 12:53 AM by SeaDawg Spelling 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators SeaDawg Posted yesterday at 01:19 AM Moderators Posted yesterday at 01:19 AM 4 hours ago, BoondockingAirstream said: It is not molded into the plug. It is attached and then a screw snugs things up This is not factory, imo. And may very well be at least a part of your issue, if not the entire issue. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
BoondockingAirstream Posted 9 hours ago Author Posted 9 hours ago (edited) SeaDawg... the 7 way plug was simple to slide the interior out with no effort. I watched a number of videos on the Internet and with one small screw to secure up front, and a back screw and bracket to tighten onto the covered wire bundle... took a couple minutes. The 7 pin assembly and wires slide out easily. What appeared as caulk was a white plastic ring that slips over the back, slips over the wire bundle as it enters the interior. You see it just flush flush in the back of the plug. The wiring was all correct and the assortment of colors shown on the wiring diagram were all Oliver wire bundle. Wires were all screwed tight and did not loosen or pull out bare wires. Just visually looked secure. I now do not suspect the plug or its wiring. If this is NOT the original plug,... there was an issue by the original owner, It is available on the Internet by name. Obviously, this did not FIX IT. So back to waiting for the professional to dig into this. NOT the 7 way Plug... to blame... yet. It was amazing how many videos are to be found just about these plugs. I am rather... over exposed... exploring those. Now... have to let the professional, using his electronics and experience to find the... ORIGINAL PROBLEM. Getting the feeling if the original owner had issues and tried to have it repaired... it is inside the trailer, For what it is costing me for the exploration and possible fix, I do not wish this on anyone. Just a few more days. I will have my F350 handy to plug into and MAKE SURE THAT EVERYTHING OPERATES. Before it seemed to be a quirk with the year of my 2016 F350 and a 2019 Oliver model.... but all is well with the 2019 27FBQ Airstream. It is now the Oliver. Cannot say what or who did what... it is, I hope, to be discovered. I will plug my F350 into the Oliver to make sure the 'repair' works... It either does work or does not work after the Service. If it works... I will describe what the Service Tech did to fix it. He will be happy as he earned his $$$$. I will be disappointed that the Original Owner had this problem, and it was not fixed when he discovered there was something not right. I learned as well. Edited 9 hours ago by BoondockingAirstream
BoondockingAirstream Posted 5 hours ago Author Posted 5 hours ago (edited) When I inquired to Oliver Inc. I was told that the Brake wiring bundle goes into the Bathroom Toilet/Sink area. I pulled out my Garage 'scooter', laid onto it and scooted to find three threaded tubes going into the bathroom, behind the panel with six screws. They are there and intact. Nothing inside the space that smelled or looked out of place. Way down and low... I do not know if this is an area with any connections, or just the position for the wire bundles to enter the interior. From my adding reading glasses and a bright flashlight... just a convenient way to bring all of the wiring into the Hull. Good planning in my opinion. Nothing unusual to see beneath the Oliver frame either... but now know where the wiring bundles enters. We had 248,000+ miles on our 'old 1994 Land Cruiser', that sold in one day with a Craigs List ad. Ran perfectly, If I cannot get this figured out, I am inept with diagnosing anything electrical, unless it is smoking or hanging bare somewhere. I do not abuse my vehicle brakes and do not over use braking traveling slow or upon level highways. (NO, I have not towed up Pikes Peak in Colorado with either trailer... you knew that already. Going up and down in a 4x4 vehicle was interesting enough for my mother, wife and me showing them... a good time. They looked pale and dehydrated.) I read a post by John E Davies about Brake Wiring being undersized in 2018. Holy Cow... now what? Like a water bottler using paper screw caps, rather than more expensive plastic screw caps? If I had not all of my own natural Gray Hair from being a 1949er... it may turn grey after this. Which... may be a good side effect. My wife does not care. She helps me look around for obvious issues in the Oliver... which are not being obvious. I can wire a 1946 Wurlitzer model 1015 bubbler... but an Oliver Elite II is an entire line of jukeboxes from the transistor age. At least when I plug it in, deposit a nickel and it always works. I pace around the Oliver... and get lost in the process, Yeah... Service Tech. I hope to learn something. If he cannot figure it out... maybe rent it out as an apartment? Edited 5 hours ago by BoondockingAirstream
BoondockingAirstream Posted 4 hours ago Author Posted 4 hours ago (edited) I do not offer any repair tips or clues. But... sure can look for them. I noted the Blue Fuse in the fuse box under the 'dining table'. Of course the door opens outward, you crawl under the table and discover that reading glasses are not enough to read the small print. But the BLUE Fuse number was not as clear as the others. Took a photograph, under the table and left room for my head and camera for the photo. My thought was... I had expired into the 'after world'. But photo flashed, I grunted.. she did not call 911. I finished a new possible discovery. Much like Columbus... but without a sail. Here I am. My very old Mac Computer was out of date, now have a new modern computer and things are... different. But this is my practice, like a being a horse, learning to carry a gal on a saddle... kind of experience. No spurs needed... I cooperate very well. If it is this fuse... I will keep it... frame it on the wall... and curse at it once a year on the repair date. I replaced a 15 year old computer than worked fine... but the software needed to use it... made it obsolete. Now a 2019 Oliver Elite II... six years old and turning me back into a Neanderthal that uses a walking stick as a... tool of sorts... if everything else fails? Whack it. What is the Blue Fuse...? Human Beans with an Oliver know. I cannot read the tiny print, backwards and upside down... Have a good day. Mine is coming Wednesday. I hope. Edited 4 hours ago by BoondockingAirstream
Galway Girl Posted 3 hours ago Posted 3 hours ago On 8/1/2025 at 9:04 AM, BoondockingAirstream said: No checking the tow vehicle and trailer are functioning as designed before a new owner departs? It appears you have brakes that work (from your break away switch test). But your 7 pin to brake connection isn't working. Hoping the RV Tech helps you out and gets it all set up correctly. As an aside to your brake issues....it's important whenever brake assemblies are new or changed to "burnish them" in before full trailer use. I learned when picking up Hull 505 that electric trailer brakes on new trailers must be BURNISHED or heated up to brake them in and seat them to the drums. When we started to pull away I grabbed the controller and squeezed...no brake action. I walked back into the service team and they showed me a page in the Dexter Service manual. They said I needed to burnish my brakes by driving on some back roads on my way to the first campground. I found that after about 30 applications my brakes where really starting to work well. The next morning as we pulled away I dropped the controller back to 5 out of 10 and I had working brakes on our trailer. This is NOT done by the factory that assembles the trailer. It must be done either by the DEALERSHIP selling the trailer....or more likely the OWNER. Hopefully you'll catch a break and things will all be fine after your RV Tech visit. To seat the brakes, Dexter and other manufacturers have a recommended brake in procedure. *See video& 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
CRM Posted 3 hours ago Posted 3 hours ago 39 minutes ago, BoondockingAirstream said: What is the Blue Fuse...? Human Beans with an Oliver know. I cannot read the tiny print, backwards and upside down... Have a good day. Mine is coming Wednesday. I hope. According to the label on the fuse box door it's for the furnace. If you want to check your blue wire and white wire for continuity, just put a 12v test light between the blue and white wire connectors at the 7 pin and then activate your breakaway switch. According to the schematic, that should power the blue wire and the white wire should complete the circuit to ground to light the test light. 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Galway Girl Posted 43 minutes ago Posted 43 minutes ago @BoondockingAirstream you may want to watch this before your tech shows up. How to troubleshoot electric brakes. 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Galway Girl Posted 30 minutes ago Posted 30 minutes ago (edited) 4 hours ago, BoondockingAirstream said: What is the Blue Fuse...? 15Amp is blue, and it's for the water pump. Pix of ours so you can read it in a 2019EII Hull 505 Notice that I crossed off the #5 AC breaker for the 12V Charger. When I upgraded to Lithium batteries I replaced our embedded 12V charger with a new combination 2000W Inverter/Charger . I disconnected the wiring from the 15A breaker for the embedded 12v charger to deactivate that circuit. Edited 21 minutes ago by Galway Girl 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
CRM Posted 11 minutes ago Posted 11 minutes ago 16 minutes ago, Galway Girl said: 15Amp is blue, and it's for the water pump. Pix of ours so you can read it in a 2019EII Hull 505 Thanks for correcting me. In his pic it looked like it was in the #4 fuse position to me. 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
