Anyone tried the Onnais version 3 keyless locks? Anyone express any issues with the RVLock V4 keyless locks? One being more or less keyless than the other...
Any issues or concerns with customer service available from either?
Neither uses laser cut keys or other types of keys that most locksmiths will not duplicate.
I wonder if either allows you to select your own frequency for communications between your FOB and the lock wireless receiver (I wouldn't enjoy the door unlocking during the night when a neighbor is locking/unlocking their unit). Failing that, will either allow you to turn off the FOB functionality? I wonder how many possible frequencies these FOB have the ability to use?
Thoughts?
Pat and Amy Radack
Hull # 1189 - 2022 LEII
Black 2019 RAM 2500, Cummins 6.7L,
Limited, Crew Cab, 4 x 4, 6’ bed w/ Rambox
2019 RAM 2500 Limited 4x4 Crew Cab Black. Hull # 1189
Pat and Amy
We have had the RVlock V4 lock on our Oliver since we purchased new and this is year 6. It has worked flawlessly since I installed it post purchase. Just make sure you replace the batteries timely. The lock will let you know when the batteries are getting low with a lower tone or faint beep.
RV lock was very responsive the one time I needed to replace our key pad with the new and improved silicone key pad. The RV lock key fobs are ok. We primarily use the key pad. RV lock is a Chi/com product and you get what you get. If someone really wants in your trailer the door lock is not going to stop them.
You might want to call RVlock and ask about frequencies. No, you cannot turn the fob off unless you remove the battery. The fobs are hit and miss…some work well for a long time and some don’t. We keep a spare set of keys locked up in our TV should we misplace or loose our keys.  The key pad has worked great for our needs and I would replace our RVlock with the same model given our field experience.
I have never heard of this key lock. Do you have a link?
Enjoy your Oliver and go camping!
Edited by Patriot
20 hours ago, johnwen said:
David,
Do you by chance have a link to the one you bought?  How was the blueberry crop this year?  Leaving Ellsworth tomorrow trekkin back to SC 🙂
Hey John,
Here is the link for RVlock.com - https://www.rvlock.com/?utm_source=google&utm_medium=paid&utm_campaign=1748190371&utm_content=69572607838&utm_term=rvlock v4&gadid=392517272318&gad_source=1&gad_campaignid=1748190371&gclid=Cj0KCQjw5onGBhDeARIsAFK6QJYJgFt5RvAk6-wVwyX33R2FaM6mQ2LRvyTXSJpmPQMbw1L02n294R8aAvwnEALw_wcB
As for the specific model I believe it is the V4, but if you give RVlock a call I am pretty sure they can get you the exact model you need, they have sold a lot of locks. It’s been a long time since purchased and I installed ours. Blueberries were at rest this season. We pruned heavily last fall. Next summer we hope for a good crop! 😊 Safe travels as you make your way back to SC! Hello to Wendy!
We've had two RVLocks fail, on the first one a circuit board failed, the second one had a mechanical failure which we were advised (by the manufacturer) to loosen the internal screws that held a metal plate in place; I don't have a lot of confidence in the second fix but it seems to be working for now. Lot's of people seem to have this lock and are happy with it though.
  • Sad 2
