possible fixes
checked breaker panel. Switched on and off.  Heard clicking noise but no power no inverter
turned breaker on an off under seat across from inverter still no power.
it worked fine 2 weeks ago
skip and cyd nielsen  hull #822 Elite     tow vehicle 2017 jeep trailhawk v6
12v power on inverter input lugs?
GFCI tripped on inverter output?
Tried on/off switch right on inverter face panel?
Big input fuse feeding inverter blown?
Tom & Holly
2018 Oliver Legacy Elite #409 - 320W rooftop solar, 300Ah Epoch LiFePO4, Victron BMV-712 & Smart Solar MPPT 100/30, Progressive Dynamics PD4060CVS 60Amp Lithium-capable Converter, Xantrex PROwatt SW 2000 inverter, Bulldog HD1213-0656 Shocks, Falken Wildpeak H/T02 235/65R16C 121/119R; Tow Vehicle: 2017 Silverado 1500, 5.3L Gas, 4x4, Dbl Cab, Std Bed.
trying to find inverter gfci output
and big input fuse
  • Collaborator
  • Members
seems like it would have to be a fuse  but i opened the 3 atached to the red wires coming off a breaker with red button opposite inverter installation underneath seat and tried the main breaker on panel  and checked for loose cables. but thinking it has to be a blown fuse not to have any power  Im trying to find the other fuses
still hoping  guess Ill look for a rv guru nearby or take it to bozeman mt to get it fixed.   should be something simple.      but not obvious
Are all your 12V circuits working? e.g. lights, stabilizer jacks, etc.
Attach some pictures here, of the inverter, inverter panel or on/off switch, wiring into the inverter and devices near the inverter.
Do you have a multimeter, or test light?
@ADKCamper gave you a good checklist for testing.
The gurus are here. Post pictures and get a meter or simple test light at an auto parts store.
It is likely simple..
Edited by jd1923
here are some pictures of the  inverter and nearby fuses ect      I will get tester and I have a testing 12v light stick.   but the problem is I do not know where to put the tester or the light 12v tester.... sorry for my ignorance   Its pretty tight in there
Skip -
I don't see any obvious issues other than the dust that is everywhere.  That dust can get into many areas that you don't want it to - I know this because every couple of years I have to plug and unplug the remote cable (runs from the back of the remote switch inside the living area of the Ollie) to the inverter.  I've never had to bother with the connection on the back of the inverter switch but it is the connection that goes into the inverter itself.
However, as I think you said that you had already tried turning the inverter on/off at the inverter itself, I doubt that this is your issue.  But, its worth a shot.
If you decide to try this, what you are looking for is what appears to be one of those little phone jack connections.  Simply press down on the little plastic tab and pull straight out and push straight back into where it came out.  Do this two or three times to help "clean" the connections.
Edited by topgun2
grammer
Having these pictures is great! It may make all the difference in us helping you.
Your test light should have an alligator clip on one end, clip it to the negative bus which is the one you have pictured 3 times with all yellow wires. You then want to touch both sides of the SMP 200A breaker shown in your 4th picture. I’m pretty sure this is the breaker between your batteries and inverter.
If the breaker is closed (on) and in working order, there should be power on both terminals (test light ON). If you have power on the battery side and not on the other, you need a new breaker and you’ve found your issue.
Let us know on this test for next steps if necessary.
Like @jd1923 said, take measurements around this circuit breaker, input vs output .  These have been known to fail. As John said you should measure 12V on each side with respect to ground. IMG_4176.jpeg.2f365603b61362b7f3332b3fcfbf2ebb.jpeg
I tested and do have 12v power on either side of the big breaker.  I also tested(picture) inside zantrex panel and have power there as well
4 minutes ago, Skipster said:
I tested and do have 12v power on either side of the big breaker.  I also tested(picture) inside zantrex panel and have power there as well.
I read in your other post that unplugging and plugging the inverter makes a noise. This and your test shows you have power to the inverter. The noise means it’s doing something internal.
Time to get in the phone with Xantrex Tech Support. You have power in but nothing out. They will have tests for you to do and next steps. Your issue must be the inverter is not powered on or something else internal to the inverter.
Good work so far! Keep us posted.
Thankyou all.   I will update when I find out more
So took it to bish rv in Bozeman
the inverter has power coming in.  I had called Zantac support and I will call back tomorrow . They told me 3 year warranty. Our Ollie hull number 822 is going on 4 years old.  A new inverter is 1800$ plus labor.  Hope xantrax will help.
3 hours ago, Skipster said:
A new inverter is 1800$ plus labor.  Hope Xantrax will help.
Yes, call them!
I purchased a brand new 3KW Victron Multiplus II for $1,100. Don’t spend this money on a 2KW Xantrex! Your model used in working condition on eBay is likely about $300.
17 hours ago, Skipster said:
I had called Zantac support and I will call back tomorrow . They told me 3 year warranty. Our Ollie hull number 822 is going on 4 years old.  A new inverter is 1800$ plus labor.  Hope Xantrex will help.
I'm thinking a good tech at Xantrex should get you up and running...
But, if it turns out you need to replace the unit and want to swap with the same model, I would do this. This eBay Seller with decent feedback is an RV parts & salvage co, this item is open box, "guaranteed to work."
https://www.ebay.com/itm/267389119450?_skw=xantrex+freedom+xc+pro
The labor is simple, since the model is identical. Just disconnect your shore power and batteries, and solar switch OFF. Then swap wires from your original unit to the new one. $650 plus tax vs. $1,800 plus tax and labor! 🤣
I have a Xantrex 2000 watt inverter removed for installation of the Victron MP2.  If you are near Atlanta, come by and make me a deal.
2020 Elite II Hull #628 "Pearl" - Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt
TV - 2011 Toyota Tundra Crew Max Platinum 5.7 V8 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
