Geronimo John Posted January 20 Posted January 20 (edited) Owners: Mike and Carol’s “Battery Box Separation” thread well addresses the battery box structural securement to the frame and hull. My intent of this post is to re-look at the battery tay and straps and their securement. Despite our OEM straps being VERY tight, twice I found one of them had gone slack and come loose from the tray hook hole. Not good. I am starting this separate thread to focus on how to ensure that our OEM tray and batteries “stay put”. So basically, I would like to learn more about how the tray is mounted and then how to super contain our batteries in the tray. I would very much appreciate your sharing your thoughts on how the battery box embed plate and straps do their job. Some questions follow: · How is the battery box embed plate attached to the structural member below? · What’s you guess as to the dimensions of the embed plate? · Are all battery sliding tray fasteners buck-stopped by the embed plate? · I assume that the embed plate is aluminum. Can it be tapped for additional hold-down bolts. If yes, what bolt length will work best? · Can you share your DIY solution? GJ PS: As far as the tray slide coming open, I like Horace's (Hull 93 Maverick) Dec 17, 2020 idea. A couple of these would increase security and would prevent movement should the slide fail. My upgrades to his idea would be to use a Riv-Nut in place of the nut and washer. Maybe also pop rivet the aluminum angle to the tray sheet metal. Combined, less parts to get lost when doing battery checks and service. Thanks GJ Edited January 20 by Geronimo John 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators topgun2 Posted January 20 Moderators Posted January 20 (edited) 14 hours ago, Geronimo John said: As far as the tray slide coming open, I like Horace's (Hull 93 Maverick) Dec 17, 2020 idea. A couple of these would increase security and would prevent movement should the slide fail. My upgrades to his idea would be to use a Riv-Nut in place of the nut and washer. Maybe also pop rivet the aluminum angle to the tray sheet metal. Combined, less parts to get lost when doing battery checks and service. GJ - Remember that the later model Olivers have two of those spring loaded catches on the tray. This was done to lessen the chance of failure at that point. Unfortunately, I do not remember exactly when Oliver made this change. As far as Horace's ideas - why not simply drill a hole for the bolt a bit closer to the sliding portion of the tray, use a wing nut on the that bolt and do away with the angle piece of metal since the bolt head will be enough to stop the tray from sliding out? Bill Edited January 21 by topgun2 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Geronimo John Posted January 21 Author Posted January 21 4 hours ago, topgun2 said: As far as Horace's ides - why not simply drill a hole for the bolt a bit closer to the sliding portion of the tray, use a wing nut on the that bolt and do away with the angle piece of metal since the bolt head will be enough to stop the tray from sliding out? Roger on the newer sliding trays having double latches. Likely more new ones than older ones like ours. On the deletion of the aluminum angle: Don't know as my Ollie is on your side of the pond. But possible. But I seem to recall that the geometry of the area was such that just a bolt and nut was not doable. My guess is that for our vintage of sliding trays Horace figured it out and needed the aluminum angle to make it work. I would wager one of Art's home brews on that! On using a bolt and wing nut: I would prefer using a Rev-Nut if it will fit. One less thing to not get lost (nut), Besides when leaving Ollie for some time, I would like it taking some time to open the drawer from an anti-theft perspective. Kind of like removing the fuse from the front jack. Make hooking up a 600# tongue a PITA.... go next door to the SOB and steal that one. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators topgun2 Posted January 21 Moderators Posted January 21 (edited) 9 hours ago, Geronimo John said: On the deletion of the aluminum angle: Don't know as my Ollie is on your side of the pond. But possible. But I seem to recall that the geometry of the area was such that just a bolt and nut was not doable. My guess is that for our vintage of sliding trays Horace figured it out and needed the aluminum angle to make it work. I would wager one of Art's home brews on that! Wish I had a pic of mine - but - no angle metal needed on mine. Good point on the wing nut if your point is to deter a thief. I've found that the wing nut makes things easier to get into and out of (there isn't that much space in that spot). But, then again, I'm not worried about "unauthorized" access to my batteries for a number of reasons. Bill Edited January 21 by topgun2 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Tony and Rhonda Posted January 21 Posted January 21 Doesn't @jd1923's post from Oct. 2024 solve two possible problems: preventing (or slowing down) theft and locking the tray in position? 1 3 New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (Now with Engine #2) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
rideandfly Posted January 21 Posted January 21 Here's the old & new style battery tray: 5 Bill 2015 LE2 #75 2024 F350 6.8L
Moderators mossemi Posted January 21 Moderators Posted January 21 My battery tray keeper is not as elegant as Horace's or as secure as jd1923's, but it keeps my battery tray in place and it’s easy to remove and replace. Mossey 5 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Ronbrink Posted January 22 Posted January 22 (edited) On 1/21/2026 at 10:25 AM, rideandfly said: Here's the old & new style battery tray: My OLEll has the new style, which solved much of the problem with trays coming loose in older models and causing damage to box doors. However, one should take care and ensure both catches are fully engaged when closing. Occasionally upon slamming the tray into the secured position, only one of the catches will fully latch correctly. It’s easy to overlook, so owners with this type tray need to visibility verify that each spring-loaded catch is properly seated. A second ‘slam’ usually gets it done! Because these catches are horizontally mounted at each side of the battery tray, it is more difficult to further lock them in place in such manner as @jd1923 and @mossemi have successfully achieved. Has anyone figured out a way to deter theft with these new style battery trays? On 1/20/2026 at 5:12 PM, Geronimo John said: Despite our OEM straps being VERY tight, twice I found one of them had gone slack and come loose from the tray hook hole. Not good. Early in ownership I replaced the stock 12V Bright Way SLA/AGM batteries with 6V Trojan T-105 flooded lead acid batteries. In time the off-gasses from the Trojans deteriorated the battery securement straps, both the webbing and plastic buckles. This caused the tray hooks to loosen and require vigilant inspections. When upgrading to LFPs, I made a new set of straps which have held tight thus far! Edited January 23 by Ronbrink 4 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Geronimo John Posted January 23 Author Posted January 23 On 1/21/2026 at 4:51 AM, Tony and Rhonda said: Doesn't @jd1923's post from Oct. 2024 solve two possible problems: preventing (or slowing down) theft and locking the tray in position? Yep, and no nuts to lose either! TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jd1923 Posted January 23 Posted January 23 (edited) 7 minutes ago, Geronimo John said: Yep, and no nuts to lose either! Not quite as cool as our updated version! 😎 Edited January 23 by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted January 23 Author Posted January 23 10 minutes ago, jd1923 said: Not quite as cool as our updated version! 😎 That works well for those that don't have their master switch in there. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
