Townesw Posted June 3 Posted June 3 (edited) Here’s a trick to dump your tanks when the sewer hookup is uphill from your bumper. Here I used (2) 1”x2”x8 ft from an Ace Hardware store on the Keweenaw Peninsula Houghton MI Door County WI This time I picked up (2) pieces of 1/2”x10 ft EMT conduit from HD in Ellsworth ME. I like the conduit better than the 1x2 wood. The sewer hose supports slide better on the conduit and when I get home I’ll cut each conduit in half and turn a steel rod to just fit inside the conduit to make a splice for the halves. I thought I could stick the whole 10ft length into the Oliver aluminum rectangle frame rail but bolts through the rail prevent my doing this. Bill Edited June 3 by Townesw 3 5 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
Steph and Dud B Posted June 3 Posted June 3 Clever! 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Moderators mossemi Posted June 3 Moderators Posted June 3 Excellent idea! Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Todd B Posted June 3 Posted June 3 It is so nice when campgrounds are this well thought out 😉 Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
HDRider Posted June 3 Posted June 3 1 hour ago, Zodd said: It is so nice when campgrounds are this well thought out 😉 The best I had was a state park in Vermont. On top of being very poorly maintained the one way road was counterclockwise and the angle of the back-in spots were setup for the road to run clockwise. And, it had lots of trees to navigate as you backed in. Thanks to one of Vermont's Green Mountain Boys for an assist. 1 Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Galway Girl Posted June 3 Posted June 3 16 minutes ago, HDRider said: one way road was counterclockwise As is the south loop of Kalaloch CG in Olympic National Park ...where some bright summer crew member sent to repaint arrows, made a mistake. People have just had to live with the result for multiple years as the same intern also changed the maps to match the mistaken arrows. (Heard all that from a Ranger.) 2 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
jd1923 Posted June 3 Posted June 3 (edited) We don’t setup a waste line at campsites. We're never in one place for more than 5 nights and I don't deal with those fancy waste ladders which I associate with Class A RVers, who stay long with full hookups! 🤣 Instead we dump on arrival (often coming from boondocking) and on departure. When dumping, you must have the Oliver up in the front AND on the curbside. I use the LevelMate at the dump station to bring the front up a good +2" over level. Some may not know, the gray tank is on the curbside, with its outlet drain facing the streetside. If your Oliver is any lower on the curbside, your gray tank can be quite full after you thought you dumped tanks! I use an 8" Anderson block to lift the curbside jack so that it is at least +1" above level. Tanks are then fully emptied. This picture was taken at a dump station in Cedar City UT. I had to back in, so there was no other approach. You can see all what I had to do to lift the front! What's not pictured is the curbside jack is also lifted. Isn't RV life wonderful?! 😎 Edited June 3 by jd1923 1 3 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galileo Posted June 22 Posted June 22 On 6/3/2026 at 4:50 PM, jd1923 said: We don’t setup a waste line at campsites. We're never in one place for more than 5 nights and I don't deal with those fancy waste ladders which I associate with Class A RVers, who stay long with full hookups! 🤣 Instead we dump on arrival (often coming from boondocking) and on departure. When dumping, you must have the Oliver up in the front AND on the curbside. I use the LevelMate at the dump station to bring the front up a good +2" over level. Some may not know, the gray tank is on the curbside, with its outlet drain facing the streetside. If your Oliver is any lower on the curbside, your gray tank can be quite full after you thought you dumped tanks! I use an 8" Anderson block to lift the curbside jack so that it is at least +1" above level. Tanks are then fully emptied. This picture was taken at a dump station in Cedar City UT. I had to back in, so there was no other approach. You can see all what I had to do to lift the front! What's not pictured is the curbside jack is also lifted. Isn't RV life wonderful?! 😎 We do pretty much the same as you JD - except we always dump before departure - unless the campground has no dump station or sewer connections. I’ve found as you have that without a good degree of rearward tilt on the Ollie, that tanks drain slowly if at all. I generally can get away with just using the front jack and a jack block to lift the nose a bit. I can usually spot a bit if an incline at the dump station and take advantage of it. Often having to pull in “the wrong way” to capitalize on the grade of the dump station. I haven’t found a huge need to elevate the curb side to get the grey tank to empty. Unless the dump station pavement is really terribly pitched. 3 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Steph and Dud B Posted June 22 Posted June 22 We also drive our truck onto Legos when we hit a dump station. 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Galileo Posted June 22 Posted June 22 16 minutes ago, Steph and Dud B said: We also drive our truck onto Legos when we hit a dump station. That beats stepping on them in bare feet in the middle of the night! 😂 2 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Galileo Posted June 22 Posted June 22 17 minutes ago, Steph and Dud B said: We also drive our truck onto Legos when we hit a dump station. I guess we could do that - we have a set of ten of those levelers and I use my LevelMate Pro + to maneuver into site where I rarely need more than two of them. Just sounds like a bit of a pain. Then again, I’ve been known to chock the wheels and unhitch to raise the nose of the trailer at some dump stations. 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
