What a scare that must have been. Glad you are ok. I wonder if it helps that attaching an Andersen anti-sway hitch requires me to lock the coupler on the ball and then raise the ball quite a ways in order to get the hitch attached? If the coupler were not secure on the ball I would never be able to connect the Andersen,.
2024 Legacy Elite Platinum, Hull #1465
2024 Nissan Pathfinder, Rock Creek Edition
Lithium Batteries (260AH),
240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter.
Victron Orion XS 50A DC-DC Battery Charger
ALAZARCTDEFLGAILINKYLAMEMDMAMIMNMSNHNJNM
On 6/12/2026 at 8:02 AM, CRM said:
I can't even visualize how this can happen if the latch is locked/pinned unless the wire part that attaches from the latch to the collar is bent or broken. Do you have any pics from the topside?
First, I would suggest a serious de-greasing:
So much gunk in any hitch can cause it to stick when hooking up.
  • 3 weeks later...
Anybody notice that they appear to be using a different coupler on the new Apex X23?
Mike
  • 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler
  • 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
