Yesterday while traveling home from Northern Indiana on US 31, we hit a bridge joint. It was a big jolt followed by a load bang. Looking back the front of the trailer had dropped. We slowed and pulled off onto the shoulder.
The crossed chains did their job, as did the brake cable. Got out and was pretty shaken so I didn't look closely at the hitch, and can't remember anything, other than the pin was in place.
We just had Alcan 5-leaf springs installed and our travel home was completing the 500 miles before re-torque, which will be done tomorrow. The springs are still stiff and will be for awhile. Wonder if this could have contributed
I found no damage to the Bulldog Hitch. We have the 2" ball and 2" Bulldog.
Very scary. Only damage was the foot plated of the front jack. I will get that replaced.
Edited by John Dorrer
Typo
  • Wow 12
-image.jpeg.9e7303babcb28d7f6badb799734c6e44.jpegALAZARCACOCTDEFLGAIDILINIAKSKYLAMEMDMAMI
Wow, John! I can just picture how terrifying that must have been. It gives me goosebumps just thinking about it! I’m so glad you and everyone else are okay and came through unscathed.
**Sold😞**
John, I'm so glad that you're ok!! I'd be very interested in knowing what caused the Bulldog to release! That's pretty scary! It's good to know that the safety systems do in fact work!
Time to relax under a tree with your favorite adult beverage!!
Was the clamp open when you looked at it immediately following the incident?
Bill and Martha
2019 Chevrolet 2500HD Duramax
Or, three or four!
I do know of a person (me) that was leaving VERY early one morning from a campsite in Yellowstone and just had this "funny" feeling that all was not right.
I (oops - this person that I know) stopped at the camp entrance just to take a look around and saw that while the bulldog was clamped shut and locked, it was "resting" on the top of the ball - NOT down and clamped around the ball as it should have been.  This person has never told me just how he got the bulldog closed and locked without being down on the ball.  I've accused him of not being as careful as he should have been and he claims that in the early morning darkness plus being in a hurry may have had something to do with the issue.🥴
  • Haha 7
  • Wow 2
That is a mystery. I was so shaken that I started checking to see if the jack worked. I had to disconnect everything, which meant no flashers on the trailer and is flying by, that all I wanted to do is get hooked up and off the shoulder. So not sure whether this was my error or something that was the perfect storm. Bad bridge joint, new springs, something with the Bulldog. The Bulldog looked fine.
It's a lesson to all of us to always have a spare set of shorts handy for occasions like this.  😜
  • Haha 8
Yeah, except it popped off and is no longer fit for highway use (around town OK). I would replace it ASAP with the 12.5K 2 5/16" coupler. Glad I made the upgrade before something like this, and more so since our trailer is much older.
The heavier Alcan Springs will keep the Oliver from porpoising. It will be less forgiving, and over a bump could creat force in the opposite direction. Given this failure, it would have happened eventually since the sagging 1750s are more foregiving.
Sounds like your back or near home. John, you do not want a repeat episode! Please get it replaced! This is what I purchased which is still reasonably priced today =>
Bulldog Collar-Lok Trailer Coupler 2-5/16" Ball 12,500 lbs 3" Channel Tongue w/ High Profile Latch | TrailerJacks.com
All our nightmare.
I am so glad everything went well.  I would be shook to my core.  It would be hard to go on.
Wow, glad you and your Ollie are OK!
I can't even visualize how this can happen if the latch is locked/pinned unless the wire part that attaches from the latch to the collar is bent or broken. Do you have any pics from the topside?
In process of getting the 2-5/16
No pictures. Trailer is back in storage. After a day processing, we are sure the trailer was secure on the ball. My wife directs me back and when we have the ball where we want it under the hitch, I lower the hitch. Once I know it is seated, I squeeze the lever and slide the slide closed. With it closed, I turn to my wife and we give each other Knucks and she hands me the pin to insert.
After the incident and getting the front raised, I pulled the pin and opened the hitch.
The bridge joint was a hard impact. It must have shut our dash cam off, or leaving it on when I went to the store and left it on overnight may have errased it.
I wonder if this was a combination of bad bridge joint, new Alcan 5-leaf springs, and wear or issue with the 2" Bulldog.
I'm not willing to go through that again. Requested pricing from Oliver so I can have them ship the 2-5/16".
When I pick up the trailer, I will be taking roads less traveled straight to my Truck Service place to get it replaced.
I may ship to Bulldog to have them determine what may have caused the failure.
John, the 2-5/16 sounds like a safe bet.  I doubt you'll have to worry after that.
Since you had the latch pinned, I would assume that the issue was caused by the wire part that connected from the latch to the collar. I don't see how that collar can slide back allowing the coupler to open without some type of deformation to, or disconnection of, that wire.
Let us know what Bulldog tells you.
Even if the collar did slide back somehow, how did the spring-loaded coupler gate manage to re-close so the collar could slide back into place? I can't see it. Either the ball doesn't fit the coupler properly (coupler socket or ball damaged or wrong size), one of the springs is broken, the ball was never in the coupler to start with, or the coupler wasn't latched.
Now I'm wondering if Oliver taught us to use the Bulldog incorrectly when we took delivery. He had us lower the coupler onto the ball with the coupler latch handle in the *down* position, then use a foot or rubber mallet to close the coupler around the ball. At that point the collar snaps closed and we put the pin in. Now I see there's another (better?) way to do it.
We all do this and I'm sure you've done it correctly 100s of times. Don't we all also eyeball all hitch connections 2-3 times before we leave and every time we stop? If it was not connected correctly, it would have fallen off in the first few miles while still towing at low speed.
Wondering how much OTT will quote? Pretty good price in the link I supplied above for the same Bulldog part. Here are my before & after pics! The only hard part with this installation is marking the correct positions for the drill holes on the new Bulldog.
The larger ball helps and with the 12.5K rating you will have a 2x safety margin, given most Olivers loaded are a little over 6K LBS.
@John Dorrer glad you're OK!
Reed used to post here.
He made a video about operating a Bulldog hitch, for those that would like to learn more about the Bulldog:
Edited by rideandfly
Bill 2015 LE2 2024 F-350 6.8L
John, if the hitch was closed and locked closed…..maybe a dumb question but are you sure that your hitch ball is in fact 2 inches and not 1 7/8? Accurately measure with calipers.
2017 Elite II, Hull #208
2019 Chevy HD 2500 Duramax
B & W Stow and Go with marked 2" & 2-5/16" on the top of each ball
Okay, thanks. I still can’t imagine the Bulldog popping off of a correctly sized ball. Mine is sort of close fitting. I’d still check the diameter accurately just in case and at least settle that question. Anyway I hope you can figure out what actually happened.
Edited by mountainoliver
Added information
Man this is a real mystery. So glad it ended well and that you and yours are safe! I have been reading all the posts trying to make sense of how this could happen, especially to a Bulldog hitch. If the hitch lever was indeed pinned in place and didn't pop open when you hit that bump, then the options become limited. Some thoughts about this:
You didn't show the ball in your pics, but I would have a close look at it for clues, including the possibility that it was out of spec and not the correct size. Or that from lack of lubrication, it was "ground down" to be out of round. This is unlikely but worth checking. If the ball doesn't give up any clues, I would check the pin on the Bulldog that creates the hinge that holds the two clamping pieces together. Do the two halve come together as they should? Did the pin somehow get bent increasing the closed opening of the hitch around the ball? It's just hard to imagine a Bulldog letting go of the ball like that if all was in spec. I assume your hitch setup with your TV is nice and flat, not nose up or down. Just throwing out these ideas to try and figure this out. Hope you will let us know what you find out. Definitely take JD's advice and get a new hitch! Sizing up would be good as you would get a new ball as well. Again, glad everyone is OK, and kudos to you for keeping control of your rig.
Cheers,
Dave
2015 Oliver Elite 1, Hull 107
Cheers,
Dave
Ball was greased. I used a grease remover and cleaned it completely up to a nice shiney chrome finish. I took a number of photos and sent them to a tech at B & W and he didn't see anything strange on the ball.🙃
Typo
Next time at your storage, take a good look at the jack post to see if it’s straight and can fully extend and retract.
If you need a new post, I’ve got one, could ship to you. 😎
Edited by jd1923
We have a fairly steep driveway, and the front is way up to get the trailer level. It works fine. I ordered a new foot plate from Barker.
