Hello all, just joined and happily waiting for delivery of my Apex 23 the first of October. Wondering if a few of “yall” owners would share information on the types of blocks/chalks, hitch lock, ladder and/or other Oliver unique items you’d suggest I get before delivery. Thanks!
DR -
Welcome to our Family!
Bet ya can't wait for that new Apex.  Make sure that you ask your Sales person what items are included at delivery with your new Ollie.  This information will help you to either delay purchase or only get those things that you believe will suit your type of camping/travel.
Any chance that you are planning on attending the annual Owner's Rally?  If yes, then really delay so that you can see what others have .
Next - start reading this Forum specifically looking for mods that might interest you.  For instance - the use of "blocks" to shorten the distance your "levelers" have to travel is a practice used by many of us.  These blocks not only save wear and tear on your levelers but also act as a "slip plane" (something that easily slides away such that a more permanent thing like you jack/leveler is not harmed) in the event you mistakenly leave the leveler down while moving the Ollie.  Blocks can be as simple as a stack of wood, or, a 6x6 10 to 11 inch long block of wood, or, something like an Andersen block like THIS or THIS or "legos" like This or some combination of all these.
Another item to consider is some type of side to side leveling helper - again like stacks of lumber or the "lego" blocks mentioned above or "ramps" such as THESE from Andersen.
Once you have taken a look to see what's out there, come on back here and ask about the goods and bads of a particular item.  Most likely you will get a variety of opinions on just about any single item, so, again, it would be helpful to detail what your intent is for usage.
Have fun with all of this but don't go crazy until you get some idea of what things just might work best for YOU.
Check out the Oliver Outfitters guide:
Oliver Outfitters Guide on Amazon
also look over our travel web page for camping reviews and blog posts
4 Ever Hitched Blog
also found at the bottom of our signature below.
Edited by Galway Girl
22 hours ago, topgun2 said:
DR -
Thank you sir and I’m definitely excited to get into the Apex! I appreciate the advice and “yes” I’ll be at the annual rally (site F-22 to make your Topgun moniker smile…).
  • 2 months later...
Douglas,
Just reading your post about the Rally and site F22.
We are taking delivery of our Apex, 2Dreamin, on September 14th and will be at the rally in site F-20.
See you there!!!
While waiting for delivery, we have gathered up items we kept from our Airstream Interstate Class B and replacing items we got rid of, uggggg.  For the F350 SuperDuty a GenY Torsion Hitich with Locks, 100% extended no-drill Bedslide from Ford for easier access to the truck bed, Leer Cap, Rhino Rachet Straps, Rockstar flaps, Bulletpoint mounts and a Proven Coupler Lock for the Apex.  BAL chocks between the wheels, Andersen Stabilizer Blocks, chocks behind the wheels, blocks for leveling (didn't get the curved Andersen levelers as we weren't sure of the distance of the mud tires since they are larger tires, can always add them later).  LevelMate, 8 x 20 CGear outside mat, 2 x 10 runner for inside, Hasko paper towel holder, various Toolertries, thank goodness we had stuff left from our van...........but I still gotta get a broom, if I can remember, LOL!!!
Hull #1738, still in the making with only 1 week left!!!!!
I'll add our two cents. We've had our new-to-us Ollie for 18 months or so and are still finding stuff we think we need. We moved from a truck camper to the Ollie and thought we had most of what we needed, but....
As @FirstApex mentioned, I suggest a LevelMate Pro (so you can power from the Ollie):
https://www.amazon.com/LogicBlue-Technology-LevelMatePRO-Wireless-Leveling/dp/B01FGGSWPW/
TPMS system to monitor the tires (you'll need metal valve stems):
https://www.amazon.com/TST-507-FT-4-C-Repeater-Temperature-Monitoring-System/dp/B08W3QZ499/
Induction countertop cooktop and induction compatible cookware for inside and outside and
many people have grills (Blackstone, Weber, etc.).
We have a Paclock hitch lock (similar to the Proven) and a Collar lock to secure the latch (if you have the Bulldog coupler).
https://www.amazon.com/PACLOCKs-UCS-77S-BUL-2516-Trailer-Coupler-Integrated-Stainless-Steel/dp/B0DLLQPB15/ or
https://www.amazon.com/Proven-Industries-2516-Heavy-Duty-Couplers/dp/B0G319Y11G/
https://www.amazon.com/Collar-Trailer-Bulldog-style-Couplers-Including/dp/B00HL2NM0K/
You'll want an Electrical Management System (EMS) for the campground power post (in addition to the onboard EMS), a 30 AMP circuit tester and a non-contact voltage detector and outlet tester.
https://www.amazon.com/gp/aw/d/B01N0W4CZ8/
https://www.amazon.com/Progressive-Industries-Receptacle-Tester-Black/dp/B088CWBBBM/
https://www.amazon.com/Klein-Tools-80025-Non-Contact-Voltage/dp/B0912Z1W88/
Don't know what hitch size the Apex comes with but I'd ask for the 2 5/16" coupler.
There's lots of info on the forums. I suggest using @Wayfinder's search tool found on this post:
New to us 2017 Legacy Elite II Hull #251 (with updates)
TV:  2023 Tundra Double Cab 4x4 TRD Sport (Now with Engine #2)
These lists can get really long and temping to buy all the things when you get started. We are in our third year and recently switched over to these for leveling and love them. Put these down and turn on level-mate pro and getting level is easy. Way easier then pulling on and off different sets of blocks.
Todd & Kat
On 9/7/2026 at 7:37 PM, FirstApex said:
(I didn't get the curved Andersen levelers as we weren't sure of the distance of the mud tires since they are larger tires, can always add them later).
I’m 100% with @Todd B on his post above. I have the name brand Andersen version and wouldn’t camp without them. After two years though the red ones sure are beat. This Amazon item has a 4.7 rating with 3K reviews which is huge! Camping in the mountains I wish they were taller than 4” but taller might not fit between the tires!
The Apex has AT tires but is the diameter actually larger? I don’t think OTT would design a suspension that would not accept these levelers. You should ask them or know the tire brand and size and can find the dia in the tire specs.
