As others have done, I recently completed a Victron Orion XS DC-DC charger installation between my 2023 Ram 1500 and 2019 Oliver Legacy Elite II, Hull 514.
The attached write-up covers the truck and trailer wiring, Anderson SB120 connection, cable routing, fuse locations, Victron settings, parts list, photos, and lessons learned. I thought I'd share in case it helps anyone considering a similar project.
Happy camping!
Oliver and RAM DC-DC Charger Installation FB pdf.pdf
  • Like 10
Jeff, Linda, and Rosa (our Golden Retriever) | Central AL | 2019 LE II #514 | TV: 2023 RAM 1500image.thumb.png.fdaa7ecf3c6d41bac95a3923cec2ce49.png
Excellent work, Jeff! And happy to see a new Forum Member share such a great project providing such detail.
I installed ours March 2025 and we love this mod more than most! The Orion XS 50A DC-DC charger is the best possible upgrade for charging LI batteries. You need a whole lot of solar capacity and a lot of time sitting around the campsite, fussing with panels, and you won't get anywhere near the average 40 Ah per hour towing this installation will provide.
If interested, read my comment re running our A/C all day, towing just 2 hours, using only 20 Ah because the Orion provided most of the power needed. If I towed another 30 minutes SOC would have been 100%! We do have 320W rooftop solar but it was a cloudy/rainy day. https://olivertraveltrailers.com/forums/topic/11177-furrion-chill-cube-–-product-review-and-installation/page/3/#comment-126555
Those of us who boondock 1-3 nights at a time, moving often, don't need much else. Add an efficient A/C and Orion DC-DC charging will allow you to stay cool anywhere/anytime! We added 400W suitcase solar and wish I had saved the money since we rarely use it. We connect our Orion DC-DC charger every time we hitch the Oliver!
You love your Orion installation now. You'll love it even more after you benefit from it on the road! 😎
Edited by jd1923
Thanks for your kind words. Your comments about the DC-DC charger are great and my thinking as well. The 40A just keeps coming as long as you are hooked up and running. We boondock multiple days at a time quite often and I'm thinking I could even hook up in camp and charge via DC-DC if solar is inadequate and if for some reason I don't want to (or can't) run my generator to recharge.
I still haven't totally ruled out adding roof solar at some point, but I'm on the fence about it since the vast majority of our camping is in areas with lots of shade. Our hull is prewired for it and has the embedded mounting plates. So far, our suitcase panels are good for accessing the sunny spots.
Thanks for the link. I love reading the AC posts and your data is impressive. I figure our AC will need to be replaced at some point (already 7 years old) and I'd love to have a high efficiency AC that could run from the battery bank for an extended time. We are in the humid south, so this can be a taller order at peak summer temps, but we could expand our current 400Ah battery bank as well.
Thanks for sharing, vital information for owners considering such an install. Here’s a couple of pics on cable management:
2020 OLEll, Twin, 579:
You're welcome! Your work and supporting documentation is a positive addition!
With the DC-DC charger, and an increase in Ah storage, you can make running your TV sitting at a campsite or running a generator quite unnecessary. Nobody likes hearing a generator anyway, so just give it away to some poor soul still running lead acid batteries! 🤣
Rooftop solar; it's nice having them up there. When parked outside the rooftop solar runs our day-to-day needs. Perhaps a good addition for the future to-do list. When you do so, please do not drill mounting holes! You only need 1-2 holes for the wiring with a dab of Dicor to seal them. The standard 1x3” Renogy solar panel mounting brackets can be mounted to fiberglass using only a 3” strip of 3M VHB tape (2x stronger than screws in fiberglass).
Smart to replace your A/C ASAP if you've been listening to that ROCK CONCERT known as the Dometic Penguin II A/C! 🤣 If you're camping in the hot & humid SE, even in the shoulder seasons, you will need to up your 400 Ah storage to run an efficient inverter or variable speed A/C unplugged.
Yesterday was 98F up here at 5400 ft and was 116F in the desert valley below. I have a Ruuvi sensor on the roof of our Oliver, under the solar panels, which reported 115F with 16% RH at 1PM. It’s a “dry heat” but only in the shade, LOL! You could cook eggs on top of the solar panels! We don't go to The Valley in the summer months! Up here after dinner it will be in the 70s, high of 98F, low of 68F. Of course at low altitude where it's humid it doesn't cool down as much at night.
The Chill Cube cooled our cabin down to 76F all day long, got to its set temp of 74F once the sun set, and for 24 hours we used only 220 Ah in battery storage. Extremely bright sun supplied another +/- 160 Ah by solar charger all day long. Think that the Orion XS 50A can add equal Ahs in 4 hours towing vs. all day long with 320W rooftop solar.
I could not imagine all this 2 years ago when I started working our mods! Now that you have a proper DC-DC charger, my suggestion is more Ah storage capacity. You should have room to add more of the same batteries and if you need to, remove the tray. 😎
Edited by jd1923
Added pic
I am posting this as educational only, not to start a debate on it. I like it more just to understand what was happening with the alternator when doing DC/DC charging. So, given this thread, I thought others might find the insight useful. Again, not getting into the debate of if it is good or bad but just education on what your alternator is doing.
Todd & Kat
Thanks for posting, educational for me, too.
Bill 2015 LE2 2024 F-350 6.8L
7 hours ago, Todd B said:
I am posting this as educational only, not to start a debate on it. I like it more just to understand what was happening with the alternator when doing DC/DC charging...
Alternator specs should be reviewed and often when adding a DC-DC charger the OEM alternator should be replaced with a higher amp model. Most truck manufacturers offer an upgrade alternator (e.g. snow plow upgrade) and there are many aftermarket sources offering superior materials and copper windings, and smaller diameter pulleys to increase alternator RPM.
Our TV came OEM with a 130A alternator. I certainly did not expect it to handle its design load plus another 50A. Simple math is to upgrade the alternator to one that produces 50A additional over your OEM capacity. Nations is a reliable aftermarket supplier. Months prior to our DC-DC mod, I spent $330 total for a HD 180A Nations alternator. Like everything else they look to be more expensive now and will be more expensive for late model trucks that come stock with higher amperage alternators.
https://www.nationsstarteralternator.com/High-Amp-Alternators-s/58.htm
This topic was discussed in my build thread and I added comments before to warn Oliver Owners on other past posts re DC-DC charging. This link goes directly to my comment re upgrading the alternator too! 😎
Exactly what I did, Mechman 320 Amp High Output alternator.
I have a 2024 Nissan Titan XD.  The stock alternator is a high output 200 amp unit.  I am thinking I would be good to go for a DC/DC install... which is happening in November.   Does that sound right?
Thanks,
Scotty
"I thought I'd share in case it helps anyone considering a similar project. "
Thanks for sharing!  I just completed a very similar installation of a Victron Orion 12/12-50A DC/DC charger.  As I was preparing a write-up I found yours, which is very well done.  I don't have much to add.
That said, be grateful you could not find a Trailer Vision enclosure for an Anderson SB175/SB120  connector.  As you planned to do, I relied on previous posts that included the Trailer Vision products.  The spring-loaded, hinged cover on the one I installed on the truck side broke even before I got a change to test it out!   Your "homemade" aluminum bracket looks almost OEM, and the Trekboxx Panel Mount with the Anderson Environmental Boot not only looks good, but should be much more durable than the Trailer Vision product.
Thanks,
Scotty
Maybe, if a lower amp alternator is standard equipment. Check with some knowledgeable members on a Nissan Titan forum.
I recommend you ask Google AI.  I believe the Victron Orion XS 12/12-50A DC/DC charger can be programmed to reduce output (and therefore strain on the alternator) at idle, if necessary.  That feature may allow you to install one connected to your 200A alternator.
Hey Everyone,
I posed some questions about Alternator load with a DC/DC charger to Easton Ford at Inverter Services.  Here is the info I got back from him:
Q:    When you install a DC/DC charger, what considerations should you have on the alternator in the Tow Vehicle?
A:     What I take into account is how much load you have on the alternator with all of your heavy electrical loads running, then I clamp the alternator wire to see how many amps it is pulling, I then Add 50 amps(DC/DC) and I see if that number is above 75% of the full capacity of the alternator. If its under everything is good. If it is over I would let you know that its over and if you didn’t want to do the DC/Dc I would take it off the ticket. If you still wanted the DC/DC it can be turned down to draw less from the alternator.
Q:  Can the Victron DC/DC charger be set to draw a certain amount of power.
A:   Yes, the Victron DC/DC charger can be turned down from 1 to 50 amps
Q:   My tow vehicle (2024 Nissan Titan XD) currently has a heavy duty 200 amp alternator.  For me specifically, what would you recommend?
A:   For this vehicle I think one DC-DC would be fine no issues. If you want to have two DC-DCs I would want to clamp the alternator wire to make sure that we are not cutting it close. (2 dc/Dcs would equal up to 100Amps but it is highly programable to set it anywhere from 1-100)
My plan going forward would be to have the alternator load tested and if it's within parameters, fine... if not, I will ask them to turn down the DC/DC charger to the appropriate number until I can arrange an alternator upgrade.
Hope this helps to answer any Alternator questions anyone else may have.
Happy Camping,
Scotty
First, great write-up.  Saved it to my DIY file. We also travel long and far, and having a Victron DC to DC has been wonderful.  Sadly ours is only the 30 amp verson.  But when it fails, I'll be digging out my saved DIY of your efforts.  So thanks in the future a second time.
I too am open to roof mount solar, some day.  Just don't like the look or their potential MPG impact, especially out west with high speed limits.  I'm hopeful that future surface mount panels will be made to allow "full" covoerage of our roof.  Specifically from the low outter sections to the main middle section curves.  Current surface mounts that I have looked at don't have adequate bend radius to cover all three areas fully.  Besides the power benefit, it would sure make waxing Ollie's top a LOT easier.
Thanks again,
