On 10/11/2017 at 6:46 AM, Mike and Carol said:
Matt, I’ve used Boerne RV Service and was happy with their work.
Boerne RV Service, 125 Industrial Drive, Boerne, TX 78006
Excellent, that's near my Texas Base, thanks!
Jack and Kathryn
2022 LEII Hull 1260 - 2020 Ram 2500
  • 7 months later...
I just had an electrical system overhaul done by Royal Coach RV in Bakersfield, CA. They did an excellent job.
TV:  2008 F-350 Crew Cab, 6.4L diesel, 4WD, custom flatbed with storage boxes, Line-X underbody coating      OLLIE:  2022 OE1 Hull 885, Lithium batteries (260AH), 230W solar panels, 2000W Pro inverter, Dometic AC w/Easy Start, Truma Tankless Comfort water heater
ALAZARCACOGAILKSKYMONVNMNCOKSCTNTXUTsm.j
What had gone wrong that required an overhaul of the electrical system?
My inverter wouldn't switch from battery to grid mode when I connected to shore power. The mechanic found that the neutral cable into the transfer switch had come completely loose, so the inverter in fact wasn't getting any shore power. It has been reconnected, snugged down tight, and so far, everything is working properly.
I used Eagle Rock RV Service in Idaho Falls, ID for a lube and wheel bearings pack. They were great.
Are all this Oliver "qualified and reputable RV maintenance facilities" documented somewhere?
That would be handy dandy info.
HDRIDER -
As per the very first post in this thread by Matt Duncan, Oliver was/is in the process of collecting this information.
To my knowledge - any names on this collected list have not been published to date.
1 hour ago, topgun2 said:
HDRIDER -
Starting in October 11, 2017
That is six years.  How long should we wait?
  • Sad 1
Well -
I don't know.  Since this list was being compiled from recommendations submitted by Oliver Owners and primarily submission was via the Forum I really don't see that many recommendations when scanning the thread.  It should be a fairly simple matter to simply copy these names down if you're interested.
Good luck!
  • Sad 1
  • 1 month later...
Loveland/Fort Collins Colorado
We have twice used Nathan RV Service and Repair. He moved from Fort Collins to Weldona. Oliver recommended him. He has twice done maintainence on our Oliver.The first time he replaced the flooring. This time he replace the Automatic Transfer Switch which had failed.  He is thorough and price was quite reasonable. He took plenty of time when we picked it up to answer our questions. He loves working on Olivers.. he said they make the best campers!
Hope this helps someone.
Linda
OEII #111
  • Like 9
2016 Oliver Elite 2 #111 Tow vehicle Porsche Cayenne 2008
States Visited Map
  • 5 months later...
Well, now I have to give an amendment. Just took off my tires yesterday to grease the zerks. The street side torque was good. The curb side wheels were way over-torqued and the threads were stretched on some studs. Boo. I gotta replace them now. It was the last rig they worked on that day at this shop and wasn't finished till 5:30. My guess is that the technician was in a rush, was using an airgun, and just jammed those lug nuts on while thinking of going home. Another reason to try to do more and more maintenance myself, with the help of these forums of course!
  • Wow 3
  • Sad 2
Excellent of you to do the follow-up and to notice something this detailed. Many would not have noticed. A good check to see if they are truly deformed is to take a good nut from the other side (better yet a brand-new nut). If it threads nicely by hand the threads are good, if it gets stuck you know the rest.
This may be blasphemy to many of you, but I've been using a pneumatic impact wrench for decades when mounting rims, without manually checking torque. I have a quality impact wrench, very much like this one (wow mine was about $140, 35 years ago): Ingersoll Rand 2146Q1MAX 3/4-Inch Drive, Air Impact Wrench, Quiet, 2,000 ft-lbs Nut-busting torque, Maintenance Duty, Pistol Grip, Standard Anvil , Gray - Amazon.com
First the "nut-busting torque" is for pulling nuts. The gun will not produce this torque when in righty-tighty position. Notice the 4 torque settings. I use the lowest setting when first mounting and get all lugs to this level (compressor set at 90 PSI). For automobiles or anything with 1/2" studs, I use the second setting as final torque. For 6-8 lug truck wheels the 3rd setting is good. I would not use the 4th setting for wheel lugs. Did that once by mistake when restoring our GX470 and broke a stud, and a round-trip to Napa to replace it.
Torque settings are based on the strength of the steel (Grade 5, Grade 8, etc.), the bolt diameter and whether it's a coarse or fine thread bolt. There is recommended torque for every bolt. Problem is when for example rebuilding a truck suspension, you cannot fit a torque wrench on 2 out of 3 bolts. Maturing into the role of being a mechanic you get used to the feel of how tight is right.
Love this Toyota guy! He taught me so much when restoring our GX, changing the CV axles, adding a 2" lift, etc. His catch phrase is "good-n-tight" which he says often, kidding in a German accent: Lexus GX470 Front Brake Upgrade - YouTube
After mounting a rim, a few days or few miles later, I check the lugnuts again, this time by hand. Not using a torque wrench, but with a 24" long 3/4" breaker bar, 1/2" reducer with appropriate socket attached. I mount it about 90 degrees to the ground and push down with my foot. If it's a car, I just push down a little. On the 2500-series truck I put a bit of my weight on it. On occasion you find one or some that are somewhat looser and only those need a little more. If they all feel about the same, then you're good. Always recheck recent repair work at least visually.
Another check I do on a regular basis is to rock the wheel. When parked flat, put your foot on the top of the wheel and push back and forth to rock the vehicle as hard as possible. Use your eyes and ears to notice anything. This is a simple check of lugs, bearings and other steering or suspension components.
  • 3 months later...
This subject is of great interest to me as I am located in in Western Washington State.  Hohenwald is a l-o-n-g way from me, and I am having some issues with a recent swap of the Penguin to FreshJet3 A/C's.
For those who have an interest, Bretz RV in Liberty Lake, Washington still does not have a functional service department. Their Missoula, MT location does have a service department, but it has NO ONE there who has been trained by Oliver (on site or back at Hohenwald). Due to distance, I decided not to call Bretz at Nampa/Boise, ID.  The whole concept of "distributed Oliver sales and service" will eventually depend on Oliver owners having confidence in the ability of their local "Joe's RV" not only being able to sell them an Oliver, but also be qualified to maintain it. (For a $110K trailer, that confidence will make or break a sales decision.)  At this point, those of us in Washington State are seeing little reason to be confident of any of that.
Edited by theOrca
theOrca,  2020 Legacy Elite II, Twin, Hull 615
Tow Vehicle - 2016 Ram 1500, Hemi, 8 Speed with 1500# rear springs and Goodyear bags.
  • 3 weeks later...
FWIW, an update on this facility. I contacted the service manager, Adam, who said to bring it in. As chance would have it, I found myself in the area again this year, one year later, and dropped it off. Adam took care of everything and threw in a lube, all comped. Wow. I now again can fully recommend this RV service center.
Just for the sake of clarity - are you talking about Bretz RV?
Eagle Rock RV in Idaho Falls, ID
  • 2 months later...
Thank you for following up on this. I consider this excellent service.
  • 11 months later...
You sure got that right.  I own an Ollie and am not happy.
Hiroshi
2023 Oliver Elite #1299
2024 Lexus GX550 Overtrail
In 10 years we’ve had our Oliver serviced by Oliver service folks twice.  Every other time has been by a local RV repair shop with no Oliver training.  Most RV issues are generic and a qualified RV tech can almost always get resolution.   Oliver has covered my warranty issues when addressed at my independent RV repair shop.  Even when we temporarily had an authorized Oliver service location at Princess Craft RV up near Austin (2 hour drive) I stayed with my local guy, just 10 minutes away and very competent and trustworthy.
You state that you own an Ollie but the membership profile that you filled out says that you Do Not own an Oliver. Is this a recent purchase and you've just failed to update your information? Please take care of it.
OTT should have never considered working with dealers. It was unique that Olivers were sold and serviced at what some here call the "Mothership!"
A sales manager at our local Blue Compass dealer said, "Nice Trailer, want to trade it in?" as I was draining tanks at their free dump station, right down the street. I then asked him about the dealership idea. He replied, "There's no money in selling Olivers! I can sell 10 Winnebagos, and 20 Thors, ... in a month where we might sell one Oliver."
Yep, Hohenwald TN is far-far-away and in our 2 1/2 years we've done fine getting things done locally, no travel necessary. Even our Oliver was listed on Prescott Craigslist! Upon sale, prior owner delivered it, backed it right into our home RV parking spot! 😎
Be a bit careful in that there were MANY reasons Oliver chose to go the route they did.  Actually one of the reasons was that WE (the current owners) were asking for ways to get service, delivery, and even new Oliver sales in locations other than Hohenwald.  Oliver considered the risks associated with external dealerships and service centers and decided that as long as they could align themselves with ongoing operations that mirrored the family oriented operations of Oliver Travel Trailers, they would stand a chance of actually developing a "win-win" for the company and its customers.  Unfortunately, it appears as though finding these family oriented businesses that treat customers and their product in exactly the same manner was a bit more difficult than planned.  Obviously the aftermath of the Covid era has not helped either Oliver or the entire RV industry in general.
Edited by topgun2
Highway Trailer Sales in Salem, OR greased our zerks, and has a very good service department. I would go back in a heartbeat if we were going to be in Oregon again. Not in Western Washington, but considerably closer than Hoenwald, TN.
Edited by John Dorrer
Typo
Agreed, an example to the contrary is Blue Compass RV. They are a chain buying independents around the country. We had a local company “Affinity RV” with 4 locations in our county (not that they were great, service always booked months out). I bought an occasional part from them. Two years ago they sold to Blue Compass (hardly family-oriented)!
Edited by jd1923
typo
