Excellent solution and execution.
It’s funny because I always thought we would order a standard bed when the time came.  I didn’t think my better half would go for the twin bed version.  Low and behold, we found a 6 month old 2017 standard bed and used the big bed for 1 trip.  We did not like devoting 40% of the space to a bed and did not like converting it to booth table each morning.  So we tried different sleeping arrangements and settled on the dinette for Krunch and the back bench for me and the dogs stay on either side bench.
And then over Labor Day week the factory converted it to the twin bed configuration.  We bought mattresses from Southern Mattress and they shipped then to Hohenwald.  Next week is our first trip as a twin bed and I am hoping for the best.
  • Thanks 4
What a clever and creative idea!  I look forward to hearing how it all works this next month!
Happy Trails!
Kevin and Kathi
TV: 2018 GMC 2500 HD Sierra Duramax 4 x 4
“Do Your Own Ride”
Now that was thinking outside the box Mike, I really like that idea. I have made our's into a king a couple time when we take the Grandkids for a couple weeks in the summer looks good and a lot less extra structure with your method. Thanks Gary
Gary & Jona
2016 Silverado 2500 Diesel
Legacy Elite II Hull 81
OK, Mike - got a question.  Given the size of both you and Carol why did you use 3/4 inch plywood?
Seriously - good job.  Assume that you cut that edge with a router?
very nice….. were your mattresses the KTT from Oliver?
The mattresses were what Oliver was using when we ordered in Sept 2015. They must be KTT. Mike
OK, Mike – got a question. Given the size of both you and Carol why did you use 3/4 inch plywood?
Seriously – good job. Assume that you cut that edge with a router?
I was going to use 1/8” plywood but that didn’t leave much for the edge recess to lock. ? I cut it on my table saw with a dado set. It’s a bit more exact than a router. Mike
Mike,
I hope you had a great trip.
How did your mods work out?  Any adjustments needed?
Andrew
Andrew
Mike,
Andrew
We’ve had a couple of good trips since this and we’re getting ready to go out again next Thursday. The mod has worked well. It’s important that the density of the middle cushions match the mattresses, otherwise it’s a bit uncomfortable. We found this out on the first iteration just using some high density foam for the middle. The new dinette cushions are a very close match to the mattresses and are much more comfortable. The larger back cushion on the dinette has not been an issue. The new bottom cushion configuration does move more when you get up, but it’s easy to straighten back out.
The only thing I would do different is to make two plywood pieces instead of three. I did three because I had some scrap cabinet grade plywood pieces that weren’t big enough. All in all, we’re happy with this modification. Mike
we were so used to sleeping together that it would be nice to be able to occasionally convert the twin beds to a double bed.
I did a similar mod - but getting in and out of bed - is just a pain. Not sure how many times I'll actually use the larger bed set up. I like having the option however.
I use a single board set-up, fabricated some aluminum removable hangers, and it installs at same level as cushions, between the opening. Plywood stores under bed area cushions when not in use, hangers - in a drawer. KISS principle in use.
RB
  • 3 weeks later...
We did essentially the same conversion with the exception of creating the platform also as the lagun table top.  I posted this on overland's topic regarding his custom lagun table bracket.  The details are posted on our blog here.
Cheers,
Mark
Mark B
LEII Twin hull #391
2013 Tundra
