hobo Posted February 14, 2020 Posted February 14, 2020 At the rally last year (or perhaps the year before) I noted a couple of folks who had put a small wire tether on their access port covers. At least one person advised me that they actually used the safety wires for light fixtures as their source of their tethers. They also advised that they had a few of them and would send me one if I sent them a note after the rally. Well of course, I forgot who this person was so I am seeking to find that person or otherwise, have anyone on the forum advise the best way to accomplish the task at hand. Thanks, Hobo 2018 Elite II, Hull #414 (the very last 2018 produced). Trailer name "2 HOBOS" . 2018 F250 4X4 Crew Cab, 6.7L diesel
Moderators mossemi Posted February 14, 2020 Moderators Posted February 14, 2020 Good morning Hobo! We stayed section F, about as far from the lake as we could get and I use a short wire cable to secure my propane access port. I believe you were just down the road from us. I have already put 10 or 12 of the cables in my OTT to give away at the rally to anyone interested. "the dog house" will be in the same spot. 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Frank C Posted February 14, 2020 Posted February 14, 2020 (edited) Thanks for this idea! Time for another update to the Ollie. I needed something to tinker with during the winter. 🙂 Found these on Amazon (of course). A couple small eye-bolts and a small swivel (to allow unscrewing of the port cover without twisting the cable) should do the trick. https://www.amazon.com/dp/B07QKWXGL1/ref=cm_sw_r_cp_api_i_jyPrEbHM3TRKR Edited February 14, 2020 by FrankC
Mainiac Posted February 14, 2020 Posted February 14, 2020 We used a piece of "parachute" cord. It happened to be bright purple. After that we put on a crimp-on 12 v electrical fitting. The one with the hole in it. Our hatch was self installed (just before Oliver made them standard). Ours has a place to put a small screw through the electrical piece and into the hole in the cover. The screw isn't fetched up tight so it can swivel. Also the cord can twist and not bind. One of the nuts holding the hatch on was loosened and another crimp on was added. After crimping the fitting we heat treated (melted) the nylon cord and as it melted it swelled so the fitting couldn't slide off. Without this tether I am sure the cover would be sitting on the edge of a back road somewhere. There might even be a picture on here someplace awhile back. My pictures are on another device and the Oliver is in a line to get the Dexters checked. 2 1
Moderators topgun2 Posted February 14, 2020 Moderators Posted February 14, 2020 (edited) Here's a pic of Mainiac's mod which I copied after he posted it back in 2017. Edited February 14, 2020 by topgun2 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Mainiac Posted February 15, 2020 Posted February 15, 2020 Thanks...knew it existed out there somewhere😊 1
Moderators topgun2 Posted February 15, 2020 Moderators Posted February 15, 2020 You're welcome - it did take me a bit of time to find it. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Overland Posted February 15, 2020 Posted February 15, 2020 An even easier method is to screw a small screw eye into the cap and tie the cord to that.
hobo Posted February 19, 2020 Author Posted February 19, 2020 While on this subject, I have a hard time getting my cover to screw on evenly and smoothly. Seems like it is being-cross threaded at times. Was wondering if a lubricant of some nature might make this easier. Any suggestions? 2018 Elite II, Hull #414 (the very last 2018 produced). Trailer name "2 HOBOS" . 2018 F250 4X4 Crew Cab, 6.7L diesel
Moderators topgun2 Posted February 19, 2020 Moderators Posted February 19, 2020 (edited) hobo - I give those threads a shot of "303 Protectant" a couple of times a year. I'm sure that a pure silicon spray would do just as well or even simply rub those threads with paraffin wax. Bill Edited February 19, 2020 by topgun2 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Trainman Posted February 19, 2020 Posted February 19, 2020 True, screwing plastic to plastic (PVC) can be hard to do at times, plastic just wants to be grabby and a little silicon will take care of that. trainman 1 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
bhncb Posted February 19, 2020 Posted February 19, 2020 2 hours ago, hobo said: While on this subject, I have a hard time getting my cover to screw on evenly and smoothly. Seems like it is being-cross threaded at times. Was wondering if a lubricant of some nature might make this easier. Any suggestions? Hold the cover in place and turn counter-clockwise until you feel/hear the threads engage, then turn clockwise until snug. 3 1
Mainiac Posted February 19, 2020 Posted February 19, 2020 If you can't find the silicone, or it has run out, try a bar of soap. The wet side in the dish is best. Just rub on the threads. If you don't like it, it should just wash off... 1
