Pat Maundrell Posted April 8, 2021 Posted April 8, 2021 (edited) One of the features we like about the EL2 Twin Bed layout is the ability to sit in the "Stateroom" and enjoy the 180 degree views through the windows while having something to eat or drink. Of course you need a table to do this, i.e. a Lagna Table is one solution. We decided to try another approach, but will keep the Lagna Table option as a Backup alternative. The attached picture shows the prototype (not the final finished model.) I wanted to try this idea to see if it was feasible before I committed to more expensive wood etc. Our plans are to add a "Nautical Theme" to our Oliver, i.e. Teak Table Tops with Compass Roses etc. This pictures shows our inexpensive Pull Out Table made out of 1/2 inch plywood with Teak Trim. So far it has exceeded our expectations, although maybe a little small to have a meal at. Edited April 9, 2021 by Overland Fixed photo rotation 1 7 1
Stevon Posted April 9, 2021 Posted April 9, 2021 We won’t get our Eii until July and will not be able to do any custom work until next winter. I think this idea is great. I look forward to seeing pictures of the final project. 2021 Oliver Legacy Elite II Hull #845
Mattnan Posted April 9, 2021 Posted April 9, 2021 We did the side mount Lagun table in mahogany with 2 folding leaves. I like your option. It looks really nice. Plus it appears to completely stow out of the way easily. The Lagun provides additional flexibility in positioning but more effort to stow away. Very nice modification!!
dhaig Posted April 9, 2021 Posted April 9, 2021 We have just ordered an LEII, and currently have 1/7/22 delivery date. I also like your mod and hope you will share construction details. I also contemplate mounting a Lagun table using the design by Overland, mounted under a bed rail. North Texas | 2022 LEII, Hull #990, delivered 2/17/22 | 2014 BMW X5 35d
Patriot Posted April 9, 2021 Posted April 9, 2021 (edited) I like the prototype and look forward to seeing the finished table top. Have you determined how you will keep the slide out table secured during travel? Thanks for posting! -Patriot Edited April 9, 2021 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Overland Posted April 9, 2021 Posted April 9, 2021 (edited) I really like this. Great idea. Does the pull out stay pretty stable? How far will it extend? I could see the same idea being very useful at the dinette, too. Edited April 9, 2021 by Overland
Pat Maundrell Posted April 9, 2021 Author Posted April 9, 2021 2 hours ago, Overland said: I really like this. Great idea. Does the pull out stay pretty stable? How far will it extend? I could see the same idea being very useful at the dinette, too. I am trying to send more pics but I am having trouble. The Pull Out Table relies on friction to keep it in place, It is a tight fit, although adjustable to your taste. The Table is 13 inch wide and can be pulled out 15 inches without any additional support. It can also be pulled out a total of 19 inches but does require a support prop underneath, which rests on the Basement Door wall. Hopefully I'll figure out why my pics aren't working, they show all of this. 2
Pat Maundrell Posted April 9, 2021 Author Posted April 9, 2021 Just now, Pat Maundrell said: I am trying to send more pics but I am having trouble. The Pull Out Table relies on friction to keep it in place, It is a tight fit, although adjustable to your taste. The Table is 13 inch wide and can be pulled out 15 inches without any additional support. It can also be pulled out a total of 19 inches but does require a support prop underneath, which rests on the Basement Door wall. Hopefully I'll figure out why my pics aren't working, they show all of this. As far as the Dinette Table is concerned, I've already consider the same idea there, it shouldn't be a problem. Of course the Pull out Table on either the NightStand or Dinette Table won't be on the same Plane. 2
Moderators topgun2 Posted April 9, 2021 Moderators Posted April 9, 2021 1 hour ago, Pat Maundrell said: I am trying to send more pics but I am having trouble. Let us (Moderators) know if we can help you with posting your pics - we'd be happy to help. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Pat Maundrell Posted April 9, 2021 Author Posted April 9, 2021 7 hours ago, Patriot said: I like the prototype and look forward to seeing the finished table top. Have you determined how you will keep the slide out table secured during travel? Thanks for posting! -Patriot It held in by friction, you have to exert a little effort to Pull it out. It stayed put for 2500 miles. 1
Pat Maundrell Posted April 9, 2021 Author Posted April 9, 2021 1 hour ago, topgun2 said: Let us (Moderators) know if we can help you with posting your pics - we'd be happy to help. Bill Thanks, but the problem is between me and my Cell Phone. 1
Moderators topgun2 Posted April 9, 2021 Moderators Posted April 9, 2021 16 minutes ago, Pat Maundrell said: Thanks, but the problem is between me and my Cell Phone. Have you considered taking it out to lunch?😋 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Pat Maundrell Posted April 9, 2021 Author Posted April 9, 2021 2 minutes ago, topgun2 said: Have you considered taking it out to lunch?😋 Let me be clear, sadly the problem is 99% me.
Pat Maundrell Posted April 10, 2021 Author Posted April 10, 2021 7 hours ago, Pat Maundrell said: I am trying to send more pics but I am having trouble. The Pull Out Table relies on friction to keep it in place, It is a tight fit, although adjustable to your taste. The Table is 13 inch wide and can be pulled out 15 inches without any additional support. It can also be pulled out a total of 19 inches but does require a support prop underneath, which rests on the Basement Door wall. Hopefully I'll figure out why my pics aren't working, they show all of this. The below pics show the bottom of the Pull out table, note the Finger/Prop Cut outs, and the Underneath Support Prop required when the Table is exceeded to 19 inches-not required at 15 inches. The pics showing the Table extended is at 19 inches, we don't use it at that position, not needed, 15 inches is perfect. 1 2
Foy_Mirna Posted April 10, 2021 Posted April 10, 2021 Nicely done Pat! Good use of space and design concept. A suggestion for you, consider embedding the support rod on the bottom side of the side out and connecting the front support end of the rod with a pin. This would allow up and down moment of the support rod. In addition, it would allow the back of the rod to dropout when the side out is pull out far enough to need support. To close, simply lift the support rod up and back into the embedded slot and slide the top back in place. I look forward to seeing your final design. Onward, Onward, Foy and Mirna Roamy Mc Roadhouse 2017 Legacy Elite II, Twin Bed Hull #227 2021 RAM 1500 Limited
Moderators topgun2 Posted April 10, 2021 Moderators Posted April 10, 2021 11 hours ago, Foy_Mirna said: Nicely done Pat! Good use of space and design concept. Pat - This is really nice praise from a guy (and gal) that seem to know just a little about working with wood. I echo that praise. Also, it is nice to see that you and your phone are back on speaking terms - 😃 Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Pat Maundrell Posted April 10, 2021 Author Posted April 10, 2021 20 hours ago, Foy_Mirna said: Nicely done Pat! Good use of space and design concept. A suggestion for you, consider embedding the support rod on the bottom side of the side out and connecting the front support end of the rod with a pin. This would allow up and down moment of the support rod. In addition, it would allow the back of the rod to dropout when the side out is pull out far enough to need support. To close, simply lift the support rod up and back into the embedded slot and slide the top back in place. I look forward to seeing your final design. Onward, Good idea, I think I may use your suggestion in the final Table.
