Popular Post dedroll Posted September 19, 2021 Popular Post Posted September 19, 2021 My domestic fridge just stopped cooling, no signs of leakage. Everything testing good on the troubleshooting guides. The opinion of the local RV guy was that I had a failed cooling unit. That left me with two options: buy a new unit or replace the cooling unit. After talking to Jason at Oliver and him telling me that to remove the fridge from the trailer you need to remove the door, I thought I would try to replace the cooling unit myself. I found some places that would ship a unit for $500 to $1000 and I do the install. I watched many videos and researched the work. In this research I found several people talking about burping this kind of unit, it entails flipping the unit on its side, top and allowing the ammonia mixture to reposition and displace any air pockets. Since I had to remove the fridge from its housing I thought I would try it...and it worked! We just took a 10 day trip and it worked fine. Some RV techs said it was a wive's tale. Glad I tried it. Hope this might help somebody. 8 7 David and Jane Droll, Pulling Hull #238 with a 2018 Toyota Tundra
Moderators SeaDawg Posted September 19, 2021 Moderators Posted September 19, 2021 I've read about that, and I've seen a couple youtubes, but as far as I know, you're the first Oliver owner to give it a try. Wish we had a badge for that. So glad it worked for you! Out of curiosity, how long did you leave it flipped on its head? 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
dedroll Posted September 21, 2021 Author Posted September 21, 2021 Several hours on its side and on its head overnight mostly because I had no idea 2 David and Jane Droll, Pulling Hull #238 with a 2018 Toyota Tundra
Moderator+ ScubaRx Posted September 22, 2021 Moderator+ Posted September 22, 2021 Sounds like you preformed a refrigerant equivalent of the Canalith Repositioning Procedure. I’m impressed. That was a bold move and I’m really glad it worked for you. Do you have any idea what might have caused the original problem? 3 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderators topgun2 Posted September 22, 2021 Moderators Posted September 22, 2021 8 hours ago, ScubaRx said: Sounds like you preformed a refrigerant equivalent of the Canalith Repositioning Procedure. I didn't know these fridges have ears!😇 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
dedroll Posted September 22, 2021 Author Posted September 22, 2021 I am thinking that I tripped the trailer nose up to facilitate dumping my gray tank, after a bit I leveled it and it sat for several months. I had seen in a repair video the the workers who were installing the new cooling units made sure to tip them toward the "boiler" side before using. They said the ammonia could settle and not work properly. 1 David and Jane Droll, Pulling Hull #238 with a 2018 Toyota Tundra
Alison Posted July 30, 2024 Posted July 30, 2024 On 9/19/2021 at 1:40 PM, dedroll said: My domestic fridge just stopped cooling, no signs of leakage. Everything testing good on the troubleshooting guides. The opinion of the local RV guy was that I had a failed cooling unit. That left me with two options: buy a new unit or replace the cooling unit. After talking to Jason at Oliver and him telling me that to remove the fridge from the trailer you need to remove the door, I thought I would try to replace the cooling unit myself. I found some places that would ship a unit for $500 to $1000 and I do the install. I watched many videos and researched the work. In this research I found several people talking about burping this kind of unit, it entails flipping the unit on its side, top and allowing the ammonia mixture to reposition and displace any air pockets. Since I had to remove the fridge from its housing I thought I would try it...and it worked! We just took a 10 day trip and it worked fine. Some RV techs said it was a wive's tale. Glad I tried it. Hope this might help somebody. I just developed this same problem in my Dometic (2018 Oliver, Hull 310). Replaced the thermistor, that didn't fix it. I'm going to try this burping technique next, otherwise I'm looking at purchasing a new fridge! Wish me luck! 1 Alison, Ross & Annika Hull No. 310
Patriot Posted July 30, 2024 Posted July 30, 2024 1 hour ago, Alison said: I just developed this same problem in my Dometic (2018 Oliver, Hull 310). Replaced the thermistor, that didn't fix it. I'm going to try this burping technique next, otherwise I'm looking at purchasing a new fridge! Wish me luck! @Alison I sure hope it all works out and you don’t have to buy a new frig. Let us know if the burping technique works. 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
MAX Burner Posted July 31, 2024 Posted July 31, 2024 On 9/19/2021 at 1:40 PM, dedroll said: Since I had to remove the fridge from its housing I thought I would try it...and it worked! We just took a 10 day trip and it worked fine. Some RV techs said it was a wive's tale. I heard of this back in the day. This is a procedure used when a fridge is move from Pt. A to B on its side or back - when it arrives at the destination, its placed upside down over night before using it... The ammonia repositions its volume when upside down. Who knew? Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
SNY SD UP Posted July 31, 2024 Posted July 31, 2024 (edited) Thank Gawd, this procedure was explained. I envisioned struggling holding the fridge on my shoulder, whilst walking up-down the runway, patting it on its back. B~Out Edited July 31, 2024 by SNY SD UP 5 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
Boudicca908 Posted July 31, 2024 Posted July 31, 2024 On 9/19/2021 at 3:40 PM, dedroll said: In this research I found several people talking about burping this kind of unit, it entails flipping the unit on its side, top and allowing the ammonia mixture to reposition and displace any air pockets Great work on your research! If there's an applicable discussion or explanation online, maybe you could attach a link in your thread, for future reference? Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
