Frank C Posted July 6, 2022 Posted July 6, 2022 Just in case anyone wants to upgrade the 6” round plastic deck hatch on the propane tank “dog house” to something more substantial (and expensive!). There are stainless steel marine versions available that would be a lot more durable. Nice and shiny too! (Heavier than the plastic one though. Hate to add weight to a trailer). My plastic one is still looking pretty good even after a few years exposed to the elements though, so I’m sticking with it. Who else wants to be first to try one of these? Make your Ollie look even more like a high end yacht! 🙂 DYRABREST 6 inch Deck Plate Inspection Hatch Cover Stainless Steel Boat Marine Out Deck Plate Inspection Access Hatch Cover https://a.co/d/eYX82IM
Moderators mossemi Posted July 6, 2022 Moderators Posted July 6, 2022 My 6" inspection hatch in the propane tank housing is really discolored and this hatch would certainly be an upgrade. Maybe after I win a lottery! Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Trainman Posted July 6, 2022 Posted July 6, 2022 I just took the cover off and unscrewed the screw ring, sanded them with 180 grit sand paper, painted then with an outdoor white spray paint for plastics, cost $4.78 for the paint and still have 4/5 of the can left for future use. So I have about a dollar in the restoration and it turned out perfect, it's been one year since it was redone. trainman 6 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
Patriot Posted July 6, 2022 Posted July 6, 2022 19 minutes ago, mossemi said: My 6" inspection hatch in the propane tank housing is really discolored and this hatch would certainly be an upgrade. Maybe after I win a lottery! Mossey $13 for for the newer hatch that Oliver Service sold me. I prefer it over the threaded hatch. 5 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Frank C Posted July 6, 2022 Author Posted July 6, 2022 2 minutes ago, Patriot said: $13 for for the newer hatch that Oliver Service sold me. I prefer it over the threaded hatch. Is the new one hinged instead of threaded?
Moderators SeaDawg Posted July 6, 2022 Moderators Posted July 6, 2022 4 hours ago, FrankC said: (Heavier than the plastic one though. Hate to add weight to a trailer). Indeed. I was thinking about trying to handle that ss deck plate, mounted vertically , in the rain, and all I could think about was how much it would hurt if it slipped and fell on my foot, at over two pounds. Ouch. I think I'd stay with plastic or composite. Plenty of available choices. White blends better with the doghouse, especially since the off center installation would bother me, visually, in stainless. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Patriot Posted July 6, 2022 Posted July 6, 2022 4 hours ago, FrankC said: Is the new one hinged instead of threaded? I insert the lid into the hatch housing turn it and it clicks and it’s secured. Not sure if you call that a hinged? I really like the ease of use vs the threading version. 6 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Frank C Posted July 6, 2022 Author Posted July 6, 2022 Just now, Patriot said: I insert the lid into the hatch housing turn it and it clicks and it’s secured. Not sure if you call that a hinge. Ah, nice! Just a quarter turn type catch to retain the lid. Definitely more convenient than the full threaded type I have. 4
Trainman Posted July 7, 2022 Posted July 7, 2022 If you find it hard to thread the cover back on, use a little lube on the threads, Vaseline, WD-40, lite weight oil, doesn't take very much, less is probably better them too much. trainman 4 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
Geronimo John Posted March 26, 2024 Posted March 26, 2024 On 7/6/2022 at 10:20 AM, SeaDawg said: White blends better with the doghouse, especially since the off center installation would bother me, visually, in stainless. Darn it Sherry, I had not ever noticed the off center. Now that's all I see! DRATS! 🙂 GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
MAX Burner Posted March 26, 2024 Posted March 26, 2024 Our Dog House cap was getting a bit "gritty" and difficult to thread - so we swapped it with one of the "fresh" caps in the overheads, cleaned the threads on the DH side then lubed the cap w/a touch of Vaseline and attached the stainless steel lanyard (so as not to leave it adrift). All good again! 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
johnwen Posted April 30, 2024 Posted April 30, 2024 (edited) On 3/26/2024 at 6:16 PM, MAX Burner said: Our Dog House cap was getting a bit "gritty" and difficult to thread - so we swapped it with one of the "fresh" caps in the overheads, cleaned the threads on the DH side then lubed the cap w/a touch of Vaseline and attached the stainless steel lanyard (so as not to leave it adrift). All good again! Thank you I admit being a little "slower" than the average Ollie person and after reading your post I checked my overheads ... EUREKA...I would never have thought to look there for a replacement. Mine are not threaded but they are a direct match and we now have a "new" hatch for our dog house. The 3 little tabs on the original broke off and I was lucky to have it not blow off while traveling. I used some of my high dollar glue I got at Quartzsite this year to fashion some tabs to keep the hatch in place in the overhead. John Edited May 1, 2024 by johnwen 2 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
