Our two under cabinet Galley lights stopped working.  Every other light in the trailer works fine. We haven't moved the trailer in several weeks and Those lights were working just fine until yesterday morning.
I'd Suspect A fuse if others were also inop, (I don't see a fuse dedicated to lights, are they on the TV circuit?)
Not sure what else to check?
2018 LE2 #333  "the Otter"
2015 Silverado 2500HD
The touch lights are flakey.  Mine over the sink particularly so.  You can remove the cover and see if the spring contacts are messed up, but I've not read of any true repair process.  I got a few spares from Oliver Service.  FWIW, they aren't crazy about them either.
Liana -
Given your hull number I suspect that you have the "touch" lights (i.e. you touch or push them to turn them on)?
If this is the case then about all you can do is get replacements from Service.
Ours - over the stove - glows faintly when it's very, very dark.  If you close your eyes, you can't see it!
Charlie.
Oliver sells them for $3.15 each. I’ve lost 2 total in a year and a half.  I ordered 6 spares last week.
We don't Have touch lights. Simple on/off switch
No, we don't Have touch lights
Then most likely you just need new bulbs which are probably G4 type. I'd swap the bulbs with one of the working lights to confirm.
It looks like VERY tiny screws hold a retaining ring to remove them?
These are LED lights so more than likely it's the switch. Open the access plate in the cabinet above and reach in behind the switch panel to feel for the switch wires. Count the wire groups over until you've found the one for the kitchen light switch. Wiggling the wire connections slightly will sometimes cause the internal switch contacts to start working. Otherwise, push the switch out of the panel from behind and have Oliver send you a replacement.
This makes More sense since both lights stopped Working At exactly the Same time
Charlie.
I like that solution. Simple, easy, cheap and quick.
