Hi all, strange question, but our trailer is parked by the garage and I am using the OTT power cord plugged into our new 30 amp outlet that we had installed for the storage time.  Should I have a different cord for that purpose?  It's maybe 15 feet to the outlet.  I just wonder if having my trailer power cord exposed to the elements  for 5-6 months is wise.  Maybe I should get a cord that's shorter for storage season and leaving the "good" power cord for actual use camping.  TIA.
I don’t think it’s anything to worry about.  The cord that came with you trailer is nothing special, there are after market cords that do the same.  I got another cord without the locking lug that I carry to extend the reach of my locking cord if needed.  We’ve had a few sites where our standard cord didn’t reach and the extension made the difference.  Mike
I agree with Mike. The only thing I would add would be if it were constantly exposed to sunlight the UV (might) damage the outside insulation. I truly don't know. If you are only trying to keep the batteries charged, you could consider buying or making a shorter cord dedicated to that one task. The cord that comes with the trailers is 10 awg. Cords that heavy might cost $3/foot for the wire and then the proper fittings for each end if you wanted to make up a dedicated one. A 12 awg cord can be bought relatively cheap locally and it will handle everything but possibly running the A/C.
The proper ends would be like these:
Male...
Female...
Even though you could attach a smaller gauge cable to 30 amp connectors, I'd be hesitant to do so. Someday down the road someone could grab the wrong cord and fire up the A/C, risking overheating the cable and a fire. I just don't like mismatching amp ratings between wire and connectors (unless the wire capacity is greater than the connectors).
And, yes, I understand that's what we're doing when we use something like a 30A to 15A adapter, but I feel like that's a bit different because we can see the adapter and know that the capacity has been derated. How about something like this for use at home: Leisure Cords 90 Degree 15' Power/Extension Cord with 30 AMP Male Standard / 30 AMP Female 90 Degree Locking Adapter (30 Amp - 15 Foot) https://a.co/d/ewDztDt
Good to know that occasionally you need an extension.
Apparently my reply was not clear. I intended that anyone making up another shorter cord should be using the $3/foot 10 awg wire with the displayed ends. My suggestion of a lighter 12 awg extension cord was intended for only light duty (not running the A/C.) Sorry for the miscommunication.
Thanks.  I think that I will get that.   I want to reserve my supplied power cord for camping use and using that  15 foot cord will save wear on my 25 foot cord due to weather.  It also might come in handy for those rare times when we might need more than 25 feet to reach the pedestal.  I assume that I could use both cords together in those cases.
We ended up several feet short of a power outlet the first week after leaving OTT with our E2 at a HipCamp. I called Service and they assured me that you can add a 50 foot cord to the 25 footer provided making 75 feet total but not to go any longer than 75 feet since it results in other unintended consequences (power loss and subsequent problems related to that). We've used the 50 footer several times but have never had to put the two together.
Albert & Terri Sterns
Paonia, Colorado
I'll bet that 50 footer is one heavy puppy.
Since the need for an extension cord is so rare (at least for me its only been one time in 7 years) I bought a 30 foot 10 gauge regular extension cord.  Its lighter, smaller and will still allow me to run the a/c if needed.
For John's application something smaller would do (as pointed out in a couple of the posts above) as long as the use of the a/c was controlled and monitored.  AS far as the original cord being used - I'd make sure that it had UV protection applied to it at least every couple of months.
"AS far as the original cord being used - I'd make sure that it had UV protection applied to it at least every couple of months."
Bill, how is that done?  We live on a north facing hill and have sun on the trailer area only about half the day due to some tall fir trees, so it's not as solar intensive, but I would be interested in what UV protection you use.  Thanks.
At the beginning of the "season" and again at the end I clean the cord very well and then apply THIS stuff according to directions.
p.s.  If for some reason the cord gets weathered (think serious rain, sand, mud, dragging through a bunch of wet grass, etc.) during the heavy camping year, I'll apply 303 more often.
Yes.  But, I recommend carrying a 1-Gallon Ziploc bag in which to enclose the connection between the 30A two cords.  Cut a hole in the side opposite the bag opening for one cord, tape up that hole with Goorilla tape, insert the cord connections, and press the other side closed.  This helps keep rain water and condensation out of the open connection between the cords.
Actually, no. 30A RV extension cords have a different female end. No twist-lock.
Great idea!
Bet it was - I am SO looking forward to having a 30 amp cord.  I had a 30’ 50 amp cord on the Airstream and I can remember several occasions coming out to disconnect for an early launch in single digit temps. That cord would freeze solid and did not want to curl up, not to mention how heavy it was!  It would go in the back of the truck for that leg.
Happy to see you put this in writing, I was wondering if I was the only one thinking this. You can either get a longer replacement cord or get an extension cord but they are not interchangeable.
Always good discussions here!
Brian
We just use the cord that came with the camper. We did the same with our other camper and never have had any issues with it being out in the elements all winter.
2021 Dodge Ram 1500
2021 Oliver Elite ll
Hull #732
Michigan
