Bill and Nancy Posted March 30, 2023 Posted March 30, 2023 If I understand this correctly Im supposed to run the batteries down to LVC and re charge them every 6 months. If this is so does anyone have a recommended procedure and how I should discharge them (ie run an electric heater) and how do I know when they are at LVC. The other question is why is the Norcold refrigerator not connected to the inverter? thanks Bill Bill & Nancy Holland MA 2022 Elite II Hull #1265 2022 GMC Diesel Canyon
John E Davies Posted March 30, 2023 Posted March 30, 2023 2 hours ago, Bill and Nancy said: The other question is why is the Norcold refrigerator not connected to the inverter? It would waste your battery to invert it, due to efficiency losses in the equipment, the fridge already runs on battery, so the only time it benefits is when you are connected to a 120 volt ac power source. John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
DaveAndBecky_NorthernMI Posted March 30, 2023 Posted March 30, 2023 You can use Lithionics app to monitor voltage during discharge. If you have solar you'll want to disable solar charging using red switch in streetside upper cabinet above bed. 2022 Oliver Elite II Hull#1047 "Saunter" 2022 Ram 1500 5.7L Hemi
Geronimo John Posted March 31, 2023 Posted March 31, 2023 I am a new Litho user so this is my dumb question(s) response: The idea of draw-down and recharge past "Resting Full Charge" on to equalization level is to ensure that all the cells are "together" voltage wise. For our Battleborns (3 Each 100AH = 300 AH Total), and charging at 60 amps, I was advised to charge up to 13.7 (RFC) and continue charging with our Progressive Dynamic's 60 amp charger for 30 minutes/ battery = 90 minutes. It will peak out at 14.7 and stay there for the equalization process. At that point, shut off the charger and it will settle back to RFC of 13.7 volts and all cells will be at that voltage allowing use of 100% of the installed batteries. The idea is to over charge for equalization purposes periodically. Bill's question and responses above went "Tilt" in pea brain so, I can't help but ask: Is there a reason to take it all the way down to the Low Voltage Cutoff (LVC)? Wouldn't just say 30% Status of Charge (SOC) do just as well? GJ and other new Litho's are a pondering...... 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Rivernerd Posted March 31, 2023 Posted March 31, 2023 On 3/30/2023 at 7:04 AM, Bill and Nancy said: If this is so does anyone have a recommended procedure and how I should discharge them (ie run an electric heater) and how do I know when they are at LVC. I turn on all the interior lights, along with the inverter, and run a space heater plugged in to a 110V receptacle. You know when you have reached Reserve Voltage Cutoff when the space heater and the lights go off. This means the BMS in the batteries has done its job by turning off the batteries before they get fully depleted. Once the lights go off, it is time to unplug the space heater, ensure that the inverter is off, turn off the master light switch, and reconnect shore power to recharge the batteries. You can then leave shore power connected for another 6 months, or until you put the trailer back into regular use. Hope this helps. 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
CnC Posted March 31, 2023 Posted March 31, 2023 13 hours ago, Geronimo John said: Low Voltage Cutoff In five years of using Battleborn lithium, we have never taken our batteries down to their bottom settings on purpose. They did go "dead" once while boondocking and we had to plug in our portable Yeti 1000 (emulating shore power) to initiate the internal BMS. This is from BB's blog: "Some batteries, including Battle Born batteries, have a low-voltage disconnect feature built into the BMS. This is a safety feature designed to protect your batteries and help ensure they last as long as possible. The low-voltage disconnect mode typically kicks in when a battery reaches 10V, and it’s important that you charge your battery as soon as possible. Within five days is best. The only way to get a battery out of low-voltage disconnect mode is by resetting it, which means charging it. You’ll need to plug into shore power or alternator power or get a charge from solar panels. If you can, charge them back up to 100% and allow the batteries to balance all of the cells." Charlie. 1 Arizona | 2020 Oliver Elite II Twin bed Hull #617 | 2021 Ram 1500 e-Hemi 4x4
Moderators Mike and Carol Posted March 31, 2023 Moderators Posted March 31, 2023 We don’t run our Battle Borns down either. I’ve had them down to 50% a couple of times but usually they don’t go down below 70% before they get some charge. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Geronimo John Posted March 31, 2023 Posted March 31, 2023 5 hours ago, CnC said: In five years of using Battleborn lithium, we have never taken our batteries down to their bottom settings on purpose. 5 hours ago, CnC said: "Some batteries, including Battle Born batteries, have a low-voltage disconnect feature built into the BMS. 1 hour ago, Mike and Carol said: We don’t run our Battle Borns down either. I’ve had them down to 50% a couple of times but usually they don’t go down below 70% before they get some charge Mike and CnC: Exactly my thoughts and procedures as they echo the Battleborn guidance. The intent of my post was to get just such feedback. That said, the advice and procedures stated are only for OUR Battleborn based systems. Other manufacturers have their procedures to be followed. The very reason it makes sense (as all three of us did!) to always state what battery manufacturer and size/model we are talking about. Especially for Lithionics that vary quite quite bit from Battleborn, especially in the topic of cold weather unattended storage requirements. . GJ 1 5 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
