Rivernerd Posted April 20, 2023 Posted April 20, 2023 We just returned from a week on the Oregon Coast. During our return trip to Idaho, we encountered several miles of freshly sanded snow/slush as we drove across Tombstone Pass. It coated the back end of our Ollie with fine grit. We also found that sand-laden water had worked its way through the rear window and left a trail of grit from the bottom of the window downward across the belly band. When I asked Oliver Service how to reseal the rear window to prevent this from happening again, Jason Essary advised me to check if the weep holes were clogged. Sure enough, the weep holes had gotten packed with fine road sand, which apparently allowed the sand/water mix to get inside. Cleaning the weep holes out with a jet of water was the solution, not re-sealing the window. Lesson learned: If you find a leak around a window, the first thing to check is the weep holes! 3 6 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
AlbertNTerri Posted April 21, 2023 Posted April 21, 2023 Thanks for the recommendation, it just got added to the list for the upcoming maintenance 1 Albert & Terri Sterns Paonia, Colorado Elite II Hull #1125 Standard Floorplan / 2017 Ford F250 gas
Patriot Posted April 21, 2023 Posted April 21, 2023 This is a regular fairly well known inspection point whenever we clean and detail our Ollie after a trip. The window tracks can at times get a dirt and grim build up depending where you travel and camp. Keeping a small can of compressed air is really helpful if you discover an issue during a trip. We also use a damp paper towel dampened with a little alcohol which fits into the window track to remove any of the grime. Directly spraying water into this track area filling the track could cause water to drip inside. Compressed air can be found in most Lowe’s and Walmarts. Patriot🇺🇸 1 4 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
MAX Burner Posted April 21, 2023 Posted April 21, 2023 SLIDING WINDOW QUESTION: Does anyone have difficulty sliding the windows open/close? Ours take 2 hands to slide open/closed, is there a maintenance tip/hack to get them sliding easier? (We've removed/replaced the plastic window glaze and cleaned out weep holes and tracks) Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Moderators topgun2 Posted April 21, 2023 Moderators Posted April 21, 2023 Try THIS 2 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
MAX Burner Posted April 21, 2023 Posted April 21, 2023 Will do, thanks, brother! Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Steph and Dud B Posted April 21, 2023 Posted April 21, 2023 4 hours ago, MAX Burner said: Does anyone have difficulty sliding the windows open/close? Our rear escape window is stiff to slide. Not 2 hands, but close. 4 hours ago, Patriot said: Directly spraying water into this track area filling the track could cause water to drip inside. We've used an ear wax bulb syringe for this. Allows you to really control the water. 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Moderator+ ScubaRx Posted April 24, 2023 Moderator+ Posted April 24, 2023 On 4/21/2023 at 7:03 AM, MAX Burner said: SLIDING WINDOW QUESTION: Does anyone have difficulty sliding the windows open/close? Ours take 2 hands to slide open/closed, is there a maintenance tip/hack to get them sliding easier? (We've removed/replaced the plastic window glaze and cleaned out weep holes and tracks) Have you completely removed the slider window, all the rubber channels and cleaned them by hand? After reinstalling it all spray the tracks with some dry lubricant for window tracks. Doing so will go a long way toward making those windows move easily and smoothly. 1 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
MAX Burner Posted April 24, 2023 Posted April 24, 2023 31 minutes ago, ScubaRx said: Have you completely removed the slider window, all the rubber channels and cleaned them by hand? I got the lube from Amazon yesterday - but I'll take the windows out and clean up the mess in the tracks before applying the lube! Good call, thanks, brother! Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
